Brass, Plastic or Something else?
21 hours ago, 250swb said:
Scratch it and see.
Hello Steve,
Because your response is in such an even tone:
Some people reading this might not understand that you were answering with a "wry" sense of  humor. And that you do not expect anyone to actually follow your suggestion.
Hello giuliani,
Welcome to the Forum.
Best Regards Both,
Michael
Edited by Michael Geschlecht
2 hours ago, Michael Geschlecht said:
Hello Steve,
Hello giuliani,
Best Regards Both,
Michael
I wasn't being wry, if it's important to know what it's made from scratch it underneath where it can't be seen (obviously not on top).
You can tell it's metal just by touching it - it has higher thermal conductivity than the plastic parts of the camera, and feels 'colder'. I've never seen a 'brassed' one, so my guess would be an anodised aluminium alloy.
Let us do some science, remember Archimedes around 2300years ago.....
First, we need a shutter speed dial, a precision scale, a small glass of water and a piece of thread. Attach the thread to the speed dial, put the glass with water on the scale, set it to Zero, dip the dial into the water (it should not touch the glass) and you via the buoyancy you get a volume of 0.95ml. Then simply let the dial drop down in the glass and read again, you get the weight 2.45g. The volume and weight of the piece of thread we neglect. By simple math we get the specific weight of 2.58 g/ml, which tells us, it is an Aluminum alloy, probably with a little Magnesium (Aluminum 2.69 g/ml, Brass 8.73 g/ml, Steel 7.8 g/ml). Problem solved.
I did not expect that it is so difficult to get good LCD photos!
  • Like 13
That is much more fun than emailing Leica Customer Service. 👍
16 hours ago, Michael Geschlecht said:
Hello Everybody,
Or, you could write an email to Leica Customer Service in Wetzlar & ask them.
And then NOT have a scratch in a place where you can not see it.
Best Regards,
Michael
It's cute that you think they will be helpful.
  • Haha 1
Agree, if you touch the tip of your tongue to various surface on a camera or lens, it's very easy to tell metal from plastic.
Just don't get caught by your partner .  Mine already already concerned with my Leica-carresssing habits
  • Haha 2
