1 minute ago, erl said:
Sometimes, in some situations, you are right, but the original debate was about differences between moving your feet or changing lenses, both of which produce a totally different outcome.
If 'timing' is the issue, which it can be, then the whole criteria shifts.
sorry, sometimes I lose track of what the topic really is..................
  • Haha 1
On 1/17/2024 at 10:55 PM, erl said:
Using your feet produces an optically different effect from using a different focal length
8 hours ago, erl said:
Remember that 'perspective' is only a function of your 'feet'. Not the lens.
This is not true, at least not consistent. The perspective lines of a building shot with an 18mm are more oblique than those from a 24mm if you walk back with the latter to get the same width of image.
vor einer Stunde schrieb otto.f:
If you move your feet, the perspective changes.
With respect, I think you are confusing 'convergence' with 'perspective'.
2 hours ago, otto.f said:
That could be my limited English then
Don't apologize for limited English, if it is not your native tongue. Aside from English my limits on all other languages is zero. I admire anyone who s multilingual.
On 1/19/2024 at 11:46 PM, IkarusJohn said:
The assumption in cropping (particularly in camera) is that the central area of an image is the same regardless of focal length - so, if you take an imgae with a 21mm lens and crop the centre, you can get the same image, including depth of field, as if you took the image with a 90mm lens.  You don’t.
Actually, you do. It’s not an assumption, it’s optics. If you take the image from the same spot, same subject in the centre, with a 21mm and a 90mm (to follow your example), you get exactly the same perspective and DOF at same aperture. Just a lot less resolution on the crop from the 21mm obviously! If you crop off centre it’s different.
This is why, no matter what a lot of people say about crop cameras and the equivalence in lenses, an APS-C 35mm lens will have EXACTLY the same perspective as a 52.5mm on full frame. The DOF will change because you are using a different focal length at the same distance.
Perspective, in the centre crop, the rest, no.   Too much going on. Compression, depth of field, resolution and lens characteristics.
You do get the same field of view, but that’s pretty much it. Your APS-C observation pretty much confirms the point.
I guess we have to agree to differ on the point.
Edited by IkarusJohn
Plus, cropping to the center is exactly the same as mounting a longer lens you stay in the optical axis.
Compression is a function of distance, not focal length, John
Circular, Jaap.  Too many variables to be proven.
Now, I’m sure you will say, as I recall you’ve said before, that if the camera doesn’t move, a crop of the centre of a 35mm image will be identical to an image taken with a 50mm lens at the same aperture, including depth of field.  Rinse and repeat.
I will continue to enjoy my primes, resisting the assurances that in camera cropping is the future!
