Dear all,
once the light leak of my IIIg will be repaired :) , I’d like to use my Summaron 3.5/35mm and Hektor 6.3/2.8cm.
What viewfinder do you use  ? Any vintage Leica ? They seem quite hard to find.
I’d like something rather small…
I saw the KEKS which are very cheap : are they usable ? Any other idea ?
Thanks
Didier
Any viewfinder of the appropriate focal length is usable, however, especially for eyeglasses users, some are better than others. I've had good experience with Voigtlander ones. The frame lines are clear and bright as are the images.
The voigtlander 28/35 VF seem difficult to find
SUOOQ is probably most chronologically appropriate for Hektor, I love the looks, don’t know how practical it is. I’d rather go with most practical one, with newer optics, all that leads to Voigtländer 28/35 but it’s hard to find.
Posted (edited)
I think the SUOOQ is the smallest, the most practical for 28mm and if the glass hasn't deteriorated also optically very good. It is not cheap, though you may find one for an acceptable price (as long as you stay away from a black painted one...)
You can fold it together when you don't use it:
Unfortunately Leitz never offered a "folding" viewfinder for 35mm. As a separate finder during the 3.5cm-Elmar times there was only the old WEISU, which is tiny though hard to find and therefore rather expensive today. I can't tell anything about the optical qualities
Then there was of course the SBLOO - it's rather huge though optically unsurpassed (if the glass is good):
It was originally meant for the M3 when the first version of the 3.5/3.5cm Summaron was introduced without goggles. Though with an IIIg it might not be way too big. Of course it's expensive nowadays.
Zeiss offered a  smaller one for their rangefinder models: 432/5. Optically it is not as good as the SBLOO, though you might find better examples than mine and not very expensive:
Edited by UliWer
  • Thanks 2
Thank you very much @UliWer
Regarding the SBLOO, are there frame lines for the 35mm focal length (ie do you see more than the 35mm FL, and, if yes, how much more) ? In this case, is it possible to use it within the frame lines for the 35 and without for an approx. 28mm ?
Thank you for your help
Didier
Light Lens Lab (LLL) make modern versions of the WEISU and SBLOO, although both appear to be sold out at present: see Light Lens Lab 35mm Viewfinder "WEISU" and Light Lens Lab 35mm Viewfinder SBLOO.
I have the modern WEISU, but as a glasses-wearer I struggle to see the edges of the tiny image; I suspect the SBLOO is much better, although I've not tried one.
Alan
Yes, you see more than the frames for 35mm in the SBLOO, though as it has a round eyepiece you see a circle around the frame which is not really helpful for defining the frames of 35mm. You better look through pone before you decide to get one.
I have at least 4 Leitz 35mm finders, but if you have a Leica Standard or earlier body the Leitz finder will not fit.
But the Nikon or Canon finders are smaller and a different shape and do fit.
FYI: the old Canon 28mm finder does fit the Leica Standard too. I actually use that one with a homemade mask to make it ~35mm. 🙂
  • Thanks 2
The Light Lens Lab copy of the SBLOO is impossible if you wear glasses and like all(?) Leica viewfinders the framelines aren't very bright. By far the brightest for view and framelines are the ordinary plastic Voigtlander finders and also for a clear view of the framelines if you wear specs.
Posted (edited)
I find SBLOO is glorious optically, though I'm not sure about using it for 28mm as the frame lines are quite close to the edges. It's also challenging with eyeglasses unless you wear ones which sit quite close to the eye.  The KEKS 35mm finder is not worth considering, in my opinion. It has no framelines or even clearly defined edges, and has strong barrel distortion, so that it is barely if at all better than not using a finder and just guessing.
VIOOH is also quite decent and has sharply defined frame edges, but not illuminated framelines. It is a bit large, though.  And if you don't mind a large viewfinder, there is of course also the Contax turret finder and the Russian copies, which have both 35mm and 28mm lenses and do show you a bit outside the frame.
Edited by qqphot
On 7/7/2025 at 5:52 AM, UliWer said:
That must be extraordinarily rare, or have a very optimistic seller!
Posted (edited)
Am 7.7.2025 um 13:32 schrieb nf3996:
Alan
Alan, it´s not your glasses, I bought the LLL "Weisu" for the same reasons discussed here: the SBLOO is very large for a Barnack, the Voigtländer 28/35 is rare and expensive, and the original Weisu costs over 1K... Unfortunately, the purchase of the LLL copy of the "Weisu" was a disappointment: mechanically excellent, but even though "35mm" is written on the finder, it definitely shows a field of view somewhere between 45 and 50mm.  I compared it with the MP finder and several others, and it is definitely nowhere near showing a true 35mm field of view. Unfortunately, the finder was shipped from the US, and returning it would mean endless discussions with customs and tax authorities—so, pointless. A pity—it could have been a great solution. My positive opinion of LLL has cooled significantly because of this finder.
My current solution is a Leica 36mm finder, which was originally offered as an optional accessory for the X1. Medium-sized, but still acceptable on a Barnack. Most of the time, however, I now use my 3.5cm Elmar with the  5cm viewfinder of the II D and just estimate—it works quite well, actually.
Edited by Kl@usW.
Personally I like to tinker around with my cameras. My very worn Standard had its front viewfinder glass missing, so I modified the viewfinder glass from a Soviet Chaika half frame camera. The Standard's viewfinder now has a FOV corresponding with ~40mm. Another option could be to find a cheap old 35mm (plastic?) viewfinder camera with a 35mm lens. Disassemble it and create your own housing (with 3D printing?).
