Al Brown Posted January 27, 2022 Share #1 Posted January 27, 2022 (edited) Advertisement (gone after registration) The discontinued Leica Motor M 14408, a very nice little grinding machine with a low torque that does not knock out one of your fillings each time you hit the shutter button of your analog M (unlike the good old bulky 14214 winder pressed against the face), has a well documented weak spot between the grip and the winder housing. The grip handle has been known to come loose and cause your camera to drop. It is easily noticed — the grip handle starts wobbling and eventually disengages. Mine came slightly wobbly from the dealer (he priced it accordingly). As there is no repair manual circulating on the mighty web I have opened up the winder and found the grip handle being held in place by two screws. If you tighten these two screws you are back on track with a firm grip. If the problem persists you can use a little blue loctite on those two screws — they unfortunately represent the weakest link of the entire Portuguese assembly. I used my Phillips screwdriver heads size 000 (for body screws) and 0 (for locking mechanism/spool holder screws). Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited January 27, 2022 by Al Brown 1 2 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/329115-repairingfixing-the-grip-handle-of-the-leica-motor-m-14408-for-mp-m7-m6-md-2-m4-p-m4-2-cameras/?do=findComment&comment=4369507'>More sharing options...
Advertisement Posted January 27, 2022 Posted January 27, 2022 Hi Al Brown, Take a look here Repairing/fixing the grip handle of the Leica Motor M 14408 for MP, M7, M6, MD-2, M4-P & M4-2 Cameras. I'm sure you'll find what you were looking for!
