satya Posted January 19, 2023 Share #1 Posted January 19, 2023 Advertisement (gone after registration) I have seen different posts about batteries for the Leica M6 and many deal with the TTL version. Have read that Alkaline LR 44 batteries can possibly leak and give different readings. Have ordered some Lithium CR1/3N (2L76) batteries and waiting for them in the mail. Is it bad to use two x Alkaline LR44 batteries until then? I got a rather unusual and very interesting Leica M film body that has been modded 😎 and really waiting to try out the camera to see if it works. (Hint: marrying a 1967 camera with one from 1987). 😁 Any experiences / advise with Leica M6 light meters and LR 44 batteries? Link to post Share on other sites More sharing options...
Advertisement Posted January 19, 2023 Posted January 19, 2023 Hi satya, Take a look here Proper battery for Leica M6 Classic? . I'm sure you'll find what you were looking for!
Chuck Albertson Posted January 19, 2023 Share #2 Posted January 19, 2023 Alkalines will work fine, they just don't last as long. The 1/3N lithium battery works fine, and last longer. I also use silver-oxide batteries that are the same size as the alkalines; they last longer, and work better in cold weather, if that is a consideration. 5 1 Link to post Share on other sites More sharing options...
satya Posted January 19, 2023 Author Share #3 Posted January 19, 2023 Thank you very much. I was worried about damaging anything. I'm presently in the tropics- but will be in Japan in winter next month so will get a silver oxide one. That's good to know. Link to post Share on other sites More sharing options...
Fotoklaus Posted January 19, 2023 Share #4 Posted January 19, 2023 No, you won´t damage anything. I prefer the CR1/3N, as I just have to carry one spare battery with me and the don´t tend to leak. Cheap alakline do after a while. So for a long term use I´d take the lithium cells. 2 Link to post Share on other sites More sharing options...
Anbaric Posted January 19, 2023 Share #5 Posted January 19, 2023 You'd have to be incredibly unlucky for the batteries to leak in the short time you'll have to wait for the lithium battery to arrive (assuming these are new alkalkine batteries from a reputable manufacturer - if they are old batteries you've grabbed from another camera, then all bets are off). Alkalines can leak in the long term. I no longer use them in anything expensive. 1 Link to post Share on other sites More sharing options...
nitroplait Posted January 19, 2023 Share #6 Posted January 19, 2023 (edited) Lithium CR1/3N is preferable by far. Very long shelf life and lower leaking risk. SR44 is second choice. LR44 is just too big a risk and their depletion profile is not suited for a light meter. Edited January 19, 2023 by nitroplait 1 1 Link to post Share on other sites More sharing options...
Matlock Posted January 19, 2023 Share #7 Posted January 19, 2023 Advertisement (gone after registration) 8 minutes ago, Anbaric said: You'd have to be incredibly unlucky for the batteries to leak in the short time you'll have to wait for the lithium battery to arrive (assuming these are new alkalkine batteries from a reputable manufacturer - if they are old batteries you've grabbed from another camera, then all bets are off). Alkalines can leak in the long term. I no longer use them in anything expensive. Another problem with Alkaline batteries is, even if they don't leak, they can expand and become difficult to remove. Mind you they would have to be pretty old to get into this state. 2 Link to post Share on other sites More sharing options...
TomB_tx Posted January 19, 2023 Share #8 Posted January 19, 2023 Years ago I left alkaline batteries in my 1985 M6 while unused for a time, and the leakage ruined the meter circuit board and also damaged a shutter part. Whatever type you use, remove them when the camera is likely to be unused. 2 1 Link to post Share on other sites More sharing options...
Huss Posted January 19, 2023 Share #9 Posted January 19, 2023 As others have mentioned, the ideal battery is the lithium CR1/3N, which is what Leica ships with their cameras. Silver oxide #2. Alkaline in a pinch but remove them the moment you do not use your camera. I have seen them swell and leak in their packets from new! And this is with any brand, including Duracell. Interestingly the Duracell alkalkine cells are now made in China, so for all I know they may the same as the cheap no name brands, just in a fancy package. The swelling and leaking is a gradual process, so you'll be ok taking them out between use and examining them. You can see the early signs of either quite easily - the leakage will first demonstrate as green particles/debris on the top sealed edge. 2 Link to post Share on other sites More sharing options...
atournas Posted January 22, 2023 Share #10 Posted January 22, 2023 Lithium CR1/3N on all my M's and 2X on all my R's. And I never carry space ones: the chances to run out while on shooting are very small, considering they long lasting (unless one is a pro photographer, which I'm not). 1 Link to post Share on other sites More sharing options...
Guest Posted March 16, 2023 Share #11 Posted March 16, 2023 (edited) Is there a CR1/3N lithium battery supply problem? It seems impossible to obtain branded (Duracell, Varta, Energizer, ...) CR1/3N 3V lithium batteries from any photo equipment dealer here in Australia. I have a Fujitsu-branded one on order from a large dealer since November last year. Expected date of delivery is unknown. None of the large electronics dealers here has any CR1/3N stock. Even B&H only has some Chinese ones in stock. What is going on? These were available on every corner in the past. I now ordered some Duracell ones from a US-based ebay store, but I prefer not to buy batteries on eBay, there is always the risk of receiving counterfeit. Edited March 16, 2023 by Studienkamera Link to post Share on other sites More sharing options...
Fotoklaus Posted March 16, 2023 Share #12 Posted March 16, 2023 Not so here in Germany. Several brands available. Link to post Share on other sites More sharing options...
Guest Posted March 16, 2023 Share #13 Posted March 16, 2023 9 minutes ago, Fotoklaus said: Not so here in Germany. Several brands available. Unfortunatelty, German shops don't seem to sell to outside EU customers. Link to post Share on other sites More sharing options...
Huss Posted March 16, 2023 Share #14 Posted March 16, 2023 Careful with Duracell. Some of their 1/3N batteries are alkaline, sold as lithium. And others are lithium. Read the package fine print. Alkaline version: https://www.thebatterysupplier.com/products/duracell-dl1-3n-3v-lithium-battery-carded.html 1 1 Link to post Share on other sites More sharing options...
romualdo Posted March 16, 2023 Share #15 Posted March 16, 2023 1 hour ago, Huss said: Careful with Duracell. Some of their 1/3N batteries are alkaline, sold as lithium. And others are lithium. Read the package fine print. Alkaline version: https://www.thebatterysupplier.com/products/duracell-dl1-3n-3v-lithium-battery-carded.html wtf!! that's blatant misleading advertising - is that a genuine Duracell product or a knock-off? Link to post Share on other sites More sharing options...
Huss Posted March 17, 2023 Share #16 Posted March 17, 2023 4 minutes ago, romualdo said: wtf!! that's blatant misleading advertising - is that a genuine Duracell product or a knock-off? dunno mate. If it was a knock off though, I'd think they'd claim it was lithium. Link to post Share on other sites More sharing options...
Huss Posted March 17, 2023 Share #17 Posted March 17, 2023 (edited) To be clear, I am not accusing Duracell of doing anything wrong apart from having labelling that should more clearly state if it is an alkaline or lithium battery. The issue is with the vendor who lists it as a lithium battery. But - I had no idea that Duracell made this in two versions and so would not have checked! Edited March 17, 2023 by Huss Link to post Share on other sites More sharing options...
romualdo Posted March 17, 2023 Share #18 Posted March 17, 2023 (edited) one of my spares from a few years back (purchased in 2015) 1/3N Lithium The product info on the "pseudo" non lithium (alkaline) 1/3N seems very minimalist compared to this one - different designs for different localities/countries? I've just checked the Australian & US Duracell website & the 1/3N battery is not listed Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited March 17, 2023 by romualdo Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/362218-proper-battery-for-leica-m6-classic/?do=findComment&comment=4726839'>More sharing options...
Guest Posted March 17, 2023 Share #19 Posted March 17, 2023 34 minutes ago, romualdo said: I've just checked the Australian & US Duracell website & the 1/3N battery is not listed Yes, I checked them as well. My eBay order was cancelled by the seller. Might have something to do with our new Australian child-resistant packaging policies for button batteries. Link to post Share on other sites More sharing options...
Matlock Posted March 17, 2023 Share #20 Posted March 17, 2023 7 hours ago, Huss said: To be clear, I am not accusing Duracell of doing anything wrong apart from having labelling that should more clearly state if it is an alkaline or lithium battery. The issue is with the vendor who lists it as a lithium battery. But - I had no idea that Duracell made this in two versions and so would not have checked! Looks pretty clear to me. Link to post Share on other sites More sharing options...
