Just got my Leica sl today, everything looks fine but when i start shooting, i found out that the photos sooc are pretty blue tint style, even the live view and evf turn blue as well, i tried several option from white balance, but does not help at all. funny is when i press the grey card on the front, everything turns normal, color seems quite right, but once i press down shutter and take photos, it turns bluish tint again.
does anybody know what is going on there? thank you so much.
I'll upload some sample down below.
1 hour ago, Indeepthought said:
Basic first question:- are the windows tinted? I would do a full reset on the camera, then use a different lens and do some more test shots… Outside shots would be beneficial..  🍷
well it's not, just regular windows ,and i actually tested with different lenses ,turns out the same result. here is another one
So was this a previously owned SL? The reason I ask is maybe there were settings adjusted by someone else. As was mentioned above, do a complete reset of camera, then reset up and let us know if that does any good. And if that doesn't work, talk to whoever you got it from.
Yeah, already did several times, funny thing is when at night, especially for indoor shooting, everything seems normal, color is quite right, even little bit warm, but once turn into outdoor daytime shooting, the white balance immediately gets bluish, kinda drives me crazy.
Red is missing.
Strangely enough it seems that night shots are OK. But a cyan cast in AWB is weird. Hence my suggestion of a gray card setting. I would like to see the LAB curves.
It is a very strange histogram totally underexposed in red and completely flat otherwise.
I forgot that WB was set to tungsten there:
vor 10 Minuten schrieb lct:
Yep, looks just like the OP's shots.
vor 5 Stunden schrieb Panda428:
pretty sure it's a setting issue, but i just don't know why and how
@Panda428, have you checked the EXIF data of your shots? What do they say with respect to WB setting?
It just looks the same!! But I do switch the WB to AWB, actually I tried every WB for testing! But the results are all the same! Isn’t that insane?!
On 6/28/2024 at 3:54 AM, Sandokan said:
I would try this. Set it to B&W and then compare the JPEG to DNG file.
And what was the result when you tried this?
Are you showing us original JPEGs or JPEGs from the DNG?
Edited by Sandokan
