brickftl Posted July 19, 2024 Share #1 Posted July 19, 2024 Advertisement (gone after registration) I'm going to be shooting next week on probably a rainy day. I have the M11-P which is supposed to be waterproof, but what about lenses attached to it? Can water enter from where they're attached and/or through the lens? On that rainy day I'll have the 35/1.4 lux steel rim reissue attached. Link to post Share on other sites More sharing options...
Advertisement Posted July 19, 2024 Posted July 19, 2024 Hi brickftl, Take a look here how waterproof is it?. I'm sure you'll find what you were looking for!
jdlaing Posted July 19, 2024 Share #2 Posted July 19, 2024 7 minutes ago, brickftl said: I'm going to be shooting next week on probably a rainy day. I have the M11-P which is supposed to be waterproof, but what about lenses attached to it? Can water enter from where they're attached and/or through the lens? On that rainy day I'll have the 35/1.4 lux steel rim reissue attached. Yes. The weak point are the lenses. Link to post Share on other sites More sharing options...
brickftl Posted July 19, 2024 Author Share #3 Posted July 19, 2024 26 minutes ago, Al Brown said: 0% waterproof, the term you are seeking is water resistant. Keep your M11 away from water. And lenses. They are neither waterproof nor water resistant. so I can't shoot it in a light rain?? Link to post Share on other sites More sharing options...
brickftl Posted July 19, 2024 Author Share #4 Posted July 19, 2024 Just now, Al Brown said: Light rain is still ok, a quick downpour is also probably OK, but avoid prolonged exposure to rain. got it thanks Link to post Share on other sites More sharing options...
brickftl Posted July 19, 2024 Author Share #5 Posted July 19, 2024 I can't help but wonder why Leica in its newest lenses (like my 35/1.4 steel rim reissue) doesn't make them water resistant - especially when they're promoting the water resistance of the M11. Link to post Share on other sites More sharing options...
Jeff S Posted July 19, 2024 Share #6 Posted July 19, 2024 More discussion… Jeff 1 Link to post Share on other sites More sharing options...
jankap Posted July 19, 2024 Share #7 Posted July 19, 2024 Advertisement (gone after registration) Shouldn't it be weather resistant? Try to find this property in the technical data: https://leica-camera.com/de-CH/fotografie/kameras/m/m11-schwarz/technische-daten Link to post Share on other sites More sharing options...
RexGig0 Posted July 19, 2024 Share #8 Posted July 19, 2024 (edited) 2 hours ago, brickftl said: I can't help but wonder why Leica in its newest lenses (like my 35/1.4 steel rim reissue) doesn't make them water resistant - especially when they're promoting the water resistance of the M11. The most-water-resistant lenses have a pliable gasket at the mount, a solid, seamless barrel, and a well-sealed outer element. Aperture rings, and focusing rings, add seams. Zoom rings, if present, add seams. O-rings can be used to seal the seams between moving parts, but, of course, require periodic maintenance/replacement. There has to be room, within the lens assembly, for those gaskets and O-rings. Lens designers have choices to make. Customers have expectations, which includes an expectation that M lenses will be small. Edited July 19, 2024 by RexGig0 Link to post Share on other sites More sharing options...
elmars Posted July 19, 2024 Share #9 Posted July 19, 2024 vor 3 Stunden schrieb brickftl: so I can't shoot it in a light rain?? You can. Leica does not give any guarantees because the lenses and the bayonet are not protected in the technical sense. But I was in Tokyo last year and on two days it rained lightly to moderately for several hours. M11 and lens were not in the bag, I just wiped them from time to time. Nothing happened. I think you have to realise that everything inside the lenses is greased. So the water can't just run in. 1 Link to post Share on other sites More sharing options...
pgk Posted July 19, 2024 Share #10 Posted July 19, 2024 I use underwater housings and the technology to waterproof them is quite simple - 'O' rings. But they do have to be periodically lubricated and don't like sand or chlorine or salt water which isn't rinsed out from their locating groove. And they add really significant bulk. So the bottom line is that the 'gaskets' and similar measures fitted to above water cameras and used to provide any degree of prevention of water access are inherently a compromise. IP ratings are difficult to apply because in general they aren't intended to include controls which need to be operated - they are mostly static, time dependant ingress tests under known conditions/pressures. My own personal experience suggests that getting gear splashed by salt water is a high riskand can easily cause problems (salt is deliquescent and unless removed will continually absorb water leading to much later failures), but drizzle/light rain is usually ok if you are careful to wipe the camera dry if it gets any significant coverage. FWIW I've actually seen a Canon D1 stop working due to very heavy rain, even misting up internally, but revived after a night on a radiator. And this is a weather sealed camera. I wouldn't subject my own cameras to such treatment though. 1 Link to post Share on other sites More sharing options...
newtoleica Posted July 19, 2024 Share #11 Posted July 19, 2024 I use a Q2 for shooting in heavy rain. a very light sprinkling is Ok on the M for short time. 1 Link to post Share on other sites More sharing options...
ELAN Posted July 19, 2024 Share #12 Posted July 19, 2024 I've shot Leica Ms in the rain for years and so far nothing bad has happened... Be prepared to wipe it often as raindrops on the VF/RF windows make focusing difficult, and drops on the lens cause weird flares. When walking in the rain I try to keep it under my coat or sometimes cover it with a shower cap until I want to take a photo. 1 Link to post Share on other sites More sharing options...
kiwidad Posted July 19, 2024 Share #13 Posted July 19, 2024 (edited) I have read Leica's comments on M lenses and water.... they said it all mechanical and with high tolerances not much water should ingress and therefore its fine.. I remember shooting mechanical Nikons in pouring rain years ago and had to pour water off top of focussing screen. I saw Minolta maxum 9000's perish that day! Having said that there are all kinds of products to keep water off! Edited July 19, 2024 by kiwidad Link to post Share on other sites More sharing options...
MaxGor Posted July 20, 2024 Share #14 Posted July 20, 2024 Leica M11 It is more rain resistant than Fuji-XPro3. Leica M11 did not get any humidity into the camera after shooting in rain for 2 hours, so yeah, it is pretty well made I would say. 1 Link to post Share on other sites More sharing options...
kivis Posted August 23, 2024 Share #15 Posted August 23, 2024 My M3's never failed me in light rain and drizzle. Same with the M6 and the M-A. Never tried my M10 so I can't say. M7 failed after about 20 minutes of solid rain. Leica Miami sent it back to Deutschland. It was gone for 6 weeks. Came back and worked like charm. Reasons why I love working with Leica Miami? they Gave a me free loaner (MP) and I never got a bill and that was a good 8 years ago. 👌 Link to post Share on other sites More sharing options...
