1 minute ago, lct said:
It switches LV off then or am i missing smething?
If you have manually programmed a FN button to "Center Frame" then when you push the programmed FN button it will simply recenter the focus point back to the center of frame.  I personally think this is a wasted use of a FN button, but for someone else this may be what they see as valuable.  LCT, if when you are pressing the FN button it is turning off the LV off, then it is probably programmed for "Live View" which turns Live View on and off with each press.
14 minutes ago, lct said:
Thank for your help folks but i just want to move the focus point by one click back to the center of the frame. Is it possible otherwise than with the Center Frame option?
Yes program one of your three customizable function buttons to "Center Frame" and then this button is a one click back to center.  Page 60 of the User Manual explains how to change the assignment of the three customizable function buttons.
3 minutes ago, LikameLeica said:
[...] Yes program one of your three customizable function buttons to "Center Frame" [...]
So it is not possible otherwise than with the Center Frame option, right?
Yes but the focus point moves back to the center of the frame this way too. Takes two clicks instead of one but sounds like a good idea. Thank you again for your help 🙂
  1. Center Frame assigned to a function button (one press)
  2. LV on/off (two presses of FN)
  3. Camera on/off (two clicks of power switch)
I keep Center Frame assigned to the thumb wheel press (used less often) and Magnification to the top plate button (used often).
