bill Posted April 26, 2011 Share #61 Posted April 26, 2011 Advertisement (gone after registration) No. And wishful thinking cannot overturn the laws of physics. Regards, Bill Link to post Share on other sites More sharing options...
Advertisement Posted April 26, 2011 Posted April 26, 2011 Hi bill, Take a look here Leica X2: Rumors and Wishlist . I'm sure you'll find what you were looking for!
Guest stnami Posted April 26, 2011 Share #62 Posted April 26, 2011 Needs an aerial so I can hang my fox tail on it Link to post Share on other sites More sharing options...
Paul Reading Posted May 5, 2011 Share #63 Posted May 5, 2011 Why dos a FF digital camer have to be so much larger then a 35mm film camera? Can't they squeeze the electronics and battery where the film used to go? Or can they, is it just a matter of cost? For me the missing camera, is an X1 with a viewfinder (EVF is fine), with the lens like the one from the Digilux 2 but now 22/24mm-90mm and F1.8. Link to post Share on other sites More sharing options...
barjohn Posted May 5, 2011 Share #64 Posted May 5, 2011 It isn't just the size of the sensor that creates a problem. As anyone that has worked with sensors knows, to minimize noise the sensor must stay cool. The bigger the sensor the more power it takes and the hotter it gets. With a DSLR you have a lot of space to heat sink the sensor and pull the heat away from it and dissipate it through the body. As the body gets smaller, the area for heat dissipation is reduced and the mean temperature goes up. If you have picked up a NEX-5 and used it for a short time you start to notice how warm the body is getting. Link to post Share on other sites More sharing options...
dhsimmonds Posted May 5, 2011 Share #65 Posted May 5, 2011 A 40mm f2.0 and an optical viewfinder would make it a must-have for me. Bill, were you meaning 40mm actual on an asp-c sensor, ie 60mm equivalent full 35mm frame, or 40mm at full frame equiv.? Link to post Share on other sites More sharing options...
hector_jorge Posted May 5, 2011 Share #66 Posted May 5, 2011 If Leica made a proper digital CM, with a lens as good as the CM, and with an optical viewfinder better than the CM (because that was pretty ropey), autofocus at least as good as a CM and with a sensor from an X1, I would buy one tomorrow. I won't buy an X1 tomorrow. Or any tomorrow. I suspect that there are thousands like me who want a proper, compact, quality digital camera that doesn't require a squint and extended arms to use, nor an add-on viewfinder. Cash waiting. +1 Link to post Share on other sites More sharing options...
lykaman Posted May 5, 2011 Share #67 Posted May 5, 2011 Advertisement (gone after registration) Why do you need a built in VF? One of Cartier Bressons Leica’s.. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/147135-leica-x2-rumors-and-wishlist/?do=findComment&comment=1664685'>More sharing options...
lct Posted May 5, 2011 Share #68 Posted May 5, 2011 Does have a built-in VF. Link to post Share on other sites More sharing options...
lykaman Posted May 5, 2011 Share #69 Posted May 5, 2011 The CB’ Leica has an External VF -- NO :cool:built in VF...... Link to post Share on other sites More sharing options...
lct Posted May 5, 2011 Share #70 Posted May 5, 2011 HCB's Leica I. Better view here. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/147135-leica-x2-rumors-and-wishlist/?do=findComment&comment=1664764'>More sharing options...
Ecaton Posted May 6, 2011 Share #71 Posted May 6, 2011 HCB's Leica I. Better view here. and an lcd screen;) Link to post Share on other sites More sharing options...
Nick_S Posted May 6, 2011 Share #72 Posted May 6, 2011 The CB’ Leica has an External VF -- NO :cool:built in VF...... I'd say it has a 'built-on' viewfinder, which is nice and compact. Link to post Share on other sites More sharing options...
adan Posted May 6, 2011 Share #73 Posted May 6, 2011 Attached permanently with screws = "built-in." Sorry! Link to post Share on other sites More sharing options...
lct Posted May 6, 2011 Share #74 Posted May 6, 2011 Thanks Andy, my English is not that bad after all. Link to post Share on other sites More sharing options...
Nick_S Posted May 7, 2011 Share #75 Posted May 7, 2011 Attached permanently with screws = built-in Sorry! = 'screwed on' Perhaps the X2 could have one of these? It looks like the size of the small 28/35 Voigtlander finder some folks are using on the X1 and it would leave the hot shoe free. Nick Link to post Share on other sites More sharing options...
Matus Kalisky Posted May 22, 2011 Share #76 Posted May 22, 2011 I would prefer the X2 to keep the small size of the X1 so no FX sensor. If the lens could be redesigned to get f/2.8 it would be nice, but even f/2.8 is OK. I would like to see better outer finish - I would not mind if the camera would become 50 - 100 g heavier. The dials should give a less plastic feeling and turn less easily. Nice OLED display with higher rate (I know that this is sensor defined). 12 Mpix is just fine - I do not need more. The lens should be threaded and could focus a little bit closer. Faster AF of course and faster response (write times & processing). Maybe separate hot-shoe for EVF or OVF which would display some information. If Leica would ally with Sigma for the X2 (or the X3 ) I would like to see FOveon sensor inside - once they get improved a bit more. Link to post Share on other sites More sharing options...
dhsimmonds Posted May 29, 2011 Share #77 Posted May 29, 2011 Having just read all the posts here, I reckon that Leica would be best advised to purchase a license to brand the X100, just as they do with the Panaleicas, obviously with their own Leica bits and pieces to justify a £2K price tag! Link to post Share on other sites More sharing options...
Paul Reading Posted May 29, 2011 Share #78 Posted May 29, 2011 I don't think the performance of the X100 is up to the standard that Leica would accept. Link to post Share on other sites More sharing options...
davidhunternyc Posted May 29, 2011 Author Share #79 Posted May 29, 2011 Having just read all the posts here, I reckon that Leica would be best advised to purchase a license to brand the X100, just as they do with the Panaleicas, obviously with their own Leica bits and pieces to justify a £2K price tag! Hmm, good idea. Leica did this with Panasonic. Why not Fuji? I can see this now; a re-wrapped Fuji X200 could most feasibly be the new Lecia X2 also. Link to post Share on other sites More sharing options...
lct Posted May 29, 2011 Share #80 Posted May 29, 2011 Leica did this with Fuji already. Was up to their standards then Link to post Share on other sites More sharing options...
