75mm Summarit and hoods
IWC Doppel
Doppel, mine lives permanently attached so is always available. If you want a smaller package for a long journey, you can reverse the hood over the lens. As to need, it provides extra protection against stray fingers and light and makes for improved handling. I cradle the underside of the hood in my left hand. Thoroughly recommended.
Yes let alone with IR-cut filters on. I have no experience with the Summarit 75 but it uses E46 filters does not it? If so why not trying a cheap 3rd party hood to see if you can stand this kind of beast? I don't like much screw-in metal hoods personally but the original hood of the Summarit is a screw-in one as well if memory serves so why not give it a try? See for instance: Metal 46mm Screw-in Lens Hood + Cap E46.
+1
One real difference with the original hood and the heavystars one is that the original screws onto a thread on the outside of the mount, not the 46mm filter thread.
Carl
With my Summarit 90 I no longer use the hood originally purchased with the lens. I have a B+W clear filter permanently attached for protection, and in a few hundred shots used without the hood I've never had an incidence of flare. The reason I have abandoned the hood is the extra 2 inches or so really bothered me when lens was attached, but if you don't mind the lens being longer than no reason not to use hood...
...I have a B+W clear filter permanently attached for protection, and in a few hundred shots used without the hood I've never had an incidence of flare...
You are a lucky man then. There is something worse though: using two filters w/o hood. :D
Hello Everybody,
The primary purpose of a rigid lens hood is to protect a lens from inadvertant impact &/or damage. Flare suppression is secondary.
It is a lot easier to replace a hood than it is to repair a lens barrel or replace an optical element.
Life happens. Sometimes unexpectedly.
Best Regards,
Michael
...The primary purpose of a rigid lens hood is to protect a lens from inadvertant impact &/or damage. Flare suppression is secondary...
Most Leica built-in hoods are useless then. Not that they are that useful to prevent flare to be honest.
No, the summarit line generally doesn't suffer from flare. I've considered many times getting a hood for my 75mm version but don't for the reasons mentioned above. I shoot B&W and use a variety of filters. I would find the screwing in and out of the hood to be a pain. Plus the additional extra length would turn the lens into a long rigid ergonomical headache. I think a clip-on hood solution would be ideal for me but there is no such product as I know.
(By the way, I generally prefer to use hoods on my lenses).
But does it suffer from flare, under normal shooting conditions?
(Later: My question related to post #15 and the Summllux lens)
If you refer to the Summilux (asph or pre-asph) no but adding a filter does not help as you know.
Hello Again lct,
Better damage/flare protection & ease of use are some of the reasons I like big, long, deep, clip on lens hoods. Some of the clip on's are separable & hold Series Filters like, for example, the 12504. Drop in Series Filters in lens hoods were reasonably common in many R lenses.
Best Regards,
Michael
