I am looking for 35mm Leica lens for M7, and used one in good condition might be a good option. Some on KEH now.
Would you please help me to understand deferences between those two:
https://www.keh.com/shop/leica-summicron-m-35-30-mm-f-2-wide-angle-lens-for-leica-m.html
https://www.keh.com/shop/leica-35mm-f-2-summicron-m-aspherical-11673-m-mount-lens-black-6-bit-coded-germany-39.html
I appreciate comments, recommendations, shared experience regarding those two, and other 35mm lenses.
Thanks!
2 hours ago, mhasman said:
Is v2 the current version Leica sales brand new?
Yes, that is the current 35mm Summicron-M version. There is also an APO-Summicron 35mm but that one is much more expensive.
-Thomas
I have the v2, but don’t like it, and try to sell it for more than 6 months now, but there doesn’t seems to be any interest.
So I advice you to find a second hand one as you most probably could get it significant cheaper than a new one.
The Summicron 35/2 asph v2 (11673) is a great little lens indeed. My favorite modern 35/2 bar the apo version i have no experience with. Sharp w/o harshness with a smoother bokeh than the asph v1. Only con is its screw-in hood to me but it is a matter of taste and i use the little hood of the Elmar-M 50/2.8 instead. For a short praise, see:
On 10/19/2024 at 9:35 AM, Al Brown said:
One is ASPH v1 and the other is ASPH v2. Any of the two will do just fine but some v1 are not 6-bit coded yet and v2 has more aperture blades (11 vs. 8 in v1). This slightly affects the shape of bokeh and determines the count of sunstars.
Forum search is your friend.
I have since owned both, loved them both. You won't go wrong with either.
Haven't owned the v2, but my preference is the v1 as I like the plastic snap-on hood better than the current generation (the v2) twist-on metal hood.  As I understand it, they are optically the same.  But like has been stated, either will not disappoint.
