Dr Cron Posted January 30, 2022 Share #361 Posted January 30, 2022 Advertisement (gone after registration) 49 minutes ago, jonoslack said: Hi There Dr Cron Apparently it says in the manual that the DR is not suitable for the M11, but I wonder if that isn't just a hangover from previous models. Certainly in one of the Wetzlar videos around the launch someone was using one, and that's what inspired me to get one - an unmodified one (but without goggles). It's in perfect condition optically and mint- as far as the body is concerned. You need to mount it to the camera set to about 5ft otherwise it feels pretty graunchy. After that however it's rather magical and works extremely well on the M11. To change to the close focus you pull the lens forward slightly (it's spring loaded) and round the peg at 1 metre. Then just push the ball bearing whilst turning the focus ring and you can use the distances down to a little less than 1/2 Metre. I've had some great results, and it's a lens with real character! As I say, the manual says don't use it, but it seems to work really well. The only limitation is that mounting it needs care with the focus ring set to 5 ft (I haven't tried setting it to infinity). All the best This is great, and many thanks for replying. Since I have the goggles I haven't actually tried pushing the ball down while turning the focus in the close range - I tend to avoid too many physical experiments with such fancy equipment(!) Link to post Share on other sites More sharing options...
Advertisement Posted January 30, 2022 Posted January 30, 2022 Hi Dr Cron, Take a look here Leica M11 Review by Jono Slack. I'm sure you'll find what you were looking for!
shirubadanieru Posted January 31, 2022 Share #362 Posted January 31, 2022 (edited) On 1/30/2022 at 12:22 AM, ELAN said: I do. And it's an issue for me. As stated, the sun is just rising behind me, hardly daylight sky. Click twice on that cropped image for full res and observe the purple fringing. I've never seen so much CA from my Summiluxes before, including the 28 lux. Here's the unedited full image, not really a shot into daylight sky. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Wow this looks more purple than green Just FYI that my summicron 6 elements from 1970 and my summilux 35mm from 1969 have not shown any purple fringing whatsoever with the M11 at this point (I’ve only had the camera for less than a week in my hands though). Edited January 31, 2022 by shirubadanieru Link to post Share on other sites More sharing options...
FrankX Posted February 2, 2022 Share #363 Posted February 2, 2022 (edited) I just read somewhere that you cannot choose any Leica lens that originally was 6 bit coded manually anymore when using an non-coded lens! 😧 For example, you cannot choose a Summicron 35 APO when a VM 35 mm APO is attached. Is this really true for the M11 (and M10R/M already)?? Edited February 2, 2022 by FrankX Link to post Share on other sites More sharing options...
adan Posted February 3, 2022 Share #364 Posted February 3, 2022 It's pretty much always been that way - no point (from Leica's point of view) in having a selection for Leica lenses that never existed in uncoded form. (And Leica is not in business to accomodate other brands' lenses ) Fortunately, VM lenses (and later Zeisses, and maybe some others) have a nice protective channel machined into the back surface of their mounts, for fairly permanent manual coding marks made by users. Link to post Share on other sites More sharing options...
meerec Posted February 3, 2022 Share #365 Posted February 3, 2022 5 hours ago, FrankX said: For example, you cannot choose a Summicron 35 APO when a VM 35 mm APO is attached. I’m pretty sure it’s not true. I’ve just checked on my M11. I mounted VM 10mm and set this up as WATE 16mm in the settings. I actually like the super wide 10mm Voigtländer lens on the M11. 1 Link to post Share on other sites More sharing options...
FrankX Posted February 3, 2022 Share #366 Posted February 3, 2022 vor 6 Stunden schrieb adan: It's pretty much always been that way - no point (from Leica's point of view) in having a selection for Leica lenses that never existed in uncoded form. (And Leica is not in business to accomodate other brands' lenses ) Fortunately, VM lenses (and later Zeisses, and maybe some others) have a nice protective channel machined into the back surface of their mounts, for fairly permanent manual coding marks made by users. That’s definitely not correct! For example, with my SL2 I can select a Summicron 35 APO manually. Maybe it was just a misunderstanding… Of course, I cannot choose a VM 35 APO, but at least something similar from Leica. Link to post Share on other sites More sharing options...
meerec Posted February 3, 2022 Share #367 Posted February 3, 2022 Advertisement (gone after registration) 56 minutes ago, FrankX said: That’s definitely not correct! For example, with my SL2 I can select a Summicron 35 APO manually. Maybe it was just a misunderstanding… Of course, I cannot choose a VM 35 APO, but at least something similar from Leica. I am then not sure I understood you correctly. Here is what I do again in more detail…I’m mounting the VM10 lens on my M11 (just like I can do on my SL2). The next step is to select a suitable Leica M lens to match if we want to hope the software corrections in the firmware will apply some ‘magic’ to rendering. The closest Leica M lens is the WATE, there is nothing wider that this. So I choose it to be applied as profile for my Voigtländer. I am able to do it on my SL2 and it works just the same way on the M11. The results are fine, I mean I like what I get. And I haven’t compared the outcome with and without the profile. I’m not that investigative or interested. Link to post Share on other sites More sharing options...
adan Posted February 3, 2022 Share #368 Posted February 3, 2022 1 hour ago, FrankX said: That’s definitely not correct! For example, with my SL2 I can select a Summicron 35 APO manually On an SL2, perhaps - but if you note the title of this part of the forum, it is about the M system cameras. Which operate differently (and always have), since the M lenses are "native" only to the M system. Link to post Share on other sites More sharing options...
Daedalus2000 Posted February 3, 2022 Share #369 Posted February 3, 2022 12 hours ago, FrankX said: I just read somewhere that you cannot choose any Leica lens that originally was 6 bit coded manually anymore when using an non-coded lens! 😧 For example, you cannot choose a Summicron 35 APO when a VM 35 mm APO is attached. Is this really true for the M11 (and M10R/M already)?? Yes that seems to be true in M11. Using a non-coded VG lens, I cannot find the Leica 35 APO which I think is 11699 Link to post Share on other sites More sharing options...
Edax Posted February 3, 2022 Share #370 Posted February 3, 2022 13 hours ago, FrankX said: I just read somewhere that you cannot choose any Leica lens that originally was 6 bit coded manually anymore when using an non-coded lens! 😧 For example, you cannot choose a Summicron 35 APO when a VM 35 mm APO is attached. Is this really true for the M11 (and M10R/M already)?? A little OT, but I 6-bit coded a VM35APO as 35mm APO-summicron-M. The result was not good (on the M10); greenish tint in the extreme corners. Link to post Share on other sites More sharing options...
FrankX Posted February 3, 2022 Share #371 Posted February 3, 2022 vor 2 Stunden schrieb meerec: I am then not sure I understood you correctly. Here is what I do again in more detail…I’m mounting the VM10 lens on my M11 (just like I can do on my SL2). The next step is to select a suitable Leica M lens to match if we want to hope the software corrections in the firmware will apply some ‘magic’ to rendering. The closest Leica M lens is the WATE, there is nothing wider that this. So I choose it to be applied as profile for my Voigtländer. I am able to do it on my SL2 and it works just the same way on the M11. The results are fine, I mean I like what I get. And I haven’t compared the outcome with and without the profile. I’m not that investigative or interested. My response wasn’t to your reply! I think you understood it correctly. The only thing I don’t know is if the WATE is a lens which was available without coding at the beginning. Therefore I used as an example the 35 APO Summicron. Link to post Share on other sites More sharing options...
FrankX Posted February 3, 2022 Share #372 Posted February 3, 2022 vor 4 Stunden schrieb adan: On an SL2, perhaps - but if you note the title of this part of the forum, it is about the M system cameras. Which operate differently (and always have), since the M lenses are "native" only to the M system. You’re right! Thanks for clarification! Wasn’t aware that an SL2 with Leica M/L-adapter behaves differently! My M10 also doesn’t list the newer lenses. Link to post Share on other sites More sharing options...
adan Posted February 3, 2022 Share #373 Posted February 3, 2022 6 hours ago, FrankX said: The only thing I don’t know is if the WATE is a lens which was available without coding at the beginning. The WATE has always been 6-bit coded (as has the 28 Elmarit-M ASPH) - they were introduced along with the M8 and were the first lenses made only in coded form. But since it provides 3 different focal lengths, it still has to be in the lens menu, to identify which specific focal length is actually in use for any given picture. "16-18-21 Tri-Elmar at 21mm" etc. It is an oddball in that way. As to: 7 hours ago, Edax said: A little OT, but I 6-bit coded a VM35APO as 35mm APO-summicron-M. The result was not good (on the M10); greenish tint in the extreme corners. ... yes. The 6-bit coding and the corrections it produces are targeted at specific Leica optical designs and light paths, not lens names or even generic lens types (e.g. "APO"). Not all "APO-35mms" are the same design - so the coding won't treat their various images the same. 2 Link to post Share on other sites More sharing options...
jonoslack Posted February 3, 2022 Author Share #374 Posted February 3, 2022 15 minutes ago, adan said: The WATE has always been 6-bit coded (as has the 28 Elmarit-M ASPH) - they were introduced along with the M8 and were the first lenses made only in coded form. But since it provides 3 different focal lengths, it still has to be in the lens menu, to identify which specific focal length is actually in use for any given picture. "16-18-21 Tri-Elmar at 21mm" etc. It is an oddball in that way. Thanks Andy You've put it all so clearly! best Link to post Share on other sites More sharing options...
Edax Posted February 3, 2022 Share #375 Posted February 3, 2022 2 hours ago, adan said: As to: ... yes. The 6-bit coding and the corrections it produces are targeted at specific Leica optical designs and light paths, not lens names or even generic lens types (e.g. "APO"). Not all "APO-35mms" are the same design - so the coding won't treat their various images the same. YES I KNOW. Only by trying out one can find out if a profile is suitable for a lens. The 'normal' 35mm ASPH profile encodes too much distortion for the VC35APO (of course that can be corrected by hand in LR), so that is why I gave it a try. B.T.W. the APO-Summicron-M 50mm profile works well for the VC50APO... Link to post Share on other sites More sharing options...
Daedalus2000 Posted February 3, 2022 Share #376 Posted February 3, 2022 5 hours ago, adan said: The WATE has always been 6-bit coded (as has the 28 Elmarit-M ASPH) - they were introduced along with the M8 and were the first lenses made only in coded form. But since it provides 3 different focal lengths, it still has to be in the lens menu, to identify which specific focal length is actually in use for any given picture. "16-18-21 Tri-Elmar at 21mm" etc. It is an oddball in that way. As to: ... yes. The 6-bit coding and the corrections it produces are targeted at specific Leica optical designs and light paths, not lens names or even generic lens types (e.g. "APO"). Not all "APO-35mms" are the same design - so the coding won't treat their various images the same. So is the 35mm APO only an APO after software corrections? Link to post Share on other sites More sharing options...
Tailwagger Posted February 3, 2022 Share #377 Posted February 3, 2022 The other issue... upcoming issue as its not there yet... with uncoded optics relates to PC which relies on knowing the focal length to do its thing. Though, it's an interesting question as to whether or not it matters. I never tried it, but as the M stores the numbers needed for corrections, regardless of whether you enable it or not, you might be able to set the profile after upload to LR and still have PC operations work properly. Link to post Share on other sites More sharing options...
Tailwagger Posted February 4, 2022 Share #378 Posted February 4, 2022 23 hours ago, adan said: (And Leica is not in business to accomodate other brands' lenses ) IMO retirement of this policy is long over due. We're getting to the point where the lens info is becoming more and more important, the Zeiss and CV lenses really aren't competing with Leica offerings and the tech is so rudimentary that it deserves a rethink anyway. At the very least, it would be nice if the user could create a set of labels/focal lengths for non-Leica lens that wind up in the selection menu. When a uncoded lens is detected, for non-Leica glass, the user could simply select one of their own tags. Of course no corrections would be applied in camera, but could be applied in LR or C1 after the fact. This would eliminate applying incorrect alterations in camera, but still afford focal length info which, again, is important for PC. 3 Link to post Share on other sites More sharing options...
adan Posted February 4, 2022 Share #379 Posted February 4, 2022 Well, Leica will do whatever Leica wants to do. Frankly, I have two C/V lenses - and they are actually easier to work with than uncoded Leitz/Leica lenses. Hand-coding the C/Vs took about 10 minutes each. 35mm Nokton coded as 35 Summicron v.4, and 75 f/1.5 coded as a 75 Summilux. Easy-peasy. A nice machined channel to put the coding-marks into and have them last a long time (about 1.5 years so far with no signs of wearing off) - and thus no need to waste time and miss shots menu-diving. 1 Link to post Share on other sites More sharing options...
hdmesa Posted February 4, 2022 Share #380 Posted February 4, 2022 3 hours ago, Daedalus2000 said: So is the 35mm APO only an APO after software corrections? No. It's still APO. APO has nothing to do with distortion or tint corrections. 1 1 Link to post Share on other sites More sharing options...
