Hello all.
I've bought a bowen ilumitran system, not bad at all to scan fast and i hope, with good results.
It came with a clean Agfa Magnolar 4,5/60 enlarger lens, after a good cleaning, it looks very good.
BUT, the final quality seems to be less than the system can deliver, so here's the question:
What's a goooood 60mm enlarging lens? i've a componon 50/4 from my past life, with some fungus, maybe i can do the effort, but the componon is not top notch anyway...
Any ideas on that?
Thanks for your help!
Here a picture scanned with that system, with the Agfa, as a sample.
Edited by fabianoliver
60mm isn't a standard focal length for enlarging lenses. The best enlarging lens close to that would be the EL Nikkor 63mm f:2.8 N.
The best lens for 1:1 reproduction of 35mm negs is probably the Rodenstock Apo-Rodagon-D 75mm, which is available new.
As @Danner mentions, any high-quality lens in the 50-to-80 mm range should suit your needs.
Butkus has the manual for this set-up: https://www.cameramanuals.org/pdf_files/bowens_illumitran-3.pdf
(Send the man some $'s when it is useful to you)
It does talk about the Bogen WA 60mm, but I would say a 50mm could work as well (I do not base this on any specific knowledge or experience). The WA Bogen 60mm has 8 elements, perhaps this is why it is mentioned.
Just in case the 60mm is important: there exist 2 Rodenstock Rodagon 60mm lenses, 60/5.6 and a 60/4. (both 6 elements). There's also the 6 elements Meopta Meogon 60/5.6 enlarging lens which is what I use next to the Focotar-2 lens. This last one came out on top of a 1980ties enlarging lenses test that included all the usual suspects. This lens has the large metal zebra barrel which makes using it in a darkroom very easy.
What I find remarkable is that an Olympus Pen F half frame is mentioned in this manual. Could that be just because you get double the images . . . ?
Edited by M.Hilo
There is also a Novoflex / Staelble-Katagon 60mm f4.5 that was offered for slide duplication with their bellows and slide holder.  I recall that I had difficulty framing with a 50mm lens and the Novoflex set-up.  There must be something about 60mm that makes slide duplicating easier.
