This gentleman was playing with pride and passion.
Less compressed JPEGs here: https://www.smugmug.com/gallery/n-D6wJ8c/
ISO 800 f/1.25 @1/500 sec.
x
I have a hard enough time getting an in-focus shot using [...]the 90mm f2 wide open. I can only imagine the needed precision for f1.25. [...]
For a typical portrait/ street situation, DOF of 75@1.25 will be effectively the same as of 90@2.0.*
So no need to be afraid of the Nocti 75, all you apo Cron 90 asph users! ;)
Kind regards
Mathias
*: (Edit: and of course both will be much shallower than 50@0.95)
Edited by schattenundlicht
While waiting to shoot a fashion show, these two gentlemen approached a fellow photographer and me and asked us to take their picture. The gentleman on the right gave us his card. He is an actor by the name of Wolfgang Schloesser.
Less compressed JPEGs here: https://www.smugmug.com/gallery/n-N64xjs/
ISO 200 f/2.8 @1/500 sec.
Edited by Chaemono
An uninvited guest in the back posed for the fellow photographer next to me.
ISO 200 f/2.8 @1/750 sec.
We moved to a spot with better light from the sun setting.
ISO 200 f/2.8 @1/1000 sec.
They used this terrible yellow light on the catwalk which created a solarization effect as the models approached. Not all skin tones took it well. The effect was more pronounced in the evening.
ISO 200 f/1.25 @1/1000 sec.
The camera and the lens loved her.
The camera and the lens loved her just as much.
I will post a few more tomorrow.
Less compressed JPEGs here: https://www.smugmug....llery/n-N64xjs/
  • 1 month later...
75 Noctilux wide open..  for me, using the range finder wide open just won't nail it especially close in on my m10.  Also note that at long distances the r/f is inaccurate, in between distance wise it can work fine.  (saw this on two different bodies).  I highly recommend using live view as a double check or fine tune, or better yet, an evf.  The latter works great.
I’ve found the opposite Eesand using the 75 Noctilux. I’ve used this lens now on both the M10 and M240 and have had no trouble nailing focus wide open. I’ve also not seen any issues with infinity focusing.
I was actually surprised how good my focus keeper rate was, this lens for me is amazing. Now I just wish it was half the weight... my arms hurt!
Am 20.10.2018 um 02:51 schrieb Eesand:
Sounds more like you have an adjustment issue. Lens or body.
Or probably my own body - vision..  it is so close. Did another experiment 90 Cron wide open has similar dof as 75 open. I get same issue, I won’t detail the experiment, but same result on more than one camera. 50 Noctilux is more forgiving than these two open, it has a little more dof open. For me anything above 50, the evf helps me nail it every time.
As it turns out, after several experiments involving other bodies, my m10-p is headed to leica to calibrate the range finder.
7 hours ago, Chaemono said:
At long distances the r/f will still be inaccurate.
Right I see that with other lenses, even longer ones. In this case instead of a little bit off, it’s a lot causing distant subjects to be out of focus if one relies solely on the r/f. Also, the overall inaccuracy  occurs at shorter distance at above 50mm lenses.
Thanks for verifying what I see in well aligned systems.
glowing porch
Am 25.10.2018 um 04:15 schrieb Chaemono:
Why? I have no issue shooting far away objects with open apertures with the RF at all. On distance the RF doesn´t have to be that precise since the DOF extends the further away your subject is.
Am 25.10.2018 um 00:26 schrieb Eesand:
That´s what I thought and I bet your experience will be way better afterwards! :)
