Les Posted October 10, 2017 Share #1 Â Posted October 10, 2017 Advertisement (gone after registration) I have just received my new SL and I want to be sure about the slots for the storage media. This is my first post here so I apologize if I am not using the correct procedure. On page 171: changing the memory cards: Slot 1 (top) operates according to UHS II standards, slot 2 according to UHS I. Â On p294 the technical data states: SD, SDHC, SDXC cards both UHS I (slots 1 and 2) UHS II (slot 2) Â Can someone please tell me which is correct. Also, if there is a discrepancy, Leica should be notified. Â Is there a US contact for customer service or technical issues. Link to post Share on other sites More sharing options...
Advertisement Posted October 10, 2017 Posted October 10, 2017 Hi Les, Take a look here SL - card slot for UHS II ?. I'm sure you'll find what you were looking for!
LocalHero1953 Posted October 10, 2017 Share #2 Â Posted October 10, 2017 TBH I never noticed or thought about it. I just got the higher quality SD cards for both, so I don't have to think about which card goes in which slot. I agree it looks like the manual is mixed up (not for the first time with Leica manuals). Link to post Share on other sites More sharing options...
amoebahydra Posted October 10, 2017 Share #3 Â Posted October 10, 2017 Slot I is UHS II compatible ............ Link to post Share on other sites More sharing options...
Les Posted October 10, 2017 Author Share #4 Â Posted October 10, 2017 Thank you for the help. Â Les Link to post Share on other sites More sharing options...
Irakly Shanidze Posted October 11, 2017 Share #5 Â Posted October 11, 2017 I tested this yesterday. SL writes 4K video to a Lexar Pro UHS-II card installed in the upper slot without dropping frames. Link to post Share on other sites More sharing options...
caissa Posted October 11, 2017 Share #6 Â Posted October 11, 2017 Slot 1 (upper slot) is of type UHS II. (Try to have a look from the side - you can maybe see the additional contacts). But both slots are compatible with UHS II - meaning UHS II cards can be used in both slots, but not with the same speed. Â If you do not do 4k video, you probably won't notice a difference. Â Â Link to post Share on other sites More sharing options...
scott kirkpatrick Posted October 11, 2017 Share #7  Posted October 11, 2017 Advertisement (gone after registration) Although the book says you can only write video to slot#1, I've shot with card #1 full (or missing) and found as a result the video file on card #2. Everything looked OK. Link to post Share on other sites More sharing options...
Irakly Shanidze Posted October 12, 2017 Share #8  Posted October 12, 2017 Although the book says you can only write video to slot#1, I've shot with card #1 full (or missing) and found as a result the video file on card #2. Everything looked OK.  If you record in MP4, lower slot is fine. Link to post Share on other sites More sharing options...
