My 240 is too fat ... it needs to go on a diet
  • Replies 54
  • Created
  • Last Reply
if you look at the top view of the M240 vs the M9, and the specs of both, the thickness increase of the M240 matches the thickness of the little thumb scallop near the dial, that the M9 doesn't have.
if you are referring to the thickness difference between the Film M bodies and the Digitals - that comes down to lens flange distance.
for the RF to work properly (and the lenses to focus to infinity) the lens mount has to be 27.8mm from the film plane.
on a film body (M3 - 33.5mm thick according to wikipedia) the film/pressure plate/back/iso reminder dial is 5.7mm thick (27.8mm from lens mount to film plane, plus 5.7mm for 33.5 total thickness)
a digital M by comparison has a bit more going on.
Sensor, sensor heatsink, mounting mechanism for sensor , LCD and LCD mounting mechanism.
according to wikipedia, the M9 is 37mm thick, so the sensor, LCD and the actual body that holds it all in place, is 9.2mm thick.
From experience with repairing digital cameras (not leicas) the sensor would be around 3mm thick, and the LCD a similar thickness - leaving a few mm for the metal to support it all.
and the framelines need illuminating somehow, if its not LED then it will be the old style window on the front....
Too fat indeed. Bottom plates are like trouser belts, they cannot lie :D. Now i prefer illuminated framelines by far. I'm lucky enough to have used M3, M4, M4-2 and M6J bodies and for me the M240's RF would be the best if it were not waisted by the 50+75 pair of framelines i've always hated since the M4-P. Give me electronic framelines Mr Leica please such as i can have at last a clean 50mm VF as i used to since the seventies. (for newbies only ;): none of the cameras quoted above has 75mm framelines, except M4-P and M240).
I'm amazed that so many people moan about the size of the M, and then promptly put a dirty great leather half-case on it!I
Size -  I blame the case/cover, and my bulky leather jacket. I am so glad to have them :)
I wonder if the next generation of screens which seem to be considerably thinner e.g. iPhone 6 could allow the next M to get a bit thinner. The heat sink might be another opportunity for increased thinness using some of the tricks used by the cell phone builders.
I'm not ready to go the M-D route (I'm not a good enough photographer) but I'm kind of warming to the idea. A EVF for macro mode and ultrawides or when things get weird and I need to review my exposure between decisive moments (e.g. Fire spinning https://goo.gl/photos/D8LDU8PXTXnjpAsWA ) and WiFi with an App like the one for the T to review my shots before downloading them and then I think I'd be good and could be happy without a screen especially if it meant a thinner lighter more rugged camera. That might be the way to go.
Any idea where the 27.8 came from? Why not a round number?
Buy an SL...it's slimmer...and stick your M lenses on it.  Smaller in feel?  I bet not.  Better yet, put the 24-90 on it for a while, then pick up your seemingly fat M.
It's not really about the depth.
Jeff
It is so much easier to hold with half case then holding that cold brick without one.
@AndrewDD you really made me smile.
Likewise my Leica amazement does not cease ...
I wonder how one could shoot all those years without additional handles or thumb grips.
Mark when shooting film M cameras did you possibly ever have your thumb at the ready on the tip of the film advance?  :D  Now your thumb has somewhere to rest on the M digital bodies instead, that tiny 2mm extension housing the thumb wheel at a more ergonomic operating position. At least my thumb was lost at first.
Don't blame Leica Camera for any optional third party Thumbs Up or other accessories though.
As far as a slimmer battery, I would be surprised if the illuminated framelines contribute much to the capacity needed. Much more the Liveview functionality I think. The battery for the M (Typ 240) is effectively two of the previous cells in one housing. I guess in theory you could make a case for a smaller battery for the M (Typ 262) but then you would have a logistical issue of different batteries for different current M's?
Personally I adapted quickly to the very slight additional body depth from the M8 forward. However the additional weight of the M (Typ 240) battery is more noticeable to me after the M9. If using the optional Multi Function Grip the bulk when carrying is more significant for me too.
Out of interest the S (Typ 007) necessitated a higher capacity battery (than for previous models) too albeit with same case dimensions. It's quite a bit taller than that for the M though. I'm guessing that customers wouldn't be pleased if the M body was 20mm taller to use that design!
And some of those same M fans are now also using an SL, which is 24mm taller....and providing descriptions like "not much different than the M".  Funny how perspective changes....often with the next new thing.
Jeff
