I'd say this TL lens is a real option for a compact 80-200 mm FF equivalent zoom on the SL2 thanks to IBIS.  It's so light that one can handhold it at 1/(FF equivalent f/10) sec. with care.
Edit - handhold it at 1/(FF equivalent f/16) sec.  Look at the next one.
Less compressed JPEG here: https://www.smugmug.com/gallery/n-fJ7LMr/
At 87.0 mm (35 mm equivalent: 132.0 mm)
ISO 100 f/4.5 @1/15 sec. Edited by Chaemono
It was a gray morning, light was pretty bad.  Still, ISO 100 would do just fine, thanks to IBIS. 😀
At 135.0 mm (according to the EXIF analyzer, 35 mm equivalent: 205.0 mm)
ISO 100 f/4.5 1/13 sec.
I can't upgrade and am limited to 500K, hence, a separate post for each picture.  At f/5.6 this lens is a stunner.
ISO 100 f/5.6 @1/40 sec. Edited by Chaemono
One more.
At 55.0 mm (according to the EXIF analyzer, 35 mm equivalent: 83.0 mm)
ISO 100 f/3.5 @1/13 sec.
The SL2 is just what the doctor ordered for this lens.  Its optical performance is incredible but it's slow.  On the SL2 it can be shot at ISO 100 most of the time.
At 93.0 mm (35 mm equivalent: 141.0 mm)
ISO 100 f/4.5 @1/30 sec. Edited by Chaemono
  • 1 month later...
vor einer Stunde schrieb SrMi:
A manual focus alternative to 55-135 could be Leica APO-Telyt-M 135mm f/3.4. Compared to the TL zoom it gives you a reach from 135-200 (by the way of cropping). Thoughts?
The t. opener and I are talking about the SL 2 and the TL zoom lenses.
Edited by Khun Hans
Probably I will take the SL 2 and the 24/90 plus the 55 - 135 with me, when I will visit Meran for app. one week  in April. I could take my 90/280 with me too, but this one is a heavy beast and I do not think, I will need it for this trip. Thank you for showing the photos - they confirm my intention.
I think this is a good point actually. If you already have the 55-135mm it may make sense to use it on SL2. Otherwise, as is my case, the  24-90 SL takes me to an equivalent 135mm cropped, and there are many great budget 135mm lenses to take me to a cropped 200mm (R, M, Contax, Canon or the Signa Art) with probably similar quality cropped to the TL zoom, or I can but a great R 180mm, also cheaper.
What do I lose? The ability to zoom between 135mm and 200mm and some compactness.  For me, if you are with full frame systems (SL and M) it’s best to stick to FF lenses. If you have both APS-C and FF, then mix and match to your heart’s delight.
This thread is about "SL2 + APO-VARIO-ELMAR-TL 55–135mm" as a an interesting option for SL2 owners. My question is about alternatives to that combo and what are people's thoughts about 55-135 vs Telyt 135. Sounds very much on topic to me.
vor 6 Stunden schrieb SrMi:
Then open your own treat about that topic.
Am 7.12.2019 um 22:38 schrieb Chaemono:
Is it only me to see these typical Leica colors and fine resolution (SmugMug) with this TL lens? It shines for me to be worth buying as a zoom for the simple FB or so shots as I mainly use the M primes 21,35,50,90 on the SL 2. Thanks for posting.
  • 8 months later...
There's quite a lot of talk about using the TL 55-135 Vario-Elmar on the SL2 (where IBIS and larger sensor cropped = about 22) but is it worth using on the SL where the sensor size is reduced to about 10? Presumably, the range remains 55-135mm on the SL, is that also the case with F stops (i.e. f3.5 - f4.5)? Has anyone had experience shooting this lens on the SL (not SL2)?
Yes, the values of the lens remain the same both focal length and aperture (i.e. exposure), but as the effective sensor size has shrunk, the DOF will get wider. On a long lens with a quite narrow native DOF, especially at the long end, this may be of advantage.
Thank you, jaapv.
In the 12 months since I've had an SL I've used only Voigtlander primes (up to 75mm) and am looking for something longer - probably zoom. Leica's own SL zooms are beyond my budget and I think the Panasonic's are too large. Not sure about Sigma - so my fallback might be the TL 55-135. Those are my present thoughts, but open to ideas. My only concern with the TL lens is that the sensor size is effectively halved - so chances of cropping in post are very limited.
By the way, the Voigtlanders (21mm f3.5 M-mount and 58mm f1.8 NF-mount) produce high quality images and are very easy to use. These are definitely 'keepers'. The V 75mm f1.8 is OK, but could be bettered.
  • 4 years later...
I also think about buying an used SL2 and the APO-Vario-Elmar-TL 1:3,5-4,5/55-135 ASPH as the full frame Leica 70-200 is too big and heavy for me. And then I can also use my 3 M (21, 35, 90) and 5 R (28, 90, 100, 180, 70-210) Lenses on this body as well (maybe I sell my Q2 to get that money)
do you still use this combination?
