geddon_jt Posted October 27, 2018 Share #61 Posted October 27, 2018 (edited) Advertisement (gone after registration) My first evening out with this lens. -John Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited October 27, 2018 by geddon_jt 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/285663-noctilux-75125-images/?do=findComment&comment=3620589'>More sharing options...
Advertisement Posted October 27, 2018 Posted October 27, 2018 Hi geddon_jt, Take a look here Noctilux 75/1.25 images. I'm sure you'll find what you were looking for!
geddon_jt Posted October 27, 2018 Share #62 Posted October 27, 2018 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 7 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/285663-noctilux-75125-images/?do=findComment&comment=3620590'>More sharing options...
Chaemono Posted October 30, 2018 Share #63 Posted October 30, 2018 (edited) Am 25.10.2018 um 01:26 schrieb Eesand: As it turns out, after several experiments involving other bodies, my m10-p is headed to leica to calibrate the range finder. Glad to see that my newly acquired M10-P is perfectly aligned with the 75 Noctilux-M Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! ISO 640 f/1.25 @1/60 sec. Edited October 30, 2018 by Chaemono Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ISO 640 f/1.25 @1/60 sec. ' data-webShareUrl='https://www.l-camera-forum.com/topic/285663-noctilux-75125-images/?do=findComment&comment=3622801'>More sharing options...
Eesand Posted October 30, 2018 Share #64 Posted October 30, 2018 2 hours ago, Chaemono said: Glad to see that my newly acquired M10-P is perfectly aligned with the 75 Noctilux-M Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! ISO 640 f/1.25 @1/60 sec. This one is shot with an m-10 which is about 13 months old. This camera focuses slightly in front of where the r/f says its focused, so, with some practice, after I line up, I nudge the focus ring just a tad toward a larger distance. I now nail nearly everything. After the M10-P returns from the hospital, the M-10 which is much closer to correct will go in for the same treatment. 2 Quote Link to post Share on other sites More sharing options...
Eesand Posted October 31, 2018 Share #65 Posted October 31, 2018 (edited) The 75 nocti can do this, too. It's around F4 on this. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited October 31, 2018 by Eesand 8 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/285663-noctilux-75125-images/?do=findComment&comment=3623213'>More sharing options...
jaques Posted October 31, 2018 Share #66 Posted October 31, 2018 I cannot afford such a fancy lens- but I am lucky enough to have an ancient Biotar 75 1.4... Not quite as sharp: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 4 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/285663-noctilux-75125-images/?do=findComment&comment=3623347'>More sharing options...
jto555 Posted November 1, 2018 Share #67 Posted November 1, 2018 Advertisement (gone after registration) On 10/25/2018 at 12:26 AM, Eesand said: As it turns out, after several experiments involving other bodies, my m10-p is headed to leica to calibrate the range finder. It is probobly too late to say that you can calibrate it yourself. All you need is a 2mm Allen key (hex wrench). I spent just over an hour calibrating both my M240s on Monday. The screw that you need acess to is on the lever in the lens mount. I set the camera up on a tripod and a target, with small text, in good light. Plus I set something slightly in front and behind. Just so I can see where the focus point is changed to. As you are looking down on the camera with the allen key in the nut, turning the key anti-clockwise sets the focus furter away while turning clockwise sets the focus nearer to the camera. By the way, only use tine adjustments, so a long handle allen key is easer to use. 1 Quote Link to post Share on other sites More sharing options...
Eesand Posted November 3, 2018 Share #68 Posted November 3, 2018 On 11/1/2018 at 6:43 AM, jto555 said: It is probobly too late to say that you can calibrate it yourself. All you need is a 2mm Allen key (hex wrench). I spent just over an hour calibrating both my M240s on Monday. The screw that you need acess to is on the lever in the lens mount. I set the camera up on a tripod and a target, with small text, in good light. Plus I set something slightly in front and behind. Just so I can see where the focus point is changed to. As you are looking down on the camera with the allen key in the nut, turning the key anti-clockwise sets the focus furter away while turning clockwise sets the focus nearer to the camera. By the way, only use tine adjustments, so a long handle allen key is easer to use. thanks. I think the M10 r/f is redesigned from the M240, so maybe adjustment process is different? BTW, I have one of those, and it's well used, the r/f is totally spot on. 1 Quote Link to post Share on other sites More sharing options...
Eesand Posted November 3, 2018 Share #69 Posted November 3, 2018 MP240 75 Noctilux wide open Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 10 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/285663-noctilux-75125-images/?do=findComment&comment=3624928'>More sharing options...
kikouyou Posted November 10, 2018 Share #70 Posted November 10, 2018 On 11/1/2018 at 4:43 AM, jto555 said: It is probobly too late to say that you can calibrate it yourself. All you need is a 2mm Allen key (hex wrench). I spent just over an hour calibrating both my M240s on Monday. The screw that you need acess to is on the lever in the lens mount. I set the camera up on a tripod and a target, with small text, in good light. Plus I set something slightly in front and behind. Just so I can see where the focus point is changed to. As you are looking down on the camera with the allen key in the nut, turning the key anti-clockwise sets the focus furter away while turning clockwise sets the focus nearer to the camera. By the way, only use tine adjustments, so a long handle allen key is easer to use. My M10P arrived brand new mis calibrated (it was good but not perfect) on the focus, thanks to this (I would not say easy) adjustment I got it spot on now without returning the camera. Thanks god the other calibrations of the patch were perfect, they are much more difficult to achieve (infinity, vertical, horizontal) .There is a detailed explanation on this forum with graphics and pictures on how to do this. I have now the 2mm Allen key always in my photo bag just in case... Also I never had to recalibrate my M240 for the 3 years I have been using it. 1 Quote Link to post Share on other sites More sharing options...
Eesand Posted November 10, 2018 Share #71 Posted November 10, 2018 1 hour ago, kikouyou said: My M10P arrived brand new mis calibrated (it was good but not perfect) on the focus, thanks to this (I would not say easy) adjustment I got it spot on now without returning the camera. Thanks god the other calibrations of the patch were perfect, they are much more difficult to achieve (infinity, vertical, horizontal) .There is a detailed explanation on this forum with graphics and pictures on how to do this. I have now the 2mm Allen key always in my photo bag just in case... Also I never had to recalibrate my M240 for the 3 years I have been using it. thanks. I have a well used m10 still under warranty which I sent in, it also was off a bit, nowhere near as much as the m10-p. The m240 which is even more well used is spot on perfect. Wonder whether manufacturing process on the 10's is a bit lax, or whether there is some other issue. Of course, this sample size is small. Quote Link to post Share on other sites More sharing options...
geddon_jt Posted November 12, 2018 Share #72 Posted November 12, 2018 This is about a 100% crop. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/285663-noctilux-75125-images/?do=findComment&comment=3629766'>More sharing options...
rsolomon Posted November 15, 2018 Share #73 Posted November 15, 2018 For me, and ofcourse speaking only for myself..... This thread was very helpful, i am very happy owning the 75 crorn. i still consider the cron a top performer and think that if you own the 75 nocti you may still want the cron for various reasons, similar reasons some folks have multiple 50's 1 1 Quote Link to post Share on other sites More sharing options...
TheGodParticle/Hari Posted November 17, 2018 Author Share #74 Posted November 17, 2018 On 11/15/2018 at 11:16 PM, rsolomon said: For me, and ofcourse speaking only for myself..... This thread was very helpful, i am very happy owning the 75 crorn. i still consider the cron a top performer and think that if you own the 75 nocti you may still want the cron for various reasons, similar reasons some folks have multiple 50's Yes, the 75Nocti and the 75Lux and the 75Cron all have a place of their own. Not to overlook the lovely Hector 73 and Summarex 85. Each so different. Quote Link to post Share on other sites More sharing options...
mmradman Posted November 18, 2018 Share #75 Posted November 18, 2018 21 hours ago, TheGodParticle said: Yes, the 75Nocti and the 75Lux and the 75Cron all have a place of their own. Not to overlook the lovely Hector 73 and Summarex 85. Each so different. Hari, would you care to elaborate how you place three fast 75s; f1.25, f1.4 and f2. Quote Link to post Share on other sites More sharing options...
geddon_jt Posted November 23, 2018 Share #76 Posted November 23, 2018 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/285663-noctilux-75125-images/?do=findComment&comment=3635871'>More sharing options...
geddon_jt Posted November 23, 2018 Share #77 Posted November 23, 2018 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/285663-noctilux-75125-images/?do=findComment&comment=3635873'>More sharing options...
jplomley Posted November 24, 2018 Share #78 Posted November 24, 2018 Having just purchased the 75/2.0 APO SL all I can say is this lens represents next level performance for prime lenses. Incredible resolution and bokeh. Sold my 90 APO M to purchase the SL 75, and zero regrets. It's that good. Quote Link to post Share on other sites More sharing options...
jrp Posted November 25, 2018 Share #79 Posted November 25, 2018 I agree; the SL Summicrons are stupendous. They are, obviously, more costly than the comparable M lenses and much more bulky, but they do deliver cleaner images. Quote Link to post Share on other sites More sharing options...
Eesand Posted November 26, 2018 Share #80 Posted November 26, 2018 75 wide open Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/285663-noctilux-75125-images/?do=findComment&comment=3637687'>More sharing options...
