cozmopak Posted July 19 Share #1 Posted July 19 Advertisement (gone after registration) Would anyone be able to comment on the shutter lag for the Leica M11-D. I found it noticeable on the standard Leica M11, but I'm wondering whether it is the same with the D version since there is no live view mode. Link to post Share on other sites More sharing options...
Advertisement Posted July 19 Posted July 19 Hi cozmopak, Take a look here Leica M11-D shutter lag . I'm sure you'll find what you were looking for!
lct Posted July 19 Share #2 Posted July 19 I have no experience with the M11-D but it has both RF and LV modes the same way as the M11 AFAIK. See Technical Data. 1 Link to post Share on other sites More sharing options...
jaapv Posted July 19 Share #3 Posted July 19 1 hour ago, cozmopak said: Would anyone be able to comment on the shutter lag for the Leica M11-D. I found it noticeable on the standard Leica M11, but I'm wondering whether it is the same with the D version since there is no live view mode. Live view takes it data from the video feed of the sensor, so there should be no impact on the shutter lag, unless there is a difference in shutter sequence. 2 Link to post Share on other sites More sharing options...
SrMi Posted July 19 Share #4 Posted July 19 4 hours ago, cozmopak said: Would anyone be able to comment on the shutter lag for the Leica M11-D. I found it noticeable on the standard Leica M11, but I'm wondering whether it is the same with the D version since there is no live view mode. The shutter operates the same in the M11-D as it does in the D. Metering occurs on the sensor, and the shutter is open before the shutter button is pressed. The shutter lag should be identical. Link to post Share on other sites More sharing options...
JNK100 Posted July 19 Share #5 Posted July 19 There is no reason for it to be different as others have said. Link to post Share on other sites More sharing options...
