On 1/18/2019 at 4:37 AM, Keith (M) said:
Looking at that video, the filter size for the 24-105mm is a huge 77mm, which really gives a clear idea of the scale of the outfit - even my Sony 70-200mm f4 G is only 72mm.
Ummm, the Sony 24-105 f4 G, also has a 77mm filter size.....
Gordon
On 1/24/2019 at 11:22 PM, frame-it said:
An interesting remark by Peter Karbe was that a fixed aperture zoom is just a variable aperture one with the larger apertures at the short end disabled. So a constant 2.8 might be capable of 1.4 on the wide end.
You can see this on many constant aperture lenses.  The aperture blades stop down as you zoom out.  This mattered more in the days when all metering was not through the lens and we liked to have accurate aperture marks on the lens.  Now that we don’t have calibrated aperture markings on the lens, might as well have the extra speed at the wide end...
Edited by mdemeyer
Video shooters still like constant apertures.
Gordon
Heavier than the SL, a bit higher, a lot thicker, but a 25% more dot EVF. And, oh BTW, double the MPS and ~$2k less. If it handles M lenses as well as the Nikon Z7, this could be very interesting.
  • 47.3 million pixels Full size sensor · Low pass filter less
  • 5-axis hand vibration reduction within the body with 5.5 steps of effect
  • Dual IS 2 with 6 stages of effect
  • 4K 60p / 50p video
  • Sequential shooting performance: 9 frames / second (AFS), 6 frames / second (AFC)
  • 6K photo at 30 frames per second and 4K photo mode at 60 frames / sec
  • 5.76 million dot EVF
  • The finder magnification can be adjusted from 0.78 times to 0.74 times or 0.7 times
  • Movable rear liquid crystal with 2.1 million dots
  • Dustproof · Drip-proof · Low temperature-10 °
  • Picture of 187 million pixels (16,736 x 11, 168) can be created using high resolution mode
  • Advanced Artificial Intelligence Technology Detecting Humans, Cats, Dogs and Birds
  • Size: 148.9 x 110.0 x 96.7 mm
  • Weight: 898 g
  • Overseas price: Body 3, 399 GBP, lens kit 4, 199 GBP
Edited by bags27
15 minutes ago, bags27 said:
Heavier than the SL, a bit higher, a lot thicker, but a 25% more dot EVF. And, oh BTW, double the MPS and ~$2k less. If it handles M lenses as well as the Nikon Z7, this could get interesting (in the Chinese sense of worrisome).
Should handle the Leica SL lenses well.  I use my grip to balance the camera and I know many here use the RRS base, so the higher/thicker looks promising.
6 hours ago, bags27 said:
T lenses work on the SL with, what? around 16 mps, of picture. Is that right? Then with a 47 mps sensor they could give something like 24 mps images I suppose. Making T lenses more valuable.
16? i thought the resulting images were 10mp
According to Leica Technical Sheet APS-C of SL (typ 601) is
For a 47.3 sensor it would be 47.3/(1.5x1.5) i.e. slightly more than 21 megapixel.
from the "leak" site:
LUMIX S 24 - 105 mm F4 Macro OIS
  • Lens construction: 13 groups 16 pieces (including 2 aspheric lenses and 2 ED lenses)
  • Minimum shooting distance: 0.3 m
  • Maximum shooting magnification: 0.5 times
  • Filter diameter: 77 mm
  • Size: φ 84 x 118 mm
  • Weight: 680 g
  • Dual IS 2 compatible
  • Overseas price: 1,299 pounds
LUMIX S PRO 70-200 mm F4 OIS
  • Lens construction: 23 groups in 17 groups (1 aspherical lens and 3 ED lenses included)
  • Minimum shooting distance: 0.92 m
  • Number of diaphragm blades: 9
  • Size: φ 84.4 x 179 mm
  • Weight: 985 g
  • Overseas price: 1,749 GBP
LUMIX S PRO 50 mm F 1.4
  • Lens construction: 13 groups of 11 lenses (2 aspheric lenses and 3 ED lenses included)
  • Minimum shooting distance: 0.44 m
  • Number of diaphragm blades: 11
  • Size: φ 90 x 130 mm
  • Weight: 955 g
  • Overseas price: 2,299 GBP
