Yes, I can do that, but sometimes, touching the area where the function of the right wheel appears when it is turned turns the lock ON (which means the wheel is OFF) and I haven't found a way to turn off touch input.
From the manual, I understand that touch-and-hold the icon or area on the display representing the wheel turns on the lock. Doesn't touch-and-hold on the same part of the screen turn off the lock? It should be a toggle... a little bit silly if it isn't.
I’m very disappointed that Leica choose not to address the wandering focus point many of us have commented on.
Hopefully they will fix in next upgrade?
Dan
+1
Louis, just out of curiosity what AF mode are you using? Multi Point, Spot or Field?
Bill, I have been using Field with most of my cameras; but a few days ago, I discovered that focus tracking is working really well for street photography. In this mode, I miss moving subjects less.
I am trying field right now. On my SL that is what I use. I will also explore the tracking. We will go to our local 4th parade and that would be a good test. Thanks again.
