nabarund Posted November 27, 2009 Share #1 Posted November 27, 2009 Advertisement (gone after registration) hi L-forum, has anybody experienced sudden battery drain on the Digilux-2? I will charge up the battery to full, pop it in the camera, and can take 15 pics or so (JPEG) before the camera tells me that the battery is nearly empty, and then won't turn back on. I replaced the battery and same problem. When I put the battery in the charger, it charges pretty quickly, so I am leaning towards something being funny with the battery sensor and not the battery itself?? I can't imagine that there is an electrical short that would drain the battery so quickly -- the camera doesn't get hot, so where would all that energy go? Has anybody else seen this happen? Any insight? I haven't seen other posts about this problem, but my apologies if it's already been discussed. If so, I would appreciate a point in the right direction. Anybody have any suggestions on a repair shop in NYC that can handle the electricals? thanks L-forum. ndg Link to post Share on other sites More sharing options...
Advertisement Posted November 27, 2009 Posted November 27, 2009 Hi nabarund, Take a look here Digilux-2 power drain/battery sensor problem?. I'm sure you'll find what you were looking for!
Algo Posted November 27, 2009 Share #2 Posted November 27, 2009 Hi, Lithium-ion battery have limited lifetime. (top 2-3 first years but could be 5) Did you try some cross test with a new one ? More on this page Is lithium-ion the ideal battery? How to prolong lithium-based batteries : http://www.batteryuniversity.com/parttwo-34.htm All you ever want to know about your battery, and more ! Cheer Link to post Share on other sites More sharing options...
ajthornbury Posted November 27, 2009 Share #3 Posted November 27, 2009 I had similar problem when my Image sensor failed. Was OK when image sensor was replaced.Could also be the battery reaching end of life, so try new battery first. Link to post Share on other sites More sharing options...
nabarund Posted November 27, 2009 Author Share #4 Posted November 27, 2009 Yes, I tried a new battery and it had the same problem. Sorry that wasn't clear in my original post. So I think it is something internal to the camera. thanks in advance for your help. Link to post Share on other sites More sharing options...
rsolomon Posted November 29, 2009 Share #5 Posted November 29, 2009 sorry to say but it looks like a vist to the leica hospitial ... Link to post Share on other sites More sharing options...
chouhsin Posted November 30, 2009 Share #6 Posted November 30, 2009 If the battery have life limit, will there still be replacements in 10 years? Will we still be enjoying D2 in 2020? Maybe this all end at 2012? Hsin Link to post Share on other sites More sharing options...
carlosecpf Posted December 1, 2009 Share #7 Posted December 1, 2009 Advertisement (gone after registration) I should start stocking up aftermarket batteries right away!! Hopefully by 2012 Leica and/or Panasonic will have something to show that outperforms D2's qualities. Link to post Share on other sites More sharing options...
Algo Posted December 2, 2009 Share #8 Posted December 2, 2009 I should start stocking up aftermarket batteries right away!! Nope Lithium-ion battery have limited lifetime ... in use or not Hopefully, this kind of battery pack is useful for a lot of material. It should be maintain for a long time after ... Link to post Share on other sites More sharing options...
jrethorst Posted December 4, 2009 Share #9 Posted December 4, 2009 Save your batteries even after they stop working. This model battery (and the slightly better but compatible 1700mah battery for the Digilux 3) may not be made forever, but the generic cells they contain may be. Online battery 'shops' can swap out the old cells for new ones in the containers you provide. Link to post Share on other sites More sharing options...
nabarund Posted February 9, 2010 Author Share #10 Posted February 9, 2010 thanks for the comments, everyone. the camera is back from the hospital. some $560 later, they changed the motherboard, gave it a software update, and fixed a little wear and tear on the focus ring. they had to order the motherboard, and it took about 2 weeks to get it back from the time i authorized the service. i love this camera, so the repairs were worth it. still, the repair price tag does smart! the batteries i was using before all work fine now, so it wasn't a power pack issue. so thanks Leica Hospital NJ. i just wish the motherboard had failed while it was still under warranty. ndg Link to post Share on other sites More sharing options...
Digitom Posted February 10, 2010 Share #11 Posted February 10, 2010 Yes, I tried a new battery and it had the same problem. Sorry that wasn't clear in my original post. So I think it is something internal to the camera. thanks in advance for your help. Do you use the original charger? That is recommended and my experience is to use the original charger only! 2nd idea: could be a problem with the charger itself, if also another cell failed. Link to post Share on other sites More sharing options...
nabarund Posted March 1, 2010 Author Share #12 Posted March 1, 2010 yes, i had been using the original charger, and also the charger from my panasonic version (camera had been stolen and i was left with the extra charger). it ended up not being a cell failure or charger problem, but a motherboard/software problem. fixed now! thanks. Link to post Share on other sites More sharing options...
