jim sink Posted December 5, 2023 Share #1 Â Posted December 5, 2023 Advertisement (gone after registration) Discovered that when using the new SL 14-24 with perspective control you have to use the lens set at 16mm , perspective control does not work at 14mm. Surprised me !! 1 1 Link to post Share on other sites More sharing options...
Advertisement Posted December 5, 2023 Posted December 5, 2023 Hi jim sink, Take a look here Perspective control using new Leica sl 14-24. I'm sure you'll find what you were looking for!
huwm Posted December 6, 2023 Share #2 Â Posted December 6, 2023 Same with the Lumix 14-28 I just swapped for the 16-35 in any case as 14 not really needed for my uses Link to post Share on other sites More sharing options...
MediaFotografie Posted December 7, 2023 Share #3 Â Posted December 7, 2023 Am 5.12.2023 um 22:32 schrieb jim sink: Discovered that when using the new SL 14-24 with perspective control you have to use the lens set at 16mm , perspective control does not work at 14mm. Surprised me !! oh, that's really surprising; using only the "old" 16-35 I don't know this problem Link to post Share on other sites More sharing options...
SrMi Posted December 7, 2023 Share #4 Â Posted December 7, 2023 On 12/5/2023 at 1:32 PM, jim sink said: Discovered that when using the new SL 14-24 with perspective control you have to use the lens set at 16mm , perspective control does not work at 14mm. Surprised me !! Does it disable the perspective correction guides in the camera? Is the JPEG not corrected? What happens when you apply perspective correction manually? Maybe the angle data is not precise enough for 14mm? Link to post Share on other sites More sharing options...
SrMi Posted December 7, 2023 Share #5 Â Posted December 7, 2023 1 hour ago, SrMi said: Does it disable the perspective correction guides in the camera? Is the JPEG not corrected? What happens when you apply perspective correction manually? Maybe the angle data is not precise enough for 14mm? I checked it with my 14-24 Panasonic, and it behaves the same way: wider than 16mm, LPC does not work and cannot be applied in post either. Somebody should let Leica know and ask whether it works as intended or is a bug. Link to post Share on other sites More sharing options...
Mak67 Posted December 8, 2023 Share #6  Posted December 8, 2023 Leica will probably make a firmware update, you should tell them about this. Link to post Share on other sites More sharing options...
jim sink Posted December 11, 2023 Author Share #7  Posted December 11, 2023 Advertisement (gone after registration) On 12/7/2023 at 3:48 PM, SrMi said: I checked it with my 14-24 Panasonic, and it behaves the same way: wider than 16mm, LPC does not work and cannot be applied in post either. Somebody should let Leica know and ask whether it works as intended or is a bug. Adam with LeicaMiami told me he would ask the  engineers about this. 1 1 Link to post Share on other sites More sharing options...
Dr. G Posted March 15, 2024 Share #8  Posted March 15, 2024 On 12/11/2023 at 8:54 AM, jim sink said: Adam with LeicaMiami told me he would ask the  engineers about this. Looks like the 14-24 on the SL3 behaves the same way. No perspective control under 16mm. Link to post Share on other sites More sharing options...
Manicouagan1 Posted June 18, 2024 Share #9 Â Posted June 18, 2024 Same behavior with SL3 and Sigma branded 14-24, cutoff about 16mm. Â Link to post Share on other sites More sharing options...
