Smudgerer Posted October 11, 2024 Share #41 Posted October 11, 2024 Advertisement (gone after registration) 4 minutes ago, maxpower said: The reset is described in the manual, but saving settings to apply them after the reset does not exist – you'll have to configure them again. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Thanks for un-stupiding me ! Link to post Share on other sites More sharing options...
Advertisement Posted October 11, 2024 Posted October 11, 2024 Hi Smudgerer, Take a look here Leica M11/M11-M/M11-P/M11-D: Firmware Update v.2.1.3 with further improvements. I'm sure you'll find what you were looking for!
mboerma Posted October 11, 2024 Share #42 Posted October 11, 2024 5 minutes ago, maxpower said: The reset is described in the manual, but saving settings to apply them after the reset does not exist – you'll have to configure them again. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! It should not be normal practice that one has to reset to factory settings after each firmware update. I rarely did and had never issues. With the M11-D it seems to have caused some changes to settings. See my earlier post. 1 1 Link to post Share on other sites More sharing options...
hdmesa Posted October 11, 2024 Share #43 Posted October 11, 2024 48 minutes ago, mboerma said: It should not be normal practice that one has to reset to factory settings after each firmware update. I rarely did and had never issues. With the M11-D it seems to have caused some changes to settings. See my earlier post. The M11-D comes from the factory at the lower GHz setting. Resetting the camera allows it to change to 5 GHz. You may need a second reset. Link to post Share on other sites More sharing options...
mboerma Posted October 11, 2024 Share #44 Posted October 11, 2024 3 minutes ago, hdmesa said: The M11-D comes from the factory at the lower GHz setting. Resetting the camera allows it to change to 5 GHz. You may need a second reset. Mine was at 5 GHz out of factory. But after connecting to the phone changed to 2.4. I did a reset. It changed back to 5. Now after the firmware update the texted for the Content Credentials disappeared and the 5 switched to 2.4 again. 1 Link to post Share on other sites More sharing options...
maxpower Posted October 11, 2024 Share #45 Posted October 11, 2024 9 minutes ago, mboerma said: Mine was at 5 GHz out of factory. But after connecting to the phone changed to 2.4. I did a reset. It changed back to 5. Now after the firmware update the texted for the Content Credentials disappeared and the 5 switched to 2.4 again. I don't usually reset my camera after an upgrade either if I'm honest, hasn't been a problem for me so far even though I do think it probably is cleaner to do, I'm just too lazy. But I just checked and my M11-D stayed on 5ghz and content credentials stayed the same as well, so interesting that that didn't happen for you. For what it's worth I've done the upgrade via SD, not sure if that makes any difference, it shouldn't you would think.. Luckily the M11-D doesn't have that many settings so even after a factory reset it should be pretty quick to get back to your preferences, as long as you remember what you changed. 4 Link to post Share on other sites More sharing options...
mboerma Posted October 11, 2024 Share #46 Posted October 11, 2024 I don’t consider it an issue. It just happened. I used the Fotos app. Link to post Share on other sites More sharing options...
M11 for me Posted October 11, 2024 Share #47 Posted October 11, 2024 Advertisement (gone after registration) I never did that factory reset here either and never had problems with either of my Leicas. Only during Beta testing I did that in order to follow the intended process. But here it worked without. Link to post Share on other sites More sharing options...
hdmesa Posted October 11, 2024 Share #48 Posted October 11, 2024 28 minutes ago, mboerma said: Mine was at 5 GHz out of factory. But after connecting to the phone changed to 2.4. I did a reset. It changed back to 5. Now after the firmware update the texted for the Content Credentials disappeared and the 5 switched to 2.4 again. If it started at 5, it would only change to 2 if it needed to for your phone. In any case, try resetting one more time. Link to post Share on other sites More sharing options...
aficionados Posted October 11, 2024 Share #49 Posted October 11, 2024 3 hours ago, lct said: +1. Forgotten it in the first place but since i did a factory reset i haven't got any new freezes so far. No "new" freezes, so you still have old freezes? I am not updating, I am still happy with 1.6.2, no freezes at all, old or new. 1 Link to post Share on other sites More sharing options...
lct Posted October 11, 2024 Share #50 Posted October 11, 2024 9 minutes ago, aficionados said: No "new" freezes, so you still have old freezes? [...] I had forgotten to do a factory reset. I just did it today and i got neither old nor new freezes since then. Link to post Share on other sites More sharing options...
Knorp Posted October 11, 2024 Share #51 Posted October 11, 2024 For me there was nothing wrong with 2.1.2 This version 2.1.3 only contains bug fixes (again). Hopefully some of you will benefit from this. But when will we get some 'exciting', useful new features? M12 ? Link to post Share on other sites More sharing options...
BWColor Posted October 11, 2024 Share #52 Posted October 11, 2024 5 hours ago, Knorp said: For me there was nothing wrong with 2.1.2 This version 2.1.3 only contains bug fixes (again). Hopefully some of you will benefit from this. But when will we get some 'exciting', useful new features? M12 ? 2.1.4 is rumored to add Otto Focus where you are able manually focus much easier on anyone named “Otto”. What ‘exciting’ features are you wanting? 8 Link to post Share on other sites More sharing options...
Knorp Posted October 12, 2024 Share #53 Posted October 12, 2024 7 hours ago, BWColor said: 2.1.4 is rumored to add Otto Focus where you are able manually focus much easier on anyone named “Otto”. What ‘exciting’ features are you wanting? Anything will do: let them just surprise us (for once) ... Link to post Share on other sites More sharing options...
Smudgerer Posted October 12, 2024 Share #54 Posted October 12, 2024 18 hours ago, Knorp said: For me there was nothing wrong with 2.1.2 This version 2.1.3 only contains bug fixes (again). Hopefully some of you will benefit from this. But when will we get some 'exciting', useful new features? M12 ? Remember lessons learned from the M10-D, there were no firmware upgrades at all, no feature or function upgrades at all, and I'd warrant there's no reason to expect that it will be any different with the M11-D either. What we have is what we've got. Link to post Share on other sites More sharing options...
AndreasG Posted October 12, 2024 Share #55 Posted October 12, 2024 vor 47 Minuten schrieb Smudgerer: there were no firmware upgrades at all, I remember two updates of the M10-D firmware. 1 Link to post Share on other sites More sharing options...
Smudgerer Posted October 12, 2024 Share #56 Posted October 12, 2024 20 minutes ago, AndreasG said: I remember two updates of the M10-D firmware. perhaps but no enhancement of functions........ Link to post Share on other sites More sharing options...
Kim Dahl Posted October 12, 2024 Share #57 Posted October 12, 2024 (edited) What would you improve? I have an MD and - with all respect - what can be improved? Update for new 6 bit lenses ? Yes - But that's it. Otherwise, there isn't much... It's like the whole idea with the D model. It will be different with the new M11_D - I think - because it depends on the Photo app. Of course, errors must be corrected on the M11D as on the M11P etc But I would expect Leica to do that, of course. Edited October 12, 2024 by Kim Dahl Link to post Share on other sites More sharing options...
baltas Posted October 12, 2024 Share #58 Posted October 12, 2024 On 10/10/2024 at 8:09 PM, SrMi said: Please remind me, which Auto ISO issue is not solved? In Auto ISO mode, the camera is 1/3 stop higher. if I set the minimum shutter speed to 1/250 the camera will take 1/320 ,even if the ISO is higher than the base ISO. For example, if you set the shutter speed limit to 1/60, it will take 1/80, 1/125 will take 1/160, 1/250 will take 1/320, etc. The slowest shutter speed is always 1/3 stop higher than the selected one. Camera resseting does not help. 2 Link to post Share on other sites More sharing options...
lct Posted October 12, 2024 Share #59 Posted October 12, 2024 41 minutes ago, baltas said: [...] in Auto ISO mode, the camera is 1/3 stop higher. if I set the minimum shutter speed to 1/250 the camera will take 1/320 ,even if the ISO is higher than the base ISO. Depends on the light, aperture and max iso. The camera can choose much slower shutter speeds than 1/250s if you shoot indoor at f/8 for instance, say 1/60s for max 6400 iso. Link to post Share on other sites More sharing options...
baltas Posted October 12, 2024 Share #60 Posted October 12, 2024 20 minutes ago, lct said: Depends on the light, aperture and max iso. The camera can choose much slower shutter speeds than 1/250s if you shoot indoor at f/8 for instance, say 1/60s for max 6400 iso. For example, automatic ISO settings: Max ISO 3200, Shutter speed limit 1/250. Camera in the range from 64 to 3200 ISO, exposure time constant 1/320, do you think this is normal? Link to post Share on other sites More sharing options...
