jaeger Posted December 12, 2019 Share #1 Posted December 12, 2019 (edited) Advertisement (gone after registration) I put away the Leica hand-grip and installed the stock bottom cover today and I realize there is rubber opening that aligns with the SD card. I have never used the stock cover... so can I remove the SD card thru that slot without take off the bottom cover, or even without powering off the camera? Thanks!! In additional, I have a MP version in black. Does the bottom cover brassing like to top plate as well? That would be sooo pretty!! Edited December 12, 2019 by jaeger Link to post Share on other sites More sharing options...
Advertisement Posted December 12, 2019 Posted December 12, 2019 Hi jaeger, Take a look here M240 bottom cover SD card slot . I'm sure you'll find what you were looking for!
jdlaing Posted December 13, 2019 Share #2 Posted December 13, 2019 (edited) NEVER remove the card with the camera powered on. That black slot you’re referring to Is an attempt to be able to use and sd card with built in WiFi. It’s not designed to be used as an sd card access. Edited December 13, 2019 by jdlaing 2 Link to post Share on other sites More sharing options...
lct Posted December 13, 2019 Share #3 Posted December 13, 2019 Yes it is a plastic part allowing Eye-Fi cards to transmit more easily. Don't ask me how it works i've never used those cards so far. 1 Link to post Share on other sites More sharing options...
jaeger Posted December 13, 2019 Author Share #4 Posted December 13, 2019 (edited) 38 minutes ago, jdlaing said: NEVER remove the card with the camera powered on. so can I remove the card thru that slot when the camera is powered off? Edited December 13, 2019 by jaeger Link to post Share on other sites More sharing options...
jaapv Posted December 13, 2019 Share #5 Posted December 13, 2019 No - unless you destroy the plastic. It is not meant for that purpose. 1 Link to post Share on other sites More sharing options...
jaeger Posted December 13, 2019 Author Share #6 Posted December 13, 2019 16 minutes ago, jaapv said: No - unless you destroy the plastic. It is not meant for that purpose. got you, thanks. Link to post Share on other sites More sharing options...
lct Posted December 13, 2019 Share #7 Posted December 13, 2019 Advertisement (gone after registration) Not sure it can't be removed but too bad for weather sealing then. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/304388-m240-bottom-cover-sd-card-slot/?do=findComment&comment=3872263'>More sharing options...
jaapv Posted December 13, 2019 Share #8 Posted December 13, 2019 I've never tried it but I think that if you push it out once you won't get it to stay in afterwards. Link to post Share on other sites More sharing options...
jdlaing Posted December 13, 2019 Share #9 Posted December 13, 2019 2 hours ago, jaeger said: so can I remove the card thru that slot when the camera is powered off? No. Link to post Share on other sites More sharing options...
sblutter Posted December 18, 2019 Share #10 Posted December 18, 2019 Luigi of Leicatime has base covers with a little door that opens to the battery & card area. Haven't taken it off since I got it. There old threads about the annoying original base on this site. Link to post Share on other sites More sharing options...
