Just upgraded  via Fotos on my day old M11-P.
Upgrade completed successfully but took a good few minutes. Progress bar didn't seem to work properly, which made me think it had crashed, but all was well.
Take note of the note ... :rolleyes:
Note
It is recommended to revert to factory settings after an update.
• Date & time, as well as the preferred language will have to be
set up again after a reset. Relevant prompts will appear on
screen.
Edited by Knorp
Note
screen.
No prompts when I upgraded, and everything (including language, date and time, seem to be fine. I'll keep an eye on it and report back when it dies on me 😉
Note
screen.
Who recommended? Its made no mention in the fotos app when updating
Edited by kiwidad
You're a brave man, Corius. I'll wait a little and see what Mr Slack has to say ... ;)
  • Haha 1
For those who can't be bothered with the release notes.
ERROR CORRECTION
The improvement of our firmware is an ongoing process. The current update contains important bugfixes
and improvements of the stability of the firmware:
• Sporadic system errors during lens changes
• Sporadic system errors during single frame shooting
• Sporadic system errors during continuous shooting in combination with CAI (content credentials)
Known errors
• The camera activation process may delay in rare instances.
Important Information regarding memory card use
• In rare cases, the use of UHS-I SD may result in some technical issues. An optimization for these SD
cards is planned for a later firmware update. Leica recommends using UHS-II cards to generally avoid
these issues, and to guarantee the best possible performance for your camera.
20 minutes ago, Knorp said:
If it is all "sporadic" you wonder why they bother in the first place ... 😇
All reported M11 issues are sporadic (occurring at irregular intervals).
15 minutes ago, VJPGG said:
Updated. Camera reset. Seem to be fine... but I can´t change the file root name. Before I choose to be "M11", and now it is "L11".
I´m the only one with this behavior?
What exactly do you mean: "can't change the file root name" ? Please check to see if you're not accidentally trying to update the default profile !
Edited by Knorp
I updated my M11-P #589 series using the SD card method. I understand the Fotos App update process works fine. But a past experience with the Fuji phone app updating my GFX 100S has me using the SD card process for now.
I saved my user profile on the SD card, since it was offered, even though the release notes recommend starting fresh with a factory reset (old boilerplate instruction?).
The update went pretty fast, just a couple minutes. When done the red light stopped flashing and the camera turned off but it did not restart on its own. I waited a minute then turned the switch off then back on again and it started right up. Everything looks just like before (including the photo file name I have), so my profile was reinstalled correctly and the firmware reads 2.1.2. The initial tests look good so far.
