camaddaloni Posted March 1, 2018 Share #1 Posted March 1, 2018 Advertisement (gone after registration) Hello- I just got my M4-2 back from a repair service for this light leak/shutter issue - a band across the top. I got my first roll back, and 95% of the frames didn't have it - but the last few frames did. None of the frames with my 35mm Summicron had it, only the last few with a 50mm Canon 1.4 LTM with an adapter. Is there any chance this is a lens/adapter issue, or is the shutter still the culprit? Band happend when shot into the direct sun at 1000th, sun behind be at 100th; and also in muted indoor light around 250th. Cheers Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/282307-light-leak-flare-or-shutter-m4-2/?do=findComment&comment=3471672'>More sharing options...
Advertisement Posted March 1, 2018 Posted March 1, 2018 Hi camaddaloni, Take a look here Light leak? Flare or shutter? (M4-2). I'm sure you'll find what you were looking for!
Pyrogallol Posted March 1, 2018 Share #2 Posted March 1, 2018 Is it on the negatives, does it show in the spaces between the negatives? Or on prints or scans? I am wondering if it is something to do with the processing of the film rather than the mechanics of the camera. With a horizontally travelling shutter you would not expect to see a band like this. Something that has happened outside of the camera? Link to post Share on other sites More sharing options...
maximilianm3 Posted March 1, 2018 Share #3 Posted March 1, 2018 I have the same problem. It only surfaces when i change lenses in broad daylight. Link to post Share on other sites More sharing options...
normclarke Posted March 2, 2018 Share #4 Posted March 2, 2018 It is a problem with the light trap, easy to fix but send it to someone who has the knowledge. Best normclarke. Link to post Share on other sites More sharing options...
Pyrogallol Posted March 4, 2018 Share #5 Posted March 4, 2018 I thought it was something to do with film processing, but seems I was wrong. I thought the problems of light leaking round the shutter housing had been solved in the 1930’s, I had a similar problem once changing lenses on an early 30’s model II, but not on later screw cameras which I understand have improved baffles. Link to post Share on other sites More sharing options...
earleygallery Posted March 4, 2018 Share #6 Posted March 4, 2018 I'm pretty sure this is due to slightly slack shutter curtains, allowing light to seep under and fogging the film. A CLA should resolve it. The other possibility is a light leak via the viewfinder but they tend to appear as streaks of fogging vertically rather than the horizontal band shown. They're also generally much harder to fix! Link to post Share on other sites More sharing options...
