Encounter this Leica case.
Who will use this beautiful case?
I have seen a lot of Leica owners tape the Leica logo.
Many SL users dislike half case due to the same issue you pointed out.
There seems no better solution to protect the camera body.
RRS has an L plate that works as a rotatable tripod mount and half protection. It does not increase the feeling of the size, But the protection only covers the bottom and the left side. Overall a leather case has much better protection coverage, including impact absorption.
I happen to shoot to hold my camera mainly with the left hand, grabing the lens, so the right hand feeling is not critical. Black seems to be a safer color, but this one has a tempting beautiful look.
Anyone has a happy story with SL case like this or similar?
Edited by Einst_Stein
I don't like any case that doesn't allow access to battery and SD card. I have an RRS bottom plate on mine, that's all.
I also have a L-plate of another brand fort another camera. It can also access the SD and battery.
But I never find it's necessary or useful. Modern digital camera and battery usually good enough to last a full day's work. and I rarely run out of the SD.
YMMV.
Most people's concern on this is usually psychological.
Gravity, ...,
Hasn’t adversely affected my photography in 45 years. I use soft tissue of another kind to protect and serve. Insurance helps, too.
Do you wrap your lens in a case, too, when shooting? Or your body?
Jeff
Edited by Jeff S
I have a case for my Leica SL. I had thought to use it to protect the body.
Frankly, for me it makes the SL too thick to hold and I do not use it when taking photos.
If so, do you think using RRS L plate a better solution? At least it can somewhat protect the bottom and the left side, not increase the grip size, and rotate to vertical on tripod. Edited by Einst_Stein
Reply: I would not recommend a case because it changes the grip size. I suppose a plate would not change that and would provide a measure of protection.
Rob
Kaufmann called the design somewhat ‘brutal’, ‘like with an axe’ and that the next version would be a bit more ‘elegant’. But that’s also when he said we’d realize some new potential in the L mount in June, 2018. Better hurry.
Jeff
Jeff
I have ruber lens shade.
Your age and years of photography has nothing to do with this question. Leica has offers of camera case for protection, so does many camera case vendor. Some of them have hundred years of making and selling camera or camera cases. I dont think you could be smarter.
The question is not about camera case or not, it is about which is better for this particular camera.
but with the huge SL lenses, wont the lens hit first /get damaged badly if the camera is falling ?
If you always had your lens hit instead of body, too bad.
No M mount lenses is huge, but I use ruber lens shade anyway, including 21mm, which has the ruber pulled back, essentially minimum shade mainly for impact absorption.
