stephengv Posted July 6, 2017 Author Share #41  Posted July 6, 2017 Advertisement (gone after registration) There could be issues where it doesn't reach infinity focus at infinity lock wide open. This is easily checked using LV. My lens had no issue on M9 but has issue on M240. This is lens specific though and not a general issue (and easily fixed by Leica, DAG or someone else).   I'm not quite sure if I have the same problem. One time, I was focusing an object, which appears to be more than 55 meters, hence I focus on infinity. However, upon checking live view, the image was not in focus. I did this at F/4.Nevertheless, when I focus on another object, which is farther, I again focus on infinity, the focus was correct. Link to post Share on other sites More sharing options...
Advertisement Posted July 6, 2017 Posted July 6, 2017 Hi stephengv, Take a look here 135 Elmar, worth it?. I'm sure you'll find what you were looking for!
fotomas Posted July 6, 2017 Share #42  Posted July 6, 2017 Her one taken with the Elmar 2,8/135 with googles. Wide open on the M 240. f 2,8 or 3,4.Focussed wit EVF. Not a pleasure to do, but possible. Unfortunately it's mechanically a bit misaligned, so I can't use the OVF.  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 6 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/271885-135-elmar-worth-it/?do=findComment&comment=3309876'>More sharing options...
stephengv Posted July 6, 2017 Author Share #43 Â Posted July 6, 2017 Nice shot! Â Her one taken with the Elmar 2,8/135 with googles. Wide open on the M 240. f 2,8 or 3,4.Focussed wit EVF. Not a pleasure to do, but possible. Unfortunately it's mechanically a bit misaligned, so I can't use the OVF. Â 16-09-09, 17-39 3.jpg 1 Link to post Share on other sites More sharing options...
Michael Geschlecht Posted July 6, 2017 Share #44 Â Posted July 6, 2017 (edited) Hello Stephen, Â Welcome to the Forum. Â 55 meters is not "Infinity" for a 135mm lens. It is better to actually focus using the range/viewfinder at that & even when you are measuring longer distances. To check "Infinity" focus it is better to use something like the Moon with the camera & lens on a tripod. The F4, 135mm Elmar conveniently has a tripod mount in the lens which will add to stability. Â You might try it at all of the F stops & appropriate adjusted shutter speeds since you will be using a tripod. Â Just make a normal exposure reading from the surface of the Moon. Â Best Regards, Â Michael Edited July 6, 2017 by Michael Geschlecht 1 Link to post Share on other sites More sharing options...
jmahto Posted July 6, 2017 Share #45  Posted July 6, 2017 I'm not quite sure if I have the same problem. One time, I was focusing an object, which appears to be more than 55 meters, hence I focus on infinity. However, upon checking live view, the image was not in focus. I did this at F/4.Nevertheless, when I focus on another object, which is farther, I again focus on infinity, the focus was correct. Focusing is always an issue with longer lens. The RF patch is too imprecise for infinity at f/4 (even 90mm gives problem if you are not careful). My rule is always to use LV/EVF with long lens for any photo that I may plan to print big someday. If not, then the slight mis focus doesn't matter on the web or even up to A4 prints. Just to be extra careful, I stop down to f/8 in the day light and let auto ISO cover the rest. I also shoot in C mode so that I can use minimum 1/focal length shutterspeed and pick the most stable shot later during curation.  I have learned that long lens require extra care to get the most out of them. Link to post Share on other sites More sharing options...
stephengv Posted July 7, 2017 Author Share #46  Posted July 7, 2017 (edited) Focusing is always an issue with longer lens. The RF patch is too imprecise for infinity at f/4 (even 90mm gives problem if you are not careful). My rule is always to use LV/EVF with long lens for any photo that I may plan to print big someday. If not, then the slight mis focus doesn't matter on the web or even up to A4 prints. Just to be extra careful, I stop down to f/8 in the day light and let auto ISO cover the rest. I also shoot in C mode so that I can use minimum 1/focal length shutterspeed and pick the most stable shot later during curation.  I have learned that long lens require extra care to get the most out of them.   Thank you. I will heed your advice. I just hope that stopping down to F/5.6 is sufficient enough for an accurate focus for big prints, since F/8 is slow haha. Edited July 7, 2017 by stephengv Link to post Share on other sites More sharing options...
amoebahydra Posted July 9, 2017 Share #47  Posted July 9, 2017 (edited) Advertisement (gone after registration) For longer focal length lenses, it is better to use 0.85X magnification cameras (with 0.85 marked on the lower right corner at front of the viewfinder) or using goggle lenses as focusing will be more accurate ..............  Please also note that M3 is a 0.91X magnification camera, while M6J is also a 0.85X camera Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited July 9, 2017 by amoebahydra 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/271885-135-elmar-worth-it/?do=findComment&comment=3311667'>More sharing options...
stephengv Posted July 9, 2017 Author Share #48  Posted July 9, 2017 For longer focal length lenses, it is better to use 0.85X magnification cameras (with 0.85 marked on the lower right corner at front of the viewfinder) or using goggle lenses as focusing will be more accurate ..............  Please also note that M3 is a 0.91X magnification camera, while M6J is also a 0.85X camera   Thank you! My only film Leica is a M6 TTL with 0.85. But, I haven't tried the Elmar on my M6. I will try it soon. Thanks again! Link to post Share on other sites More sharing options...
stephengv Posted September 9, 2017 Author Share #49  Posted September 9, 2017 Another test with Lee Seven5 filters:   Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 8 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/271885-135-elmar-worth-it/?do=findComment&comment=3355321'>More sharing options...
stephengv Posted September 9, 2017 Author Share #50  Posted September 9, 2017 One more:   Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 6 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/271885-135-elmar-worth-it/?do=findComment&comment=3355323'>More sharing options...
Adrian Lord Posted January 1, 2018 Share #51  Posted January 1, 2018 Cropped. 135 Elmar M9 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 4 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/271885-135-elmar-worth-it/?do=findComment&comment=3429960'>More sharing options...
ropo54 Posted January 1, 2018 Share #52  Posted January 1, 2018 (edited) A few more taken with the SL 601 w 135 f4 elmar Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited January 1, 2018 by ropo54 4 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/271885-135-elmar-worth-it/?do=findComment&comment=3430128'>More sharing options...
stephengv Posted January 1, 2018 Author Share #53 Â Posted January 1, 2018 Any idea why this lens is so sharp despite its age? Link to post Share on other sites More sharing options...
ropo54 Posted January 1, 2018 Share #54 Â Posted January 1, 2018 Any idea why this lens is so sharp despite its age? Â I would have no idea! Â But, I really enjoy the lens and the pricing for it is so ridiculously good. 1 Link to post Share on other sites More sharing options...
wda Posted January 1, 2018 Share #55 Â Posted January 1, 2018 The 135mm F.4 Elmar, in good conditions, is one of the best value Leica lenses available today. Most samples have seen light use; hence the survivala condition. 2 Link to post Share on other sites More sharing options...
ropo54 Posted January 2, 2018 Share #56  Posted January 2, 2018 CL w 135 f/4 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 11 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/271885-135-elmar-worth-it/?do=findComment&comment=3430563'>More sharing options...
stephengv Posted April 8, 2018 Author Share #57  Posted April 8, 2018 Playing with it the other night:   Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 7 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/271885-135-elmar-worth-it/?do=findComment&comment=3496102'>More sharing options...
tsleica Posted April 8, 2018 Share #58 Â Posted April 8, 2018 (edited) 1961 ver w/lanthanum glass..shot wide open.. Edited April 8, 2018 by tsleica 6 Link to post Share on other sites More sharing options...
stephengv Posted November 7, 2018 Author Share #59  Posted November 7, 2018 (edited) Some shot with a Lee Big Stopper and Grad ND: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited November 7, 2018 by stephengv 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/271885-135-elmar-worth-it/?do=findComment&comment=3627175'>More sharing options...
lct Posted November 7, 2018 Share #60  Posted November 7, 2018 Elmar 135/4 on Epson R-D1 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 19 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/271885-135-elmar-worth-it/?do=findComment&comment=3627259'>More sharing options...
