KateStarr Posted November 17, 2021 Share #1 Posted November 17, 2021 Advertisement (gone after registration) I recently purchased a used 35mm Lux FLE (11663) and noticed some strange vignetting going on. I would certainly expect some vignetting in the corners wide open, but to my eye this looks different. Almost as if the lens hood is getting in the shot or something. Has anyone seen this before or know what's going on? Could it be the lens came with the wrong hood? The example below was taken at f2.8 and the lens corrections were applied in Lightroom. You can clearly see the vignetting I'm talking about in the upper corners, especially the left. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/326682-35mm-lux-fle-strange-vignetting/?do=findComment&comment=4315291'>More sharing options...
Advertisement Posted November 17, 2021 Posted November 17, 2021 Hi KateStarr, Take a look here 35mm Lux FLE strange vignetting?. I'm sure you'll find what you were looking for!
TeleElmar135mm Posted November 17, 2021 Share #2 Posted November 17, 2021 vor 4 Minuten schrieb KateStarr: I recently purchased a used 35mm Lux FLE (11663) and noticed some strange vignetting going on. I would certainly expect some vignetting in the corners wide open, but to my eye this looks different. Almost as if the lens hood is getting in the shot or something. Has anyone seen this before or know what's going on? Could it be the lens came with the wrong hood? The example below was taken at f2.8 and the lens corrections were applied in Lightroom. You can clearly see the vignetting I'm talking about in the upper corners, especially the left. Strange for 2,8 - make a little test: Remove the hood and make some test shots. It it's gone it's the hood. nd make some shots at 5.8, 8 and so on and look, of the vignetting is still be present. Then it's a case for the CS Link to post Share on other sites More sharing options...
KateStarr Posted November 17, 2021 Author Share #3 Posted November 17, 2021 Good idea, thanks. I'll get out and do some testing later today. In the meantime, I checked the part number of the hood and it seems to be the correct one. That doesn't mean it isn't the problem, but still. Thanks again. Link to post Share on other sites More sharing options...
UliWer Posted November 17, 2021 Share #4 Posted November 17, 2021 (edited) When I did my "stress test" for looking at vignetting with an opaque object just in front of the lens with f/2.8 I can see some vignetting, but the lens hood does not make any difference. My method strongly exaggerates the amount of vignetting, in normal usage there will be much, much less. When I look a your photos, I'd say there is too much. It looks as if the hood was not in its proper position. Both examples with 35mm FLE at f 2.8 and M10 Monochrom: with hood f/2.8: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! without hood f 2.8: Edited November 17, 2021 by UliWer Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! without hood f 2.8: ' data-webShareUrl='https://www.l-camera-forum.com/topic/326682-35mm-lux-fle-strange-vignetting/?do=findComment&comment=4315318'>More sharing options...
KateStarr Posted November 17, 2021 Author Share #5 Posted November 17, 2021 @UliWer Thanks for doing that test. Did you apply the lens corrections to both of those examples? Link to post Share on other sites More sharing options...
UliWer Posted November 17, 2021 Share #6 Posted November 17, 2021 Yes, lens was automatically detected. How on your example? Link to post Share on other sites More sharing options...
KateStarr Posted November 17, 2021 Author Share #7 Posted November 17, 2021 Advertisement (gone after registration) Yes, the lens corrections were applied in my example, which is why I was surprised that the vignetting is still so prominent. Link to post Share on other sites More sharing options...
evikne Posted November 17, 2021 Share #8 Posted November 17, 2021 (edited) Ken Rockwell writes about the 35 FLE here: https://www.kenrockwell.com/leica/35mm-f14-floating-element.htm#fo His test shots are quite similar to yours at f/2.8 without any lens profile, but with the proper lens profile it's considerably better. Edited November 17, 2021 by evikne Link to post Share on other sites More sharing options...
a.noctilux Posted November 17, 2021 Share #9 Posted November 17, 2021 Hello Kate, did you use filter ? Link to post Share on other sites More sharing options...
UliWer Posted November 17, 2021 Share #10 Posted November 17, 2021 (edited) This is a photo recently made with the 35mm FLE. The EXIF tells me f/3.4 - may be right, but could be f/2.8 as well. The example is not ideal as the sky is very dark. There is some vignetting, but I don't see it as pronounced as on your example: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited November 17, 2021 by UliWer Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/326682-35mm-lux-fle-strange-vignetting/?do=findComment&comment=4315344'>More sharing options...
KateStarr Posted November 17, 2021 Author Share #11 Posted November 17, 2021 Thanks everyone for your input! @evikne I double checked that the correct lens profile was applied, but I'm not 100% sure I shot it at f2.8. That sounds right to me, but I don't know for certain. I'll take some test shots this afternoon so I'll have some examples where I can be certain of the apertures I used. @a.noctilux I did not use a filter. When I first saw the files it looked to me like the same effect you get sometimes with a filter, which is why I suspected the lens hood was the wrong size. Stepping outside to shoot some samples now. Link to post Share on other sites More sharing options...
a.noctilux Posted November 17, 2021 Share #12 Posted November 17, 2021 So no filter. Thanks for clarification. In my view, not the adapted hood can give this sort of vignetting. Link to post Share on other sites More sharing options...
sarav Posted November 17, 2021 Share #13 Posted November 17, 2021 Did you try it in another M-Body? Link to post Share on other sites More sharing options...
KateStarr Posted November 17, 2021 Author Share #14 Posted November 17, 2021 Well, I did some very unscientific testing at f1.4, 2, 2.8, 4, 5.6 and 8 - with the hood and without - and the strange vignetting is there throughout. It almost seems like it is worst at f2.8, but it's still apparent at f5.6. Today is the last day I can return the lens for a refund, which is what I've decided to do. Thanks again, everyone, for all of your help. Link to post Share on other sites More sharing options...
