JaKuBe Posted September 23, 2022 Share #1 Â Posted September 23, 2022 (edited) Advertisement (gone after registration) Hello. I just have simple question. Is it necessary to adjust rangefinder after top plate removal? I need to replace plastic strap protectors and some repairmans say it is necessary, but I doubt it. I just want to do it quickly and without complicate things a lot more. Thank you. Edited September 23, 2022 by JaKuBe Link to post Share on other sites More sharing options...
Advertisement Posted September 23, 2022 Posted September 23, 2022 Hi JaKuBe, Take a look here Leica M6 adjustment after top plate removal. I'm sure you'll find what you were looking for!
madNbad Posted September 24, 2022 Share #2  Posted September 24, 2022 The last M6 was made nearly thirty years ago so the chance that the viewfinder needs cleaning and adjustment are pretty high. If the top plate is going to be off, what better time to attend to this service? I realize you’re hoping to pop off the top plate, install a couple of new buffers and be done. Do it right and you’ll do it once and you’re set for a long time. Sorry for the tough love but welcome to the forum. Link to post Share on other sites More sharing options...
LeicaR10 Posted September 24, 2022 Share #3 Â Posted September 24, 2022 JaKuBe, Â First, welcome to the forum. Â Second, +1 for Madnbad post to you. Â r/ Mark Link to post Share on other sites More sharing options...
JaKuBe Posted September 24, 2022 Author Share #4  Posted September 24, 2022 1 hour ago, madNbad said: The last M6 was made nearly thirty years ago so the chance that the viewfinder needs cleaning and adjustment are pretty high. If the top plate is going to be off, what better time to attend to this service? I realize you’re hoping to pop off the top plate, install a couple of new buffers and be done. Do it right and you’ll do it once and you’re set for a long time. Sorry for the tough love but welcome to the forum. I see. But CLA was done quite recently, so I am sure everything is fine right now. No cleaning needs. I just have broken strap protector and want it to repair, because it can cause light leaks. Link to post Share on other sites More sharing options...
250swb Posted September 24, 2022 Share #5 Â Posted September 24, 2022 On 9/23/2022 at 8:38 PM, JaKuBe said: Hello. I just have simple question. Is it necessary to adjust rangefinder after top plate removal? I need to replace plastic strap protectors and some repairmans say it is necessary, but I doubt it. I just want to do it quickly and without complicate things a lot more. Thank you. If it ain't broke don't fix it. It's quite simple if it works and focuses 'adjusting' it isn't going to make it better, only the same or worse. Link to post Share on other sites More sharing options...
madNbad Posted September 24, 2022 Share #6 Â Posted September 24, 2022 2 hours ago, Al Brown said: Beg to differ, the last M6 was the number 999 from the "Die Letzten 999", the last 999 M6 Leicas special edition made in 2002, exactly 20 years ago. They were TTLs. Link to post Share on other sites More sharing options...
nitroplait Posted September 25, 2022 Share #7 Â Posted September 25, 2022 Advertisement (gone after registration) On 9/23/2022 at 9:38 PM, JaKuBe said: Hello. I just have simple question. Is it necessary to adjust rangefinder after top plate removal? No - it is not. However adjusting the rangefinder is something that should take max 60 seconds for a qualified tech, thus it shouldn't cost you more than the removal of the top and the cleaning of the inside surfaces (which you would want done when the top is off anyway). If the rangefinder adjustment is a major expense on the estimate, the repair person you are talking to is a crook. Link to post Share on other sites More sharing options...
jakontil Posted September 29, 2022 Share #8  Posted September 29, 2022 I would just do CLA altogether Link to post Share on other sites More sharing options...
