I'll post photos later but I have a question. I have 3 LTM's but I do not have an Elmar 50mm 3.5 and I'm thinking I should get one. I have a 35mm Summaron, 50 Summarit, 50 Summitar and 2 Russian 50mm 3.5 collapsible knockoffs. The russian lenses are ok but not great. I like the 3 Leica lenses a lot, the Summaron is sharp and the 50's are fast and have the dreamy look. should I get an Elmar? how will the shots with it look compared to what I have?
Camera's are IIIa, IIIb and IIIf RD.
Thanks, JIm
Elmars are a challenge and a delight to use; I have two, an ancient 5cm nickel Elmar and a 3.5cm. With the 5cm collapsed, since they appear, to touch at least, almost identical when mounted on my II, they are indirectly responsible for my losing a couple of frames by having not extended the 5cm before use :rolleyes:
The Elmar can be fiddly to use for those with fat fingers and no fingernails but the joy of seeing the results far outweighs the disadvantages. Should you get one? Yes. Condition of the glass is really the only thing that matters. In performance terms they are of course not up the standard of current lenses but that is part of the charm There is, incidentally, a noticable difference in the rendition and particularly the bokeh between the Elmar and its Ukrainian counterpart, with the Elmar being less harsh and contrasty.
Gratuitous photo time:
Regards,
Bill
My thoughts as well. My first ever shot w/ the Elmar was collapsed -OOPS.
They are a delight and I always look forward to using it.
I was an LTM user, then I wasn't, then I was, then I wasn't, then I was, then I wasn't. And all within the last four weeks! Does that count? Is that a winner in the 'Most LTM in a Month Competition'?
That is how hard its been trying to buy an IIIf RDST. The first a private sale and the camera was clearly not in the condition you'd expect for Exc+. The second when a very well known dealer sent a great camera, it just wasn't a IIIf RDST. They were determined to argue the toss and invoke their expertise in Leica's until the serial number and other details caught them out (it was an updated IIIc). The third from another well known Leica expert who accepted with good grace the shutter was sticking.
Maybe I'll refine my search, cross out IIIf RDST, and just go with 'any camera that works and fits its description'......
Steve :(
Steve,
Unless you have to have the slow speeds and the ST, what about a IIF RD. Without the slow speeds, the shutter is simpler and more reliable. My IIF bought new by my father in Brooklyn in 1953, has had only two CLA's in its life and the shutter speeds are pretty much spot on. If you need ST, you can always get an external one like either the Leica, Haka or Hansa ones. Again it is more "schpringenwerk" in the camera body to go wrong. I understood that the IIIG ST was a more reliable mechanism than the IIIF ST but I think they are quite a bit more money, given that there are far fewer of them, since most Leica new camera buyers had changed to M bodies by that time.
Wilson
Yes, another model is what I thinking of now Wilson. I just decided on the IIIf RDST because it was fancy, but if I can get something in better condition and perhaps more reliable as well that would OK.
Steve
  • 2 weeks later...
Finally, I got a IIIf RD that matches its description and works! Having been very unimpressed with the goods offered by very well known dealers I eventually bought #4 through Ebay. I didn't really need the 5cm Elmar that came with it, but both it and the camera are superb, AND the body has had a full service by Malcolm Taylor in January. Body 1954 and lens 1951. Now I just need to find my lens hoods and filters, I know they are in a box somewhere.....
Steve
Thanks, JIm
Personally,I think you don't NEED an Elmar (of course,HAVING one is another matter: it's simply mandatory for one who has 3 LTMs :D) : imho, the reason is the Summarit... me too have one, in VG conditions, and I have always observed (> 15 years of use...) that, globally, it's the 50mm most comparable to the Elmar Red Scale at similar apertures; clearly there is also the form/weight factor and the capability of Elmar to be collapsed... but if I were you... I thought more to an Elmar 90 (easy to find, and cheap even if VG) or to the Summaron 2,8 cm (very fine lens, but a bit costly)
Smart looking example!
Why didn't you need the 5cm 3.5, have you already got one? Just that if you haven't used this lens before, you are in for a real surprise!
The reason I was looking for a body only in the first instance was that I already have a 50mm Summitar, but you are dead right James, the 5cm Elmar has a beautiful character. The first film I put through was a quick test so 400 ISO wasn't ideal for looking at subtle lens qualities, but I put the Elmar on my M9 to have a close look and think I'm going to like it very much. It certainly makes for a compact outfit. Anyway, I'm taking the M adapters off my CV21mm, 35mm Jupiter, and CV75mm so I have a good range to fit in a camera bag.
Steve
Good move.
The CV 75 goes so well on a Barnack:
Regards,
Bill
Hi
2 off IIIc
Leicavit
Summitar + barndoor
Summicron + barndoor
Elmar '49 + FISON
n x FILCA
Lots of CV MC lenses for dull days, FSU, Nicca, and Canon gear, I use LTM 50% of time, an average of 1x 36 frame cassette a day.
Noel
The day before yesterday I bought my third screwmount Leica, it is a III g:
yours sincerely
Thomas
Here are my babies.
IIIf with Summicron
IIIa with Summitar
IIIb with Summaron
At Easter I took this shot of my wife with the IIIb and 50mm Elmar red scale. Kodak Portra 160 with drug store developing.
Sorry for the long post.
Jim
My baby... still trying to get pictures focused though :-)
  • 2 weeks later...
  • 1 month later...
