banjobees Posted April 22, 2022 Share #1 Posted April 22, 2022 Advertisement (gone after registration) Good afternoon- I have a FODUA Leitz Rangefinder (ser.#31383). Image is hazy and coincidence images not very distinct. The end caps are knurled, as are the bezels surrounding the lenses, but they do not seem to unscrew. Would you know the proper way to access the inside to clean the glass? Thanks very much, David Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/331840-seeking-information-on-how-to-clean-inside-of-fodua-long-base-leitz-rangefinder/?do=findComment&comment=4423094'>More sharing options...
Advertisement Posted April 22, 2022 Posted April 22, 2022 Hi banjobees, Take a look here Seeking information on how to clean inside of FODUA long base Leitz Rangefinder. I'm sure you'll find what you were looking for!
jerzy Posted April 23, 2022 Share #2 Posted April 23, 2022 (edited) hello, they are screwed on, you will need wrench to unscrew. This is >80 years old device, most probably never opened before, so all screws are sitting firm. While the glass may be foggy most probably this is not the main reason for dim patch. Most probably beam splitter is corroded, you cannot clean it, it must be replaced. Replacements are available, either new from Japan or adopted from old, scraped rangefinder cameras from garage sales. Very rarely silvering of a prism inside is gone and there is no replacement available. Picture below shows it partially disassembled. Besides optics (orange)' as well caps (blue) are screwed on and if you want to replace beam splitter (green) you need to remove the right one. Afterwards horizontal and vertical adjsutement need to be done, this is separate story, if you decide to do it alone contact me for details Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited April 23, 2022 by jerzy 4 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/331840-seeking-information-on-how-to-clean-inside-of-fodua-long-base-leitz-rangefinder/?do=findComment&comment=4423184'>More sharing options...
banjobees Posted April 23, 2022 Author Share #3 Posted April 23, 2022 Thank-you very much, Jerzy. It took a surprising amount of force to get them unscrewed, but all came apart as you suggested. I cleaned the foggy glass. And, as you suspected, the beam splitter glass is corroded. I wrote to 'nobbysparrow' on eBay to see about a new one. The rangefinder reads accurate distance and the dial turns smoothly. Cosmetically it is in good shape except for slight wear to the lower end-cap and the top inner edge of the locking ring of the distance adjustment screw. I won't be using it but have it for display. However, I came across an interesting method to get a bright split-image for a rangefinder in need of a new beam splitter glass. I tried it on the rangefinder by putting a small piece of tape in the center of the lower ( yellow) window and it does give a strong split image. This is the link: http://rick_oleson.tripod.com/index-165.html Thank-you again, David Quote Link to post Share on other sites More sharing options...
jerzy Posted April 24, 2022 Share #4 Posted April 24, 2022 great, David. I did not know the trick with black dot, it is good. You will not need it for the beam splitter from Japan. They are thinner than original Leica and milticoated, "ghost" image is reduced, patch is sharper and more contrasty as with original Leica beam splitters. There are however some collectors who prefer the "Leica look" and for such case I use beam splitters that are coated like Leitz did it. When mounting into rangefinder the reflecting side has to be on eye side (there is toothpick trick to see which side is coated) and most probably you will need to do adjustments (horizontal, vertical). Quote Link to post Share on other sites More sharing options...
banjobees Posted April 25, 2022 Author Share #5 Posted April 25, 2022 Thank you again, Jerzy. Nobu (knobbysparrow on eBay) said it would take several weeks to arrive- I will write back afterwards. Quote Link to post Share on other sites More sharing options...
banjobees Posted May 4, 2022 Author Share #6 Posted May 4, 2022 The beam splitter from Nobu arrived and replaced the old one without difficulty. The range finder images are sharp and align well without adjustment. It reads accurately from 3-25 feet and seems correct at the longer distances. Thank-you again for your help, Jerzy. David Quote Link to post Share on other sites More sharing options...
sweat100 Posted August 8, 2023 Share #7 Posted August 8, 2023 Advertisement (gone after registration) Bumping this thread, is the replacement of the beamsplitter difficult? How does it attach to the RF? Lastly, is the alignment difficult? Quote Link to post Share on other sites More sharing options...
