Lens not in use set to smallest aperture?
PBeter
Another photographer alerted me to the following that I never heard of:
Is it recommended to, as a lens for a long time is not in use, the aperturering completely turned down, to the smallest aperture.
Or is this not matter?
A new one on me. However, if I retained control, that is not locked away in store somewhere, I would probably exercise the aperture and focus controls, from time to time, to keep lubricated parts refreshed.
I’ve never heard it would matter and I wouldn’t know why it possibly might.
Using my imagination - maybe it will put some less strain on the little springs that are incorporated in the return mechanism - of an SLR lens.!.
Even if that were the case - it would be be news to me- it would not be applicable to an M lens.
I suppose if grease is going to break down, get oily, and migrate along the aperture blades it will most likely happen if the lens is wide open with the blades bunched together, and less likely if stopped down and the blades spread out? Just an idea. Can't say I have ever bothered because if the grease has broken down with age it will spread just as quickly as soon as you use the lens.
Steve
I think that we need a sticky about things to worry about when everything is working perfectly:eek:.
I'll start a list!
Fungus
Depreciation (if a new model comes out)
Shutter cocked or uncocked
Aperture open or closed
Financial stability of Leica's suppliers (sensors, batteries etc)
Will my sensor crack?
Availability of film
(that's enough, Ed)
I have heard this, some time ago about old lenses. But can't remember if it was to leave it open or stopped down. I did it with my speed graphic lenses for a time, until I feared of being OCD. :D Lenses still work fine.
If this all works as with carbon-based image capture devices, then we should close the iris at night and open when the alarm goes off.
:D
But........
That lens and camera body is fluid filled and has no aperture blades.
Malcolm Taylor told me after cleaning my Elmar 2.8/50 that its best to leave it at full aperture when not in use, the diaphragm is close to the front element and the lubricant is known to etch the glass over time. Same goes for the Elmarit 90/2.8
Gerry
I would have thought that, if it mattered significantly, then Leica would have given appropriate advice in their lens booklets. Certainly, with my R lenses, there is no such adivce. I keep my R lenses stored set at minimum aperture, but only so they are ready immediately on mounting for full available range in T or P mode.
