miq.maq Posted October 15, 2024 Share #1  Posted October 15, 2024 Advertisement (gone after registration) I'm just curious how often do people switch lenses on their M cameras? Do you tend to keep one prime lens most of the time or do you switch weekly / daily / hourly 🙂 ? I'm a bit new to Leica and for now very happy with my 50 Summicron but saving up to also get a 35. Can (very) frequent changes wear out the lens mount? Or should they usually last a lifetime? Link to post Share on other sites More sharing options...
Advertisement Posted October 15, 2024 Posted October 15, 2024 Hi miq.maq, Take a look here How often do you switch lenses?. I'm sure you'll find what you were looking for!
Lee S Posted October 15, 2024 Share #2  Posted October 15, 2024 When I first got into photography I’d change depending on the subject when on holiday / travel / walking about. Now I’m one lens with me only unless I’m doing a model shoot. Link to post Share on other sites More sharing options...
rogxwhit Posted October 15, 2024 Share #3  Posted October 15, 2024 Well I don't change lenses by the clock or the calendar but over a year I suppose it could be the equivalent of once a week. And I commonly go out with just one lens already mounted. But that's in the context of photographing just for my own satisfaction.  I wouldn't worry about the mounts. But bear in mind that dust (or worse!) enters and can stick to the sensor ... Link to post Share on other sites More sharing options...
darylgo Posted October 15, 2024 Share #4  Posted October 15, 2024 24 minutes ago, miq.maq said: Can (very) frequent changes wear out the lens mount? Or should they usually last a lifetime? Occasionally I've seen brassing on the camera side and more often on the lens side but don't believe that makes a difference. I would be more concerned with large heavy lenses distorting the mount or damaging the attachment to the body. This would not be an issue with the M body except for the Noctilux lenses and adapted lenses such as the larger R lenses. There are whole forums (almost) discussing the topic of skewed sensors and misaligned lenses, a real issue that is known to drive photographers crazy. The King of misalignment and skew: https://diglloyd.com/blog/2020/20201008_1420-SonyA7R_IV-sensor-parallelism.html Link to post Share on other sites More sharing options...
miq.maq Posted October 15, 2024 Author Share #5  Posted October 15, 2024 (edited) vor 21 Minuten schrieb Al Brown: YOu do not switch lenses on a Leica M. You get a body for each lens. That's the unwritten rule of the chosen. Yea, i was waiting for that comment .... 🙂  Thanks for the other comments. Guess those mounts are pretty tough. I mean lets assume 1o years of use - one change per weekend. Would make for more than 500 changes alone. And i guess some people change more often / and or use their equipment for longer. Edited October 15, 2024 by miq.maq Added Informatio Link to post Share on other sites More sharing options...
Topsy Posted October 15, 2024 Share #6  Posted October 15, 2024 31 minutes ago, Al Brown said: YOu do not switch lenses on a Leica M. You get a body for each lens. That's the unwritten rule of the chosen. Like this.......... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  I normally take my 3 bodies, usually I take the 2 spare lenses but 99% of the time they stay in the bag. 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!  I normally take my 3 bodies, usually I take the 2 spare lenses but 99% of the time they stay in the bag. ' data-webShareUrl='https://www.l-camera-forum.com/topic/413782-how-often-do-you-switch-lenses/?do=findComment&comment=5657620'>More sharing options...
jankap Posted October 15, 2024 Share #7  Posted October 15, 2024 Advertisement (gone after registration) Leica equipment is made for eternity.😇 2 Link to post Share on other sites More sharing options...
lexffm Posted October 15, 2024 Share #8 Â Posted October 15, 2024 I change lenses while I'm out and about. At the moment I have a 35mm, 50mm and the Apo-Elmarit R 180 with me. Not every minute, but in two hours I can use all three. Of course, sometimes I only go out with one lens, for example the 75mm or 90mm. Link to post Share on other sites More sharing options...
kkm Posted October 15, 2024 Share #9  Posted October 15, 2024 vor 1 Stunde schrieb Al Brown: YOu do not switch lenses on a Leica M. You get a body for each lens. That's the unwritten rule of the chosen. Luckily I‘m using Zeiss and Voigtländer lenses - they are not familiar with this unwritten rule 😀 Link to post Share on other sites More sharing options...
aficionados Posted October 15, 2024 Share #10 Â Posted October 15, 2024 we need a fixed lens M camera, then this question is solved. 1 1 Link to post Share on other sites More sharing options...
lct Posted October 15, 2024 Share #11  Posted October 15, 2024 3 hours ago, miq.maq said: I'm just curious how often do people switch lenses on their M cameras? Do you tend to keep one prime lens most of the time or do you switch weekly / daily / hourly 🙂 ? I must own something like 30+ M lenses, i don't count them any more, so i switch each time i need or want so, mainly each time i need a different focal length. Why that many? Because i began to buy M lenses in the seventies and most of them are keepers. 3 hours ago, miq.maq said: Can (very) frequent changes wear out the lens mount? Or should they usually last a lifetime? They are made to last. I have in front of me an Elmar 35/3.5 from 1949 and a Summicron 35/2 from 1960. They still work the same way as when i bought them and they will last probably longer than me. Ready to write a thesis on The Real Leica Man? 😄 2 Link to post Share on other sites More sharing options...
JoshuaR Posted October 15, 2024 Share #12 Â Posted October 15, 2024 I usually go out with two lenses. 28/50 and 35/50 are the most common pairs, but I've also done 50/90 or 50/135. I always like having options. Link to post Share on other sites More sharing options...
miq.maq Posted October 15, 2024 Author Share #13 Â Posted October 15, 2024 vor 2 Stunden schrieb Topsy: Like this.......... Â I normally take my 3 bodies, usually I take the 2 spare lenses but 99% of the time they stay in the bag. Love the patina on your gear! 1 Link to post Share on other sites More sharing options...
CP93 Posted October 15, 2024 Share #14  Posted October 15, 2024 I used to do it a lot. Then I used zooms almost exclusively. Now I’m back to fixed lenses, but generally just stick with one per outing. Link to post Share on other sites More sharing options...
pippy Posted October 15, 2024 Share #15 Â Posted October 15, 2024 Â 5 hours ago, miq.maq said: I'm just curious how often do people switch lenses on their M cameras? Do you tend to keep one prime lens most of the time or do you switch weekly / daily / hourly?... Can (very) frequent changes wear out the lens mount? Or should they usually last a lifetime? I'll consider which lens(es) I wish to use on a daily basis. Normally I will take out a pair of Digi-M bodies each of which will be fitted with one chosen lens. I might take along another lens (or two) but will normally stick with whichever lens has been put on each camera at the start of the day. As far as mount-wear is concerned? Several Lifetimes would be an underestimate. Why might you think otherwise? Philip. Link to post Share on other sites More sharing options...
LocalHero1953 Posted October 15, 2024 Share #16  Posted October 15, 2024 My M2, when I sold it, had seen 60 years of changing lenses, and had little/no sign of mount wear. My M4 has seen 40+ years of use, ditto. My 1932 II Model D, on the other hand, needed a bit of gentle straightening back into proper shape in the experienced hands of Malcolm Taylor. Barnacks, though well engineered, were not quite as tough as the M. Link to post Share on other sites More sharing options...
OR120 Posted October 16, 2024 Share #17 Â Posted October 16, 2024 if i'm out shooting a job - i take what i need for the job ------ when i'm out shooting for myself - i might change a lens once, maybe twice a month -- and for myself i usually pick between the same three lenses - i have many i don't use very often - just keeping them forever - because you never know Link to post Share on other sites More sharing options...
Pika898 Posted October 16, 2024 Share #18  Posted October 16, 2024 Never. I am back to having only one lens and would probably be an ideal target group for the Q3 43 but still prefer the M experience. Link to post Share on other sites More sharing options...
Rick in CO Posted October 16, 2024 Share #19 Â Posted October 16, 2024 get a 28/35/50 Vario-Elmar for walking about and other lenses for those special shots. Link to post Share on other sites More sharing options...
newtoleica Posted October 16, 2024 Share #20  Posted October 16, 2024 When out for a couple of hours walking the street I probably change lenses 3 times. I usually take the 24, 35 and 50, sometimes the 75 instead, depending on where I’m going. I swap both for subject matter, 24 if I can be close in, 50 or 75 if the place is less crowded and sometimes just to give myself a different perspective and keep fresh. I’m not bothered by sensor dust, I clean it when needed. I have a 10-P and a 10-M but only ever take one body out. 1 Link to post Share on other sites More sharing options...
