Hi everyone, while I was shooting my Leica M10, I encountered a strange problem. Here it is:
I was shooting with LIVE VIEW making sure I get the exact focus I wanted. After shooting a couple frames, the screen went black.
I press the LV button again, and would hear the shutter sound. The screen would remain black, showing all info (shutter speed, ISO etc) but no info on histogram.
When I press the shutter, the camera takes a photo, and shows the photo when I press play but I can not see anything in live view mode at all. When I go to "SENSOR CLEANING" and execute command to open the sensor, the shutter gate remains closed. I updated firmware, changed the battery, changed the SD but nothing worked.
The camera takes the photos with no problem - for all practical purposes the camera is working fine, but the LV function leads to a black screen with info showing on top & bottom but 0 info on histogram, complete darkness.
I'm quite concerned as the camera is 2nd hand and, most probably, out of warranty. Has anyone had this issue? am I going to end up with a $4000 paper weight? any help is appreciated.
9 hours ago, dugby said:
Have you tried a camera reset as found deep down in the camera menu?
Yes, I did! I went through the forums, a couple stories about them having to spent 1500 to change the boards inside the camera got me worried.
9 hours ago, a.noctilux said:
No, not paper weight, I think it's kind of false contact or you can use the M10 without LV (...as main M users do ).
When you have opportunity just show the problem to a Leica Dealer.
I rarely use LV, it was one of those times where the were obstructions close to the lens (tree leaves) between me and the subject so I wanted to make sure I get the right frame. I'm in NYC, i'll take it to either Nippon or Leica, please let me know if you have any other suggestions. Thanks!
1 hour ago, mort linder said:
it would be interesting to see if the evf worked . it would also be interesting to know if the shutter is actually opening when lv is pressed .
does the screen show shutter speed , iso , etc ? good luck .
yes all the info is shown, its just completely black screen in EVF and no histogram info but it takes the photo when I press the button to actuate. I don't have an EVF to try it
I had this issue with a previous M10 and mine required a shutter replacement. I would contact Leica.
  • 4 months later...
Most likely a circuit board failure or loose flex cable.
And yes, repairs can be expensive. But ask yourself: if you got offered a technically as-new M10 for 1500 $, would you hesitate?
  • 9 months later...
  • 2 weeks later...
