11 hours ago, Kwesi said:
1 - that the "glow" is in the lens and not in the M11
Yes and no.
Get ready, this one will be a doozy.
Here's Nokton 40mm, wide open, in a very high contrast situation where it normally exhibits fringing (note - this is NOT longitudinal CA):
Note also that it resolves better on M11 than on M240.
x
Just to keep things interesting (even if a little off topic), here's Nokton vs. Summicron (note - Summicron's FoV is wider) at f/2.0, both shot on M11, 100% crops:
And here's what a Heliar looks like wide open (not that it matters at f/4.5 anyways) on an M11, 100% crop, just to give you an impression of the amount of detail M11 truly captures:
Not sure what you're trying to demonstrate here sorry. "Glow", color fringing or resolution? In any case i would use a single lens to avoid variables and i would upsize M240 pics instead of downsizing M11's as suggested previously. BTW your Nokton lens does exhibit color fringing on the M11 as you can see below.
Yes.
No.
Yes.
