wlaidlaw Posted December 2, 2013 Share #81 Posted December 2, 2013 Advertisement (gone after registration) If you look on the lens codes section of the Wiki on this forum, you will find recommendations for most compatible non-Leica lenses. This is not a hard and fast rule and you may find other codes will suit better for the colour balance you like or another reason. For example I am coding my 40mm Summicron-C as a series 3 50 Summicron not the pre-ASPH 35 Summicron as recommended. This is because I would have to alter the framelines tab to 35mm, which I don’t want to do. I find it easier to look outside the 50mm framelines than inside the 35mm ones. Wilson 2 Link to post Share on other sites More sharing options...
Advertisement Posted December 2, 2013 Posted December 2, 2013 Hi wlaidlaw, Take a look here M lens codes . I'm sure you'll find what you were looking for!
billo101 Posted May 21, 2014 Share #82 Posted May 21, 2014 I bought a 85 Summarex, I have a Monochrom, which encoding (101...) should I put on the 28/90 VM ring? Thanks in advance. b Link to post Share on other sites More sharing options...
wlaidlaw Posted May 21, 2014 Share #83 Posted May 21, 2014 I would try the old Summicron-M 90 type II which is 000111. I should not think there is much if any correction on this but at least you would get 90mm/f2 shown on the EXIF, to give you a clue as to which lens you used. Wilson Link to post Share on other sites More sharing options...
evering Posted May 30, 2014 Share #84 Posted May 30, 2014 Hi, I have M240 and was wondering if anyone knows the code for the 35 / 1.4 Summilux pre-APSH. It is an '86 model. The code doesn't appear in any of the tables? thanks Link to post Share on other sites More sharing options...
adan Posted May 30, 2014 Share #85 Posted May 30, 2014 There is no "code" for that lens - Leica left it off the list going back to the origination of the codes for the M8. Only option is selecting it in the menu, or substituting the code for a more modern 35 f/2 or f/1.4. The reason being that that lens uses a different mounting flange than all other M lenses since 1980 - grandfathered in from the 1960's. Thicker, and with no screws on the back. Leica did not go to the trouble of reviving that unique mount for one lens, when creating the new mounts with the coding pits in them. I did see a 35 pre-ASPH Summilux very recently, where the photographer had had one of the third-party repair people drill pits into his 40-year-old mount, and paint in the code for the ASPH 35 Summilux. Link to post Share on other sites More sharing options...
wlaidlaw Posted May 30, 2014 Share #86 Posted May 30, 2014 Hi, I have M240 and was wondering if anyone knows the code for the 35 / 1.4 Summilux pre-APSH. It is an '86 model. The code doesn't appear in any of the tables? thanks I would just code as ASPH. Wilson Link to post Share on other sites More sharing options...
01af Posted May 30, 2014 Share #87 Posted May 30, 2014 Advertisement (gone after registration) ... wondering if anyone knows the code for the pre-asph Summilux-M 35 mm. It is an '86 model. The code is 6-0. However you cannot use this as the 6-bit code on the bayonet flange ... or actually you can but the camera will interpret it as 6-2 which is the Summicron-M 35 mm. Link to post Share on other sites More sharing options...
evering Posted May 30, 2014 Share #88 Posted May 30, 2014 The code is 6-0. However you cannot use this as the 6-bit code on the bayonet flange ... or actually you can but the camera will interpret it as 6-2 which is the Summicron-M 35 mm. Sorry but I do not follow. Are you saying that I can not code that lens? Link to post Share on other sites More sharing options...
01af Posted May 30, 2014 Share #89 Posted May 30, 2014 Are you saying that I can not code that lens? You cannot code it as "Summilux-M 35 mm." You can code it as some other lens. Most owners of this lens choose the code 29-2 which means, "Summilux-M 35 mm Asph." 1 Link to post Share on other sites More sharing options...
JohnJWhite Posted June 2, 2014 Share #90 Posted June 2, 2014 Just received the Match Technical coding kit. Worked perfectly with my 1970 50mm Summicron and the 21mm Elmarit M. But the Tri-Elmar, 28-35-50, first version, gave the M 240 fits. The camera couldn't decide if there's a lens mounted or not. The lens worked fine on my M4 and M6, as well as the M8 and M240 before marking the mount with the code. So I scratched my head and stared at it for a while. Then, I got out the pen they supply and really laid on the ink, several layers. Now it works perfectly. Link to post Share on other sites More sharing options...
james.liam Posted July 10, 2014 Share #91 Posted July 10, 2014 What codes work best for the ZM 2,8/35? Link to post Share on other sites More sharing options...
wlaidlaw Posted July 10, 2014 Share #92 Posted July 10, 2014 I would probably opt for the 35 Summarit. 101011. Both fairly straightforward modern lenses without fancy elements. Would not be a long way out I would guess. Wilson Link to post Share on other sites More sharing options...
lct Posted July 10, 2014 Share #93 Posted July 10, 2014 My ZM 35/2.8 is coded as a Summarit 35/2.5 as well. Link to post Share on other sites More sharing options...
Alberti Posted October 7, 2014 Share #94 Posted October 7, 2014 I have been trying to recode my Heliar 15 mm. I had 010000, that gave the tri-elmar on the M8. On the M-P it was not recognized anymore. The EXIF was empty. Big purple edges are the result. Using the manual selection the code 28f2.8 asph 11606 seems to work best regarding color: least but not totally absent color fringe. Looking at Flickr photo's many of the posters with the lens have chosen this code. So I decided to go for 011100 I went ahead with coding the recesses (with black pieces of paper). I tried 011010 (2/28) and to my surprise it gives 4/16. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! I tried 011100 and this gives 4/16 and reverting to the original code: 010000 NOW ALSO shows 4/16. So to recap: three codes give 4/16. Initially the Heliar returned an empty string for the lens, after fooling around my camera sort of got the hint there is a 4/16 and sticks to that, I did have the selection on auto And that 4/16 code it still has a purple edge. It's the tri-elmar as C1's EXIF tells me. How does the M know I am trying to trick it? I do not expect artificial intelligence in the machine! And I definitely like the 2/28 best for handling. I have the lens selection on automatic. I'm clueless. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! I tried 011100 and this gives 4/16 and reverting to the original code: 010000 NOW ALSO shows 4/16. So to recap: three codes give 4/16. Initially the Heliar returned an empty string for the lens, after fooling around my camera sort of got the hint there is a 4/16 and sticks to that, I did have the selection on auto And that 4/16 code it still has a purple edge. It's the tri-elmar as C1's EXIF tells me. How does the M know I am trying to trick it? I do not expect artificial intelligence in the machine! And I definitely like the 2/28 best for handling. I have the lens selection on automatic. I'm clueless. ' data-webShareUrl='https://www.l-camera-forum.com/topic/185433-m-lens-codes/?do=findComment&comment=2685031'>More sharing options...
Alberti Posted October 8, 2014 Share #95 Posted October 8, 2014 I solved it. I used black pieces of paper that I cut for the recesses, but the IR code reader does not see it as real black. I took a Sharpie and made the black cardboard paper really black: now with 011100 is recognized as a 2.8/28A and corrected in the right way. Link to post Share on other sites More sharing options...
01af Posted October 14, 2014 Share #96 Posted October 14, 2014 And with that 16/4 code it still has a purple edge. Yes, sure it has, as the Tri-Elmar-M 16-18-21 mm Asph is a retrofocus lens and your Heliar 15 mm 1:4.5 is not. So it's the worst code to pick. Do not use the Tri-Elmar's code for any 3rd-party super-wide-angle lenses! The best should be the Elmarit-M 21 mm's (non-Asph, code 000001). Those for 28 mm lenses should work well, too. 1 Link to post Share on other sites More sharing options...
jmahto Posted June 8, 2015 Share #97 Posted June 8, 2015 If you look on the lens codes section of the Wiki on this forum, you will find recommendations for most compatible non-Leica lenses. This is not a hard and fast rule and you may find other codes will suit better for the colour balance you like or another reason. For example I am coding my 40mm Summicron-C as a series 3 50 Summicron not the pre-ASPH 35 Summicron as recommended. This is because I would have to alter the framelines tab to 35mm, which I don’t want to do. I find it easier to look outside the 50mm framelines than inside the 35mm ones. Wilson I found that 40mm summicron-c was the most difficult to code since there is a screw where code is supposed to be but I finally succeeded after long trial and error. I thought I will share. First I shaved off the leading part of left tab (see pic. You can see the freshly ground tab). It was very easy with a dremel tool and I had to take off less than 1mm. Make sure to cover the rest of the lens carefully to protect from the flying metal dust. I simply took some paper and taped it all over leaving only the tab. It was very easy. Then I blackened the screw with black paint fully (I used paint pen by CraftSmart) and then added a sharpie mark on the side. This makes it 000110 (pre-ASPH 35 Summicron). In my previous attempts the sharpie mark was too close to the screw. Going forward I will drill a hole for the sharpie mark if it wears off. Look at the picture. Don't give up. If you mess up sharpie mark then simply wipe it off and try again Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/185433-m-lens-codes/?do=findComment&comment=2830537'>More sharing options...
Erik Gunst Lund Posted June 27, 2015 Share #98 Posted June 27, 2015 The new Leica M 75mm f/2.4 Summarit is coded 010011 75mm rangefinder framelines Link to post Share on other sites More sharing options...
Erik Gunst Lund Posted June 28, 2015 Share #99 Posted June 28, 2015 Here a shot of the mount, The firmware of my old Leica M9 does not recognize the code off course... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/185433-m-lens-codes/?do=findComment&comment=2843713'>More sharing options...
ramarren Posted July 2, 2015 Share #100 Posted July 2, 2015 I tried several different codes with the Summilux 35 v2 on the M-P and decided that no code worked best. I created a user config that turns off the lens codes for when I use that lens. Link to post Share on other sites More sharing options...
