tom0511 Posted 18 hours ago Share #1 Posted 18 hours ago Advertisement (gone after registration) I now have used the SL3-S for handball game. together with a Sigma sports 70200/2.8. I wanted to share my experience and see if others have made same experience: I worked with C-AF, 7fms per second and later 30 pms per sec. first annoying thing: every time I switch the camera on I get this "no credential rec at this setting" which I first have to click ok before I can do anything else. I understand that now and I do not want to have this step every time I should at a fast frame rate! The AF felt fine, the viewfinder looked pretty sharp, but after the first few shots I realized something: I felt I pressed the shutter early enough to catch a throw/jump shot, but the first image already seemed a short moment too late. My speculation is that there is a small time gap/delay between the action happening and what I see in the viewfinder which can lead to the fact , that I press the viewfinder for a quick moment too late. I the changed my behavior and started to press the shutter a moment before I was expecting a throw and that worked better. I tried to find out if it was a difference between the electronic shutter and the mechanical, but I am not able to say if either mode worked better or worse. Overall I got some acceptable shots, but it seems much easier and a quite a bit more reliable to catch shots with the Canon which I usually have used for handball/sports. The AF of SL3-s has become better, the viewfinder as well, but there seems to be a (very short) viewfinder delay/ or shutter delay (I am not sure here, I think the first). Also with the R3 you can use face detection and choose a certain area in the viewfinder anyways. This helps a lot to catch the right player and get the face sharp. In case of SL3-s I watched the right player, but not always the face/eyes. I read that some newer sports cameras even have AI for basketball or football which helps to focus on the right player. And then you can choose "pre-shooting" with half pressed shutter, which also should help. to get the shot even if you press the shutter slightly too late. I got the SL3-S because I wanted to get away from an additional system for sports (My Canon). But this first check was not so successful. My main complain is the slight delay. Do others here can share there experience of using the SL3-S for sports? I know, its not a Z9 or R1, but I expected it to come a little closer. Link to post Share on other sites More sharing options...
Advertisement Posted 18 hours ago Posted 18 hours ago Hi tom0511, Take a look here SL3-S for sports...viewfinder/shutter delay and AF. I'm sure you'll find what you were looking for!
hoolyproductions Posted 16 hours ago Share #2 Posted 16 hours ago I almost never shoot sports, but did give it a try recently for one of my daughter's roller derby matches: Link to post Share on other sites More sharing options...
LocalHero1953 Posted 15 hours ago Share #3 Posted 15 hours ago (edited) Not sports but dance. My experience is with the SL2-S, though I have recently switched to the SL3-S. I suspect the same will apply. IMO the problem with all EVFs is not resolution, refresh rate or colour fidelity, but the lag from the action. It has got better as I have progressed from M240+visoflex, CL, SL, SL2-S, but remains something I have to make allowances for. For dance my aim is to catch a leap as the dancer is rising, not coming down, and to catch the moment in a pose when the limbs and fingers are perfectly outstretched. I use the fastest fps rate with mechanical shutter and AFc, which I find adequate - 30fps would be overkill as well as problematic with rolling shutter. I start the burst before the leap starts or before I expect the pose, but unless it is a rehearsal with lots of repetitions, I can't always anticipate correctly. The worst case scenario is where I shoot a burst too early, and then find the camera is emptying the buffer just when I want to take another sequence. I haven't noticed a big problem with focusing. I'm using face recognition and AFc, and normally this works. Leaps usually look best side on anyway (i.e. the distance doesn't change so much). They repeated these leaps in rehearsal so many times that anticipation was not a problem, but I was still able to focus using just AFs and in single shot with the SL2-S. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited 15 hours ago by LocalHero1953 3 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/425095-sl3-s-for-sportsviewfindershutter-delay-and-af/?do=findComment&comment=5884229'>More sharing options...
jaapv Posted 13 hours ago Share #4 Posted 13 hours ago I imagine that Panasonic's pre-release and hi-speed bursts would solve these problems. 1 Link to post Share on other sites More sharing options...
Luke_Miller Posted 11 hours ago Share #5 Posted 11 hours ago I discovered this lag between reality and EVF image with my first mirrorless camera many years ago. With practice I found that with both eyes open I could compose using the image in the EVF and release the shutter using the the realtime view of the subject from my other eye. It's easier than it sounds. While the lag times are much reduced with modern EVF cameras this technique may still be useful. 3 Link to post Share on other sites More sharing options...
jaapv Posted 6 hours ago Share #6 Posted 6 hours ago The Digilux2 had a lag of about one second. Still I managaged some photographs of kids on a swing The hit rate was about 10% as I recall. 1 Link to post Share on other sites More sharing options...
tom0511 Posted 5 hours ago Author Share #7 Posted 5 hours ago Advertisement (gone after registration) I still love the SL system but I really wish Leica would present a real sports camera. A sensor with a really fast read out might be the solution. I guess it would help to a) reduce viewfinder lag b) to improve AF even further. Pre-capture would be a real benefit. Might it be possible via firmware for the SL3-s???? this would be a dream! Link to post Share on other sites More sharing options...
