Diglux 2 stuck in macro focus mode
Cirrus1
I just got this one back a month ago with a new sensor and don't want to send it back yet.:mad:
Any ideas..... will it work ok for all around shooting in macro mode. The macro symbol only goes away when I switch to manual focus mode. Is there a reboot/reset trick?
Thanks,
John
John,
I've had two D2's over the years that have exhibited that problem:confused:. Neither of those D2's actually entered the "Macro" mode (only the "flower" indicator on the screen would indicate so):). So, even though it showed "macro" mode with the flower on screen, it would take pictures normally in AF mode. So it was really not a problem; for me as I hardly ever used AF mode anyways. I really think it was an indicator/switch in the lens problem and not a "real" functional problem. Uh.... did I make that clear or .... ???:eek: Anyways, I would try an infinity AF shot and check closely; I think you may find your D2 has the same problem.
Bob
The only problem that would occur if the camera really was stuck in macro mode is that it would take slightly longer for the autofocus to lock on because the lens elements have to travel further. From time to time I've absent-mindedly walked around with my D2 in macro mode and there are no negative effects apart from the above; I haven't noticed the battery draining any faster either.
Pete.
Well, I have to thank you Thorsten. You prompted me to setup a test. On a tripod from 12 inches away the camera in question will focus on a poster that has small text and pictures in Both settings. My "backup" D2 will not, it only has sharp focus in macro mode. So..... what should I do? Send it in? Does this effect infinity focus. I have never had this happen and have never done macro photography so I am at a loss as to how this effects the camera.
Thanks,
John
Thanks for the quick reply Thorsten, I was just out in front of my house and it seems to focus fast at infinity distance and looks sharp through the EVF. I think I will go out early Sunday and shoot a landscape with both camera's and print them to see if there is any difference. I'll email Leica and see if its still coverd from the sensor replacement. It was there in August.
Thanks again,
John
Hi,
Focus and aperture rings on Digilux 2 / LC1 are linked to variable resistors via a sliding cam, this is how the camera determines the position of each ring. The resistors themselves are attached on the lens body with two screws. You can adjust their position slightly for accurate sensing (requires full strip down and some desoldering, though).
In my LC1 the aperture ring was shifting to the right, towards smaller apertures, and I lost f/11 setting. I could only do f/10 or A mode, f/11 was just on the A-lock ridge. In your case the AF mode must have shifted to the left, probably just on the MF-lock ridge. This is why you can't keep it on AF mode now. Unfortunately, this also affects the focus distance numbers, for instance when you think you are at 1m, the camera might be pointing at 1.2m. But still none of this will make your camera unusable, I think.
Even though I solved my problem by nudging the little resistor, the actual solution must be in the camera software itself. There must be a calibration mode and probably the service centre did a shoddy job out there. If I were you I would send back for calibration.
Cheers,
Koray
