LUF Admin Posted January 13, 2022 Share #1 Posted January 13, 2022 Advertisement (gone after registration) Leica M11 Technical Specification Camera typeDigital system camera with rangefinderType no.2416Order No.Black: 20 200 (EU/US/CN), 20 202 (JP), 20 206 (ROW) Silver: 20 201 (EU/US/CN), 20 203 (JP), 20 207 (ROW)Buffer memory3 GB DNG™: 15 recordings JPG: > 100 recordingsStorage mediumUHS-II (recommended), UHS-I, SD/SDHC/SDXC memory card (SDXC cards up to 2 TB, internal memory 64 GB)MaterialBlack: full-metal housing made of magnesium and aluminum, leatherette coverSilver: full-metal housing made of magnesium and brass, leatherette coverLens mountLeica M bayonet with additional sensor for 6-bit encodingOperating conditions+0 to +40°CInterfacesISO accessory shoe with additional control contacts for Leica flash units and Leica Visoflex 2 viewfinder (optional accessory), USB 3.1 Gen1 Typ-CTripod threadA 1⁄4 DIN 4503 (1⁄4”) with stainless steel in the baseDimensionsapprox. 139 x 38,5 x 80mmWeight Black: approx. 530 g/455 g (with/without battery)Silver: approx. 640 g/565 g (with/without battery)SensorSensor sizeCMOS sensor, pixel pitch: 3.76 μm, 35 mm: 9528 x 6328 pixels (60.3 MP)ProcessorLeica Maestro series (Maestro III)FilterRGB color filter, UV/IR filter, no low-pass filterFile formatsDNG™ (raw data, loss-free compression), DNG + JPG, JPG (DCF, Exif 2.30)Image resolutionDNG™ L-DNG 60.3 MP 9528 x 6328 pixelsM-DNG 36.5 MP 7416 x 4928 pixelsS-DNG 18.4 MP 5272 x 3498 pixelsJPG L-JPG 60.1 MP 9504 x 6320 pixelsM-JPG 36.2 MP 7392 x 4896 pixelsS-JPG 18.2 MP 5248 x 3472 pixelsThe entire sensor surface will always be used irrespective of format and resolution. Digital Zoom 1.3x and 1.8x available (always based on L-DNG or L-JPG)File sizeDNG™ L-DNG 60.3 MPM-DNG 36.5 MPS-DNG 18.4 MPJPG L-JPG 60.1 MPM-JPG 36.2 MPS-JPG 18.2 MPJPG: depending on resolution and image contentColor depthDNGTM: 14 bit, JPG: 8 bitColor spacesRGBViewfinder/LCD panelViewfinderLarge, bright-line rangefinder with automatic parallax compensation, suitable for -0.5 dpt; optional corrective lenses available: -3 to +3 dptDisplayFour-digit digital display with items show on the top and bottom, Image field limiter: two lit frames: 35 mm + 135 mm, 28 mm + 90 mm, 50 mm + 75 mm (automatic switchover when lens is attached)Parallax compensationThe horizontal and vertical difference between viewfinder and lens is compensated automatically in line with the relevant focus setting. Congruence of viewfinder and actual image. The size of the bright-line frame matches the distance:– at 2 m: the exact sensor size of approx. 23.9 x 35.8 mm– at infinity: (depending on focal length) approx. 7.3% (28 mm) to 18% (135 – less than 2 m: less than sensor sizeViewfinder magnificationx0.73 (all lenses)Large-base rangefinderSplit or superimposed image rangefinder shown as a bright field at the center of the viewfinder imageLCD panel2.95” (Active Matrix TFT), Gorilla Glass 5 cover glass, 2 332 800 dots, format 3:2, touch control availableShutterShutter typeElectronically controlled focal plane shutter and electronic shutter functionShutter speedsElectronically controlled focal plane shutter and electronic shutter functionMech. shutter: 60 min to 1⁄4000 sElectro. shutter function: 60 s to 1⁄16000 sFlash Synch: up to 1⁄180 sOptional noise reduction via additional “black picture” (can be disabled)Shutter buttonTwo-stage(1st stage: activation of the camera electronics including exposure metering and metering memory lock, 2nd stage: taking the picture)Self-timerDelay time: 2 s or 12 sDrive ModeSingleContinuous - Low Speed (3 fps)Continuous - High Speed (4.5 fps)Intervall ShootingExposure BracketingFocusingFocus range70 cm to ∞Focus modeManual (focus assist functions Magnification and Focus Peaking available)ExposureExposure meteringTTL (exposure metering through the lens), with working apertureMetering principleExposure metering is done by the image sensor for all exposure metering methods (in Live View mode and in rangefinder mode)Exposure metering methodsSpot, Center-Weighted, Multi-FieldExposure modesAperture priority mode (A): Automatic shutter speed control with manual aperture preselectionManual (M): manual setting for shutter speed and apertureExposure compensation±3 EV in 1⁄3 EV incrementsAutomatic bracketing3 or 5 shots, graduations between shoots up to 3 EV, in 1⁄3 EV increments, additional optional exposure compensation: up to ±3 EVISO sensitivity rangeAuto ISO: IS0 64 (native) to ISO 50 000, also available in flash mode Manual: ISO 64 to ISO 50,000White balanceAutomatic (Auto), Default (Daylight - 5200 K, Cloudy - 6100 K, Shadow - 6600 K, Tungsten - 2950 K, HMI - 5700 K, Fluorescent (warm) - 3650 K, Fluorescent (cool) - 5800 K, Flash - 6600 K), manual metering (Gray card), manual color temperature setting (Color Temperature, 2000 K to 11,500 K)FlashFlash unit connectorVia the accessory shoeMetering principleFlash exposure metering is done by the image sensor for all exposure metering methods (in Live View mode and in rangefinder mode)Flash sync time1⁄180 s, slower shutter speeds available, automatic switchover to TTL linear flash mode with HSS-compatible Leica system flash units if sync time is undercutFlash exposure meteringUsing center-weighted TTL pre-flash metering with Leica flash units (SF 26, SF 40, SF 58, SF 60, SF 64) or with system-compatible flash units, remote controlled flash SF C1Flash exposure compensationSF 40: ±2 EV in 1⁄2 EV incrementsSF 60: ±2 EV in 1⁄3 EV incrementsOther: ±3 EV in 1⁄3 EV incrementsDisplays in flash mode (in the viewfinder only)Flash icon: Connection of an external flash unitEquipmentWLANThe Leica FOTOS app is required to use the WLAN function. The Leica app is available from the Apple App StoreTM or the Google Play StoreTM. 2.4 GHz/5 GHz* dual band IEEE802.11 a/b/g/n/ac Wave2 WLAN (standard WLAN protocol), encryption method: WLAN-kompatible WPATM/WPA2TM, access method: infrastructure modeBluetooth*Bluetooth v4.2 BR/EDR/LE, BR/DR-channel 1-79, LE-channel 0-39 (2402–2480 MHz)GPS*Geotagging via Leica FOTOS app using Bluetooth* Available after Firmware Update during second half of 2022 Menu languagesEnglish, German, French, Italian, Spanish, Russian, Japanese, Simplified Chinese, Traditional Chinese, Korean, PortuguesePower supplyRechargeable battery (Leica BP-SCL7)Li-Ion (Lithium-Polymer) rechargeable battery, rated voltage: 7.4 V / capacity: 1800 mAh, Charging voltage/current: DC 1000 mAh, 7.4 V, operating conditions: +10°C to +35°C (charging) / +0°C to +40°C (discharged), manufacturer: Fuji Electronics (Shenzhen) Co., Ltd. made in ChinaApprox. 700 shots (in accordance with CIPA Standard in rangefinder mode), up to approx. 1700 shots (Leica adapted shooting cycle)Charger (Leica BC-SCL7)Input: USB-C DC 5 V, 2 A, output: DC 8.4 V, 1 A, operating conditions: +10°C to +35°C, manufacturer: Dee Van Enterprises Co., Ltd.., made in ChinaPower pack (Leica ACA-SCL7Input: AC 110 V - 240 V ~ 50/60 Hz, 0.3 A, output: DC 5 V, 2 A, operating conditions: +10°C to +35°C, manufacturer: Dee Van Enterprises Co., Ltd.., made in ChinaUSB Power supplyWhen in standby mode or Off: USB charging functionWhen On: USB power supply and intermittent charging The official Leica Camera press release: The new Leica M11 – A Legend reinvented. Wetzlar, 13th January 2022. The new Leica M11 combines the experience of traditional rangefinder photography with contemporary camera technology, delivering a maximum of flexibility to every photographer. Featuring an exclusive triple resolution sensor, expanded ISO range, dual memory, extended battery life and a streamlined and intuitive menu system, the Leica M11 represents a new benchmark in digital photography and the most flexible M-System camera in Leica’s storied history. At the heart of the new Leica M11 is a full-frame BSI CMOS sensor with Triple Resolution Technology. Raw image files in DNG format and JPEGs can be recorded at 60, 36 or 18 megapixels, always using the full sensor area. The 60-megapixel option delivers unprecedented image quality and detail resolution, exploiting the full optical potential of Leica’s latest APO Lenses for the M-System – whereas the lower resolutions enable faster camera performance, extended burst lengths, and smaller files. A special IR + UV cut filter – comprising of two extremely thin, cemented layers of glass – achieve an especially effective correction of even the most oblique rays of incident light. Thanks to a new color filter array, the camera also offers an improved, more natural color reproduction. While maintaining the iconic look of a traditional Leica M, the carefully optimized design of the Leica M11 is focused on efficiency and ergonomics. The controls have been arranged in a unique layout around the new, 2.3 million pixels, high-resolution touchscreen. The menu structure of the M11 remains consistent with that of the Leica SL2 and Q2, unifying the acclaimed interface for a more user-friendly experience. The Leica M11 has a sensitivity range of ISO 64 to 50,000; it records a 14-bit color depth and has a dynamic range of up to 15 stops. With its Maestro III processor, the Leica M11 offers a fluid and responsive operation, even at the highest resolution and image quality. With the optional electronic shutter featuring a shutter speed of up to 1/16000 of a second, photographers are empowered to work with wide open apertures, in bright light - without ND filters. The M11 marks the first time multi-field metering in rangefinder mode will be available, affording photographers a valuable tool to curate light. The black-finish variant of the Leica M11 features a top plate made of high-quality aluminium with an especially scratch-resistant coating, resulting in a body that is approximately 20% (100 grams) lighter than its silver-chrome counterpart. By comparison, the silver-chrome M11 features a classic brass top plate and weighs in at 640 grams. Unique to the M11 is the deliberate omission of the traditional base plate, offering photographers easy direct access to the battery and SD card. In addition to the SD card slot, the Leica M11 is equipped with a generous internal storage capacity of 64 gigabytes. As a result, the M11 is the first M model to save image files simultaneously onto two different storage media. The 1800mAh battery stores 64% more energy than before, and combined with the camera’s more efficient operation, allows for considerably longer shooting sessions with a single charge. In addition, the newly added universal USB-C port also serves to charge the camera’s battery, using most USB-C chargers. Upgraded connectivity features of the Leica M11 will be available through a new firmware version in the second half of 2022. This will enable the new M11’s advanced connectivity capabilities that will elevate users' mobile workflows and enhance the Leica FOTOS app with the possibility to embed location data, access images via Bluetooth connection, and allow increased transfer rates. Moreover, the Leica M11 is already an Apple “Made for iPhone and iPad” certified accessory and as such, offers unique abilities with the included Leica FOTOS cable. With the evolution of the Leica M comes new accessories to enhance the rangefinder experience. The new Visoflex 2 electronic viewfinder features 3.7-megapixel resolution to provide outstanding image control in Live View mode. Encased in a metal exterior, the Visoflex 2 perfectly matches the M11 in terms of design and functionality. Full-frame viewing and the precise focusing of Leica lenses is supported by the Visoflex 2’s large diopter adjustment range of -4 to +3 and 90 degree tilt function. To improve ergonomics without obstructing access to the battery and SD card, photographers will have the option to complement their M11 with a newly designed handgrip. The new handgrip doubles as a tripod mount, where the Leica M11 can be attached to Arca-Swiss-standard tripod heads without the need for any additional equipment. Leica M11: Witness the Future “We are very proud of the new M11,” says Stefan Daniel, Executive Vice President Technology and Operations. “This camera is another milestone for Leica. Its inner workings are a completely new development, while the exterior remains true to the iconic Leica M design.” “As we all know,” says Dr. Andreas Kaufmann, Chairman of the Supervisory Board of Leica Camera AG, Wetzlar, “the iconic Leica M-System has accompanied dedicated photographers worldwide over decades, giving them a superior tool for witnessing their time and creating outstanding pictures. The new M11 will continue this legacy with outstanding technology, based on the experience since 1925.” The Leica M11 is available worldwide as of January 13, 2022. 1 Link to post Share on other sites More sharing options...
Advertisement Posted January 13, 2022 Posted January 13, 2022 Hi LUF Admin, Take a look here Leica M11: Technical Spec and Official Press Release . I'm sure you'll find what you were looking for!
sebben Posted January 13, 2022 Share #2 Posted January 13, 2022 Price? Link to post Share on other sites More sharing options...
surfmanjoe Posted January 13, 2022 Share #3 Posted January 13, 2022 2 minutes ago, sebben said: Price? Must be around US$9000. Link to post Share on other sites More sharing options...
LUF Admin Posted January 13, 2022 Author Share #4 Posted January 13, 2022 vor 4 Minuten schrieb sebben: Price? 8350 € $ 8995 1 Link to post Share on other sites More sharing options...
Chris W Posted January 13, 2022 Share #5 Posted January 13, 2022 £7500 in the UK. Not as bad as I thought it would be. 1 Link to post Share on other sites More sharing options...
Antema Posted January 13, 2022 Share #6 Posted January 13, 2022 Sensor cleaning? Link to post Share on other sites More sharing options...
SrMi Posted January 13, 2022 Share #7 Posted January 13, 2022 Advertisement (gone after registration) 1 hour ago, Antema said: Sensor cleaning? By hand :). 2 Link to post Share on other sites More sharing options...
fenykepesz Posted January 13, 2022 Share #8 Posted January 13, 2022 what i don't understand is that the OPERATING CONDITIONS are from 0°C till +40°C ? i use my M10-D here in Montréal regularly out in the cold, that's -20°C or less even, and the camera seems to live with it just fine. although i just looked at its specs (for the M10-D), and they also show 0°C till +40°C - so i am now a bit baffled...? 1 Link to post Share on other sites More sharing options...
SrMi Posted January 13, 2022 Share #9 Posted January 13, 2022 11 minutes ago, fenykepesz said: what i don't understand is that the OPERATING CONDITIONS are from 0°C till +40°C ? i use my M10-D here in Montréal regularly out in the cold, that's -20°C or less even, and the camera seems to live with it just fine. although i just looked at its specs (for the M10-D), and they also show 0°C till +40°C - so i am now a bit baffled...? Nikon Z series and DSLRs have all specified 0 to 40C. I have used my D850 at -25C without any problems, though I had some issues with a Nikon zoom lens. No need to worry. 1 Link to post Share on other sites More sharing options...
Tailwagger Posted January 13, 2022 Share #10 Posted January 13, 2022 Has anyone managed to find a download for the user manual on the camera? US has quick start and tech spec PDFs, but no full manual yet. Link to post Share on other sites More sharing options...
rramesh Posted January 14, 2022 Share #11 Posted January 14, 2022 Is there a level gauge? Link to post Share on other sites More sharing options...
SrMi Posted January 14, 2022 Share #12 Posted January 14, 2022 20 minutes ago, rramesh said: Is there a level gauge? Yes Link to post Share on other sites More sharing options...
Keek Posted January 14, 2022 Share #13 Posted January 14, 2022 Does the shutter stay open all the time, also when changing lenses, and does it close only when taking a photo, or does it work like in the M10? Link to post Share on other sites More sharing options...
elmars Posted January 14, 2022 Share #14 Posted January 14, 2022 It stays open. 1 Link to post Share on other sites More sharing options...
sdk Posted January 14, 2022 Share #15 Posted January 14, 2022 On 1/13/2022 at 10:07 AM, LUF Admin said: 8350 € $ 8995 B&H still has the M10-R priced the same as the M11, both US $8995. If the M10-R were discounted a thousand or two that might be attractive, but it should definitely be far less expensive than the M11. Link to post Share on other sites More sharing options...
sdk Posted January 14, 2022 Share #16 Posted January 14, 2022 2 hours ago, elmars said: It stays open. That does not seem correct. It does have a mechanical shutter as well as an electronic shutter function. You really would want the sensor covered when changing lenses especially outside. Link to post Share on other sites More sharing options...
SrMi Posted January 14, 2022 Share #17 Posted January 14, 2022 9 minutes ago, sdk said: That does not seem correct. It does have a mechanical shutter as well as an electronic shutter function. You really would want the sensor covered when changing lenses especially outside. It closes once you turn off the camera. Link to post Share on other sites More sharing options...
V23 Posted January 15, 2022 Share #18 Posted January 15, 2022 13 hours ago, sdk said: B&H still has the M10-R priced the same as the M11, both US $8995. If the M10-R were discounted a thousand or two that might be attractive, but it should definitely be far less expensive than the M11. The same pricing structure in Australia. Link to post Share on other sites More sharing options...
Robert Blanko Posted January 16, 2022 Share #19 Posted January 16, 2022 Will the old visoflex 020 work with the M11? Just wondering, as the 020 has built-in GPS (the new visoflex does not seem to provide GPS) and for the rare usage would be still ok. Link to post Share on other sites More sharing options...
SrMi Posted January 16, 2022 Share #20 Posted January 16, 2022 5 hours ago, Robert Blanko said: Will the old visoflex 020 work with the M11? Just wondering, as the 020 has built-in GPS (the new visoflex does not seem to provide GPS) and for the rare usage would be still ok. No. Link to post Share on other sites More sharing options...
