  • 2 years later...
Of course you have to switch to advanced metering first; just selecting spot or multi-field won’t do. With advanced metering enabled (Light Metering Mode = Advanced) you can use those advanced metering options even without live view. See page 180 of the manual where this is explained. ‘Exposure metering’ selects the metering method to be used in advanced mode but you need to switch to ‘Advanced’ in the ‘Light Metering Mode’ menu to activate the selected method. When using live view this isn’t necessary but if you want to use the advanced metering options outside live view it is.
This provided link (Jun 2015) was released before M10, something may be explained in M10 case.
Sorry post in wrong thread .
The answer must be for M10 not in this section of earlier M .
Edited by a.noctilux
I go with Classic on the main Menu, then Spot on the Set menu
Super fast & accurate.
After you've decided on shutter speed and approximate aperture, capturing an area that will give you what you want by holding down the shutter release 1/2 way
Then compose, focus & shoot
In daylight I capture a 7 out of 10(brightest) to not blow out highlights.  And the opposite for night to preserve shadow details
If unsure, shoot a bunch lighter & darker to increase your chances of success:  "Bracketing for exposure" can be done with either shutter speed or aperture.  Whatever effect you want is user preference.  There's no right & wrong - just your intent and that the capture will hold up in a big print and be interesting!
