Showing results for tags 'shutter curtain'.
Found 3 results
  1. Hi! I've been noticing uneven exposures, usually on the right side of the photo. Have you guys experienced the same thing? What could be the cause?
  2. Hello everybody, I need some advice regarding repairing/CLA of an M6. The camera seems to have shutter capping (It might be partially my fault since I took out the camera at -7 degrees Celsius a whole day, however, after that, I shoot a roll in a normal temperature environment -my house- and everything was fine, all the images were fine) So... these are my questions: 1. Do I sent the camera to Leica Camera without prior notice? I mean, do I ship it with DHL and that's it? I'm asking this because on their service page they do not specify all the types of Leicas they are repairing. I'm assuming M6 is one of them but it's better to play it safe. 2. I want my problem to be fixed and also I want a full CLA (I've noticed some gunk on the winding gears and the low exposure times are not quite accurate). Should I specify the CLA part in the attached document or the CLA of a camera comes by default with the repairing process? 3. Please don't laugh on this one but the camera will be sent to: Leica Camera AG, Am Leitz-Park 5, Wetzlar, Germany? I'm asking that just to be sure that I'm sending the camera to the right address. I realize the questions are a little bit odd but I never sent a camera for a CLA (I usually shoot with two EOS3 cameras-never had a problem). I bought recently this Leica from Ebay and I want to make it "as new" before I start shooting with it intensively. Thanks in advance for the answers Cheers L.
  3. Hi all, Just had my M6 CLA’d due to a light leak around the shutter curtains. They are demonstrating some curling and leave a light leak when a frame is left in the gate for too long. The tech replaces the baffles among other things but I can still see a bit of light at the edges when shining a bright light. He claims that is normal and his other Leicas also have this. Can anyone attest if that is true by checking your shutter curtain edges when shining a bright light inside? much obliged! Boe
