Sagar Posted June 18, 2022 Share #1  Posted June 18, 2022 Advertisement (gone after registration) Looking for some advice on best NON LEICA 28, 35 and 50 mm lenses on M10 Monochrom. Appreciate your feedback in advance Link to post Share on other sites More sharing options...
Advertisement Posted June 18, 2022 Posted June 18, 2022 Hi Sagar, Take a look here Best Non Leica Lenses on Monochrom (M10M)?. I'm sure you'll find what you were looking for!
jaeger Posted June 18, 2022 Share #2 Â Posted June 18, 2022 call the adopted son - voigtlander Link to post Share on other sites More sharing options...
frame-it Posted June 18, 2022 Share #3  Posted June 18, 2022 27 minutes ago, Sagar said: Looking for some advice on best NON LEICA 28, 35 and 50 mm lenses on M10 Monochrom. Appreciate your feedback in advance what do you mean by "Best" ? 1 1 Link to post Share on other sites More sharing options...
rpsawin Posted June 18, 2022 Share #4 Â Posted June 18, 2022 (edited) "what do you mean by "Best" ? I'm with frame-it on this. I am using a Zeiss 50/1.5 C Sonar and really like it. The B&W rendering looks great to my eye. I also have both a 21 & 28 2.8 Biogons but have not shot enough with either to make a definitive statement. I hope this helps. Â Â Â Â Â Â Â Â Edited June 18, 2022 by rpsawin Link to post Share on other sites More sharing options...
egrossman Posted June 18, 2022 Share #5 Â Posted June 18, 2022 I really like the Canon 50mm 1.4 LTM on the M10M (and on the M10D). I think it's one of the biggest lens bargains out there (I paid around $400). Erik 1 Link to post Share on other sites More sharing options...
Olaf_ZG Posted June 18, 2022 Share #6  Posted June 18, 2022 Depends on the look you are after… Link to post Share on other sites More sharing options...
pippy Posted June 18, 2022 Share #7 Â Posted June 18, 2022 Advertisement (gone after registration) Light Lens Lab "8 Element" 35mm f2. Reverse-engineered recreation of the '58-'69 (v1) 35mm Summicron. Philip. 2 Link to post Share on other sites More sharing options...
Keith (M) Posted June 20, 2022 Share #8  Posted June 20, 2022 After well over two years of M10M use, my non-Leica choices would be my 50mm ZM C-Sonnar f1.5 & 35mm VM Nokton III f1.2. PS - the results from the M10M / C-Sonnar combo always remind me of the results from putting a roll of Tri-X through my M7. 1 Link to post Share on other sites More sharing options...
RexGig0 Posted June 20, 2022 Share #9  Posted June 20, 2022 (edited) Something tells me that you would like to try the Zeiss 35mm f/2,8 ZM. 😉 Edited June 20, 2022 by RexGig0 2 Link to post Share on other sites More sharing options...
Jon Warwick Posted June 21, 2022 Share #10  Posted June 21, 2022 On 6/18/2022 at 2:41 PM, Sagar said: Looking for some advice on best NON LEICA 28, 35 and 50 mm lenses on M10 Monochrom. Appreciate your feedback in advance "Best" is subjective, so I can't begin to answer your question, it depends on the rendering and look you want. In my case, my parameters were as much edge-to-edge sharpness and high resolution as possible - with that in mind, I chose a Voigtlander 50mm APO Lanthar, and thoroughly enjoy both its remarkable image quality and excellent construction (eg, really smooth and well-dampened focus ring). I used to own the M 50mm APO Summicron. For me, one benefit of that Leica lens is it is shorter than my Voigtlander, even with the Leica having a built-in hood. But the Voigtlander remains a small lens IMHO. And given the Voigtlander's slightly longer length I have been wondering to myself if it's more telecentric in design and as a result might work better (due to light rays hitting the sensor more directly) on non-M bodies like the SL? (I don't know the answer yet to that idea). I will also be considering a Voigtlander 35mm APO Lanthar in the future. ReidReviews did an in-depth report comparing it to the Leica M 35mm APO Summicron.   Link to post Share on other sites More sharing options...
shirubadanieru Posted June 22, 2022 Share #11 Â Posted June 22, 2022 Nikkor 35mm f1.8 LTM Nikkor 28mm f3.5 LTM Nikkor 35mm f2.5 LTM Nikkor 50mm f2 or f1.4 LTM All the above lenses are great on the MM, and can rival any Leica lens of the same period, while being smaller, and in some cases better looking. On top of that, the 50mm lenses can focus to 0.5m using a system that is similar in practice to the new 35mm APO lens. 2 Link to post Share on other sites More sharing options...
rramesh Posted June 23, 2022 Share #12  Posted June 23, 2022 Depends on what look you are looking for? Every lens has a use. Link to post Share on other sites More sharing options...
henning Posted June 24, 2022 Share #13 Â Posted June 24, 2022 'Best' is an ephemeral term. 'Technically best' are probably the 50 and 35 APO ASPH lenses, followed closely by the Voigtlander equivalents. Not being willing at the moment to spend that much on the former, and not caring for the size/performance tradeoffs of the latter, I use the 50 Summilux ASPH and the Voigtlander 35/2 Ultron v.II. (Note the v.II). Since I have a number of other 35's, such as the 35/2.8 Zeiss (not as good as my Ultron) and the 35/1.4 Zeiss (much better than my 35 Summilux ASPH, but huge), older Summicrons etc I can readily compare. So, if I want a softer look, a Summicron v4 does a good job, or a Voigtlander 35/1.2 first version. For 50's I have a Noctilux f/1, a couple of Summicrons, and a number of Elmars. I have a 28, but it rarely gets used. For the 35 or 50 focal length, any are 'best' at some time, and none are 'best' all the time although I could certainly live with the 50 Summilux ASPH and the 35 Ultron v.II if no other lenses were available. Link to post Share on other sites More sharing options...
Ko.Fe. Posted June 24, 2022 Share #14 Â Posted June 24, 2022 Best for what? Sharpness, range of grey or just been special (totally subjective). Link to post Share on other sites More sharing options...
galleryg Posted June 30, 2022 Share #15 Â Posted June 30, 2022 (edited) I would highly recommend the 35 or 50mm Voigtlander APO Lanthar. I have the 50 and after extensive self tests in comparison to the latest Leica 50mm APO summicron, I sold the Cron because I could not find enough of a quality difference to warrant the price difference. Sure if the prices were closer I would chose the Cron just strictly for continuity with my kit and familiar ergonomics, but when it comes to IQ and performance. the APO Lanthar is absolutely stellar and IMHO equal to the task. YMMV Â PS Selling my Cron allowed me to purchase a much wanted 18mm Super Elmar with the savings along with some new SD cards and an additional Battery for my new M11. It was hard to do but no lingering regrets. Edited June 30, 2022 by galleryg spelling Link to post Share on other sites More sharing options...
intermediatic Posted July 7, 2022 Share #16 Â Posted July 7, 2022 Why don't you get a subscription to Reid Reviews? It's a small price to pay and you can see comparison shots of many of the CV lenses vs Leica lenses, including on M10M. That said, the 35mm Voigtlander APO Lanthar is one of the best lenses available for Leica *period.*Â Link to post Share on other sites More sharing options...
eyeheartny Posted July 8, 2022 Share #17  Posted July 8, 2022 Voigtlander 28 Ultron ASPH and 35 Ultron II are supposed to be outstanding. Performance is equivalent to or better than lenses many times their price. Link to post Share on other sites More sharing options...
Erato Posted July 8, 2022 Share #18  Posted July 8, 2022 (edited) My instinct told me that this is something so-called "shoot and forget threads" and here's the living proof of what it should be as expected.🤩 Edited July 8, 2022 by Erato Link to post Share on other sites More sharing options...
