humerc Posted August 17, 2019 Share #21 Posted August 17, 2019 Advertisement (gone after registration) Yes, I also have only 2 screws. Its also not so easy to set the focus exactly... Link to post Share on other sites More sharing options...
Advertisement Posted August 17, 2019 Posted August 17, 2019 Hi humerc, Take a look here 7artisans 75mm f/1.25 lens for Leica M-mount specifications and sample photos. I'm sure you'll find what you were looking for!
Ecar Posted August 17, 2019 Share #22 Posted August 17, 2019 I found the focus adjustment process very straightforward, perhaps because I have done it before on their 50/1.1 and 35/2. This time around, the lens was only very slightly off (didn't quite reach infinity) and a single adjustment was good enough. Setting proper infinity focus took care of closer distances. It took me literally 2 minutes. The key is to make very small, incremental adjustments and then check with LV/EVF (assuming your camera belongs to the M240 or M10 generation - else it gets somewhat more tedious) until you are happy with the results. Link to post Share on other sites More sharing options...
humerc Posted August 17, 2019 Share #23 Posted August 17, 2019 Thanks, I have the M10-D, so LV is only possible over the phone, which makes the process somewhat more complex. The process itself is not complicated, but to get everything right seems difficult. Perhaps it is the lens, as with a 75mm at 1.25 nailing focus is not really easy. I got some good results (good sharpness at 1.25), but it is not easy to replicate, so most of my pictures seem to be slightly out of focus and I ask myself if I did something wrong at the calibration. Link to post Share on other sites More sharing options...
Ecar Posted August 17, 2019 Share #24 Posted August 17, 2019 Take some time to ensure proper calibration: set camera on tripod, connect to phone, etc. Once you are satisfied with it, and unless there's an issue with the lens itself, you will know that any focusing errors are user-induced 😉 In any event, the DoF @ f/1.25 is so thin that you can't expect to nail focus every time, especially if you shoot handheld and close to your subject... 1 Link to post Share on other sites More sharing options...
lct Posted August 17, 2019 Share #25 Posted August 17, 2019 +1. I have no experience with this lens but at full aperture, my Summilux 75/1.4 is near the limit of the RF accuracy. To nail focus, better use the EVF + focus magnification if needed. 1 Link to post Share on other sites More sharing options...
michali Posted August 17, 2019 Share #26 Posted August 17, 2019 I've been looking for a 75mm lens since I sold my Summicron f2 which had QC issues straight out the box, I aIso found it too clinical. I then bought a 75mm Summarit f2.5, well the less said the better about its build quality, they can't seem to sort out the rattle of the front portion of the barrel. Have been considering the 7Artisans. However I have some concerns especially when it comes to having set up focus calibration etc. I'm going to play it safe and have ordered the Voigtlander 75mm f1.5 ASPH. 1 Link to post Share on other sites More sharing options...
Matlock Posted August 17, 2019 Share #27 Posted August 17, 2019 Advertisement (gone after registration) 37 minutes ago, michali said: I then bought a 75mm Summarit f2.5, well the less said the better about its build quality, they can't seem to sort out the rattle of the front portion of the barrel. Strange, I have the 75mm Summarit f2.5 and find it superb. Also it seems to get an almost 100% from most users. Perhaps you were unlucky with yours. 1 1 Link to post Share on other sites More sharing options...
Ecar Posted August 17, 2019 Share #28 Posted August 17, 2019 Well, the aperture ring of my Summarit 75/2.5 started to spin freely shortly after I purchased it (new) about 10 years ago. It was fixed by Leica and has been fine ever since. It's lighter and easier to use than my Summicron 75/2 and, to be honest, I see little IQ difference (if any) between them in real-life use. Link to post Share on other sites More sharing options...
lct Posted August 17, 2019 Share #29 Posted August 17, 2019 I like much my 75/2.5 but i wouldn't say it is built like a tank. Mine had problems with the aperture ring as well. Link to post Share on other sites More sharing options...
humerc Posted August 17, 2019 Share #30 Posted August 17, 2019 6 hours ago, Ecar said: A quick update to my post above after receiving a reply from 7a: there are only 2 screws, not 3, on the focus ring adjustment - and a video explaining the calibration procedure can be found here https://www.youtube.com/watch?v=GSmtmQs-oxc&feature=youtu.be Thanks for the video link! I used the instructions from my 35/2 and there you should only move the ring 0,5mm - but the 75/1.25 needs bigger moves (3mm). I think I now have it properly calibrated! 1 Link to post Share on other sites More sharing options...
Ecar Posted August 17, 2019 Share #31 Posted August 17, 2019 One in BW. Again wide open on the M10. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 14 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/297654-7artisans-75mm-f125-lens-for-leica-m-mount-specifications-and-sample-photos/?do=findComment&comment=3799748'>More sharing options...
Coltma Posted August 17, 2019 Share #32 Posted August 17, 2019 (edited) On 8/13/2019 at 2:24 PM, Coltma said: Got mine two days ago. I'm in China. Very nice lens to me. But just found something "wrong" in the bokeh part. Right now it's on the way back to the factory. Need to check the QC again. After my lens returned to the 7Art, they replied that the bokeh problem I described was an "optical design style." The goal is to sacrifice bokeh rendering to reduce the purple fringing at the focus point. They call this a normal phenomenon, not a QC problem. And kindly send back a new one to me. Hmmm...Yes, the same problem. This is a typical busy bokeh rendering brought by overcorrected spherical aberration. You found a "bright core" in the background bokeh. As the focus moves away, the bokeh spot will gradually become large, dim and even, making it progressively more difficult to detect. For your understanding, just finished another test. A crop of my LED panel at 1.2m away. Notice the focus distance I marked. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! This is what it looks like in the actual photo, some street lights at 500m away. 100% cropped: Since it is so cheap at 75/1.25 grade, I can really understand it's compromise. But this does cause confusion in use. Be careful to avoid strong point light sources or strong textures in the background, especially before and after the focus point. Finally, boring part is over. Please continue to love it. This lens is really special. Edited August 17, 2019 by Coltma 1 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! This is what it looks like in the actual photo, some street lights at 500m away. 100% cropped: Since it is so cheap at 75/1.25 grade, I can really understand it's compromise. But this does cause confusion in use. Be careful to avoid strong point light sources or strong textures in the background, especially before and after the focus point. Finally, boring part is over. Please continue to love it. This lens is really special. ' data-webShareUrl='https://www.l-camera-forum.com/topic/297654-7artisans-75mm-f125-lens-for-leica-m-mount-specifications-and-sample-photos/?do=findComment&comment=3799959'>More sharing options...
jaeger Posted August 17, 2019 Share #33 Posted August 17, 2019 1 hour ago, Coltma said: After my lens returned to the 7Art, they replied that the bokeh problem I described was an "optical design style." The goal is to sacrifice bokeh rendering to reduce the purple fringing at the focus point. They call this a normal phenomenon, not a QC problem. And kindly send back a new one to me. Hmmm...Yes, the same problem. This is a typical busy bokeh rendering brought by overcorrected spherical aberration. You found a "bright core" in the background bokeh. As the focus moves away, the bokeh spot will gradually become large, dim and even, making it progressively more difficult to detect. For your understanding, just finished another test. A crop of my LED panel at 1.2m away. Notice the focus distance I marked. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! This is what it looks like in the actual photo, some street lights at 500m away. 100% cropped: Since it is so cheap at 75/1.25 grade, I can really understand it's compromise. But this does cause confusion in use. Be careful to avoid strong point light sources or strong textures in the background, especially before and after the focus point. Finally, boring part is over. Please continue to love it. This lens is really special. do you mean the color in boken was the problem? Link to post Share on other sites More sharing options...
humerc Posted August 17, 2019 Share #34 Posted August 17, 2019 (edited) I have one question, maybe someone can answer: I adjusted the focusing and its so far really good for my typical shooting (mostly portraits). But I checked infinity focusing and the RF Patch goes a bit to wide. If I now start again to adjust at the ring this would mean my otherwise “perfect” setting will be gone, or do I misinterpret this? I just cant understand how I can set two different settings with adjustments in the same ring... Edited August 17, 2019 by humerc Link to post Share on other sites More sharing options...
satijntje Posted August 17, 2019 Share #35 Posted August 17, 2019 My 75mm 7artisans lens is blocked at the DHL customs clearance office in Leipzig. I bought the lens on Amazon Germany but although it says that VAT (Ust) is included in the price, DHL wants proof of the content of the package and its price. Curious to find out who will be paying the VAT! I have informed the Chinese seller, letters see what comes out of this 😞 John Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/297654-7artisans-75mm-f125-lens-for-leica-m-mount-specifications-and-sample-photos/?do=findComment&comment=3800083'>More sharing options...
Coltma Posted August 18, 2019 Share #36 Posted August 18, 2019 8 hours ago, jaeger said: do you mean the color in boken was the problem? Not only the color edges. See the spherical aberration part: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/297654-7artisans-75mm-f125-lens-for-leica-m-mount-specifications-and-sample-photos/?do=findComment&comment=3800182'>More sharing options...
michali Posted August 18, 2019 Share #37 Posted August 18, 2019 Too much hassle to deal with 15 hours ago, Coltma said: After my lens returned to the 7Art, they replied that the bokeh problem I described was an "optical design style." The goal is to sacrifice bokeh rendering to reduce the purple fringing at the focus point. They call this a normal phenomenon, not a QC problem. And kindly send back a new one to me. Hmmm...Yes, the same problem. This is a typical busy bokeh rendering brought by overcorrected spherical aberration. You found a "bright core" in the background bokeh. As the focus moves away, the bokeh spot will gradually become large, dim and even, making it progressively more difficult to detect. For your understanding, just finished another test. A crop of my LED panel at 1.2m away. Notice the focus distance I marked. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! This is what it looks like in the actual photo, some street lights at 500m away. 100% cropped: Since it is so cheap at 75/1.25 grade, I can really understand it's compromise. But this does cause confusion in use. Be careful to avoid strong point light sources or strong textures in the background, especially before and after the focus point. Finally, boring part is over. Please continue to love it. This lens is really special.' You're absolutely right when you say, "Since it is so cheap at 75/1.25 grade, I can really understand it's compromise." However IMHO it's too much hassle to deal with, I'm pleased I purchased the Voigtlander 75mm f1.5, albeit at double the price of this lens. Best, Mike 1 Link to post Share on other sites More sharing options...
Ecar Posted August 18, 2019 Share #38 Posted August 18, 2019 20 hours ago, Coltma said: But this does cause confusion in use. Be careful to avoid strong point light sources or strong textures in the background, especially before and after the focus point. You are right. I could easily reproduce the issue today when taking pictures of kids in the water. Below is a heavy crop (I won't post the full image for privacy reasons) of an unprocessed picture taken at full aperture. It shows what happens when part of the image is only slightly out of focus and there are strong highlights (in this case, reflections from droplets of water). Indeed, at under 500 USD something's gotta give... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 3 1 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/297654-7artisans-75mm-f125-lens-for-leica-m-mount-specifications-and-sample-photos/?do=findComment&comment=3800518'>More sharing options...
jaeger Posted September 2, 2019 Share #39 Posted September 2, 2019 is this lens 6-bit coded? Link to post Share on other sites More sharing options...
humerc Posted September 2, 2019 Share #40 Posted September 2, 2019 No 6-bit coding any longer on 7Artisans lenses. The first one had it, but they stopped it some time ago. Link to post Share on other sites More sharing options...
