M 240 focussing
  • Replies 55
  • Created
  • Last Reply
... or one's eyes are still wide after receiving one's shiny, new M240.
Pete.:p
hardly...Ive had my M for 4 months and there is a clear difference. This is not a placebo, in one of the interviews with Stefan Daniels he mentions it as well.
I also see it with my M9 and if nothing has changed in an optical way, how can you have the impressing it's more precise while focusing?
Did you watch the interview above? Stefan Daniel said the structure of the rangefinder from the M9 was used in the M..."but also improved"
If you have used the M9, then try the M and you will see that is it easier to get accurate focus quickly. How? I have no idea, all I can say is that the difference is apparent immediately upon using the M.
Because there is less flare in the viewfinder due to the lack of external window so the focus patch is more contrasty.
The focussing action is more precise than the M9. All M owners that commented on the forum found the rangefinder more precise, Leica told us the manufacturing tolerance has increased for greater precision and easier focussing. I must confess that I am a bit lost as to what your are trying to say. Everybody who uses the M is wrong and those that haven't used it are right?
I'm not quite sure about that as it would depend on the light falling on the original focus patch. It is more constant, that is for sure.
I'm not trying to say anything, I'm just raising a question. And as it seems everybody else seems to have understood my question.
To put my question in other words: I'm just wondering what the perceivable (optical) changes among focusing with an M240 and an M9 are. What is the thing that makes focusing easier and more precise? ICT tried to explain. I can't judge if he's right.
Jaap
As i started this thread i have the perfect solution to end it -- you can supply me your m240 on a permanent "loan basis " and i will give feedback on the focus every week up until the new m260 arrives . :D now everybody's happy:)
Regards from South-Africa
Walter
I should explain: my comment was intended as an amuse-bouche not a pop at the M240's viewfinder. MY M240's viewfinder shows similar improvement.
Pete.
Who can judge if he is right? Thats the point, nobody but Leica knows for sure and they haven't revealed any details.
... Leica told us the manufacturing tolerance has increased for greater precision and easier focusing. ...
I am sorry if I missed that somewhere. Where did Leica say they improved the tolerances in the rangefinder?
When I picked my M240 up at my dealer's not-so-well lit store and looked through the viewfinder, it was instantly apparent that the VF was much brighter and the framelines + focus patch were more crisp than M9... I posted such a thread months ago, actually.
So back to Walter's question, why is he getting more M240 related orders if the M240 is, in fact, easier to focus than the M9? Perhaps one component in this correlation between M240 roll out and increased sales of the new Walter eyepiece might be LF forum traffic during this period. Is there a way to find out if Forum clicks/viewing has increased since March 1. 2013?
BTW, I have Walter eyepieces on both my M240 and MM. Because of mild/medium astigmatism in left shooting eye, I would need to shoot everything at f/8 without these excellent eyepieces :D
I said it a few times before - the mechanical tolerances in the focussing mechanism are tighter. It turns out that that makes a considerable difference. There are no optical changes,except that the brightness of the framelines/rangefinder patch is more controlled.
Stefan Daniel talks about the M rangefinder in the interview with Thorsten on this page (at about 10:46), where he says that although the structure was taken from the M9, the accuracy was improved.
Jeff
Jaap
Walter
You can play with it if you want, I'll be in Mozambique and Malawi in October. ;)
Jaap
I will be waiting for you and the M at the airport.:D..on another note..I would like to take this opportunity to thank all the Leica forum experts and you in particular for the unselfish advice you have given us youngsters over the years.:cool:
