01af Posted May 15, 2013 Share #361 Posted May 15, 2013 Advertisement (gone after registration) ... my M9 reports "uncoded" not only to the 135 Elmarit code (001001) ... Sure. Wrong framelines. ... but to any other code that I have tried. Have you tried 110101? That's the Apo-Telyt's code, and this should work. You cannot code your lens as a "Tele-Elmar 135 mm." ... it is something to do with the frame lines. Can you or anyone throw any light on this? This has been discussed over and over so many times already. Link to post Share on other sites More sharing options...
Advertisement Posted May 15, 2013 Posted May 15, 2013 Hi 01af, Take a look here Proof of concept regarding self coding of lenses. I'm sure you'll find what you were looking for!
LCL999 Posted May 17, 2013 Share #362 Posted May 17, 2013 Thanks for the feedback. I tried 110101 but that did not work either. From yours and other posts I have determined the following. 1) For an M9 to recognise a lens, the lens must have a valid code AND bring up frame-lines to match that code. 2) The 135mm 2.8 Elmarit (code 001001) actually brings up the 28/90 framelines (it comes with a separate viewfinder) so any lens with that code bringing up the 35/135 framelines will be reported as "uncoded" 3) The APO-Telyt 135mm was originally released without coding, and Leica at the time claimed it never would have coding. (Because most M9s don't have 35/135 frame lines). Since then, current shipments DO have the 110101 code, and the latest M9 firmware supports that. 4) My M9 does not have that update. As proof-of-concept I have just now recoded my f/4 135mm to 101011. Bingo! It is reported as being an f2.5 35mm Summarit, which matches the code. I have yet to see what the "adustments" do to the images with that lens. The whole exercise has, for me, been quite long and frustrating. You said "This has been discussed over and over so many times already" Maybe so, but the info. is pretty scattered and putting it all together I did not find easy. Certainly point (1) above was glossed over in most of the self-coding discussions that I read. LCL Link to post Share on other sites More sharing options...
250swb Posted May 17, 2013 Share #363 Posted May 17, 2013 Do make sure you are using matt black paint to fill the coding rebates, not black marker pen. The M9 requires a more opaque black mark than the M8, which will happily respond to a Sharpie. Steve Link to post Share on other sites More sharing options...
01af Posted May 17, 2013 Share #364 Posted May 17, 2013 ... and the latest M9 firmware supports that.[...] My M9 does not have that update. You don't need the latest M9 firmware. Firmware 1.162 and later will do. If code 110101 ("Apo-Telyt") doesn't work but 101011 ("Summarit 35") does then I guess you just didn't apply the former code properly ... a misplacement by, say, one millimeter or so will render it unrecognisable. Or your firmware is older than 1.162. Link to post Share on other sites More sharing options...
Henners Posted February 14, 2024 Share #365 Posted February 14, 2024 On 4/14/2013 at 7:45 AM, lct said: No problem with the Match Technical's coder kit. Coder Kit Looks like that link is broken for the coder, there's ones on eBay though Link to post Share on other sites More sharing options...
RexGig0 Posted February 14, 2024 Share #366 Posted February 14, 2024 1 hour ago, Henners said: Looks like that link is broken for the coder, there's ones on eBay though We should not expect a link to work, when it is more than a decade old. 😉 1 Link to post Share on other sites More sharing options...
lct Posted February 14, 2024 Share #367 Posted February 14, 2024 Advertisement (gone after registration) See also: 2 Link to post Share on other sites More sharing options...
