Hello everyone, here's my review of the new Carl Zeiss Contax G Planar 35mm f/2 FUNLEADER conversion to Leica M.
This is my first review here so I am not used to the technicalities of posting, please forgive me if I readjust things after I post.
FUNLEADER Contax G35 to Leica M Conversions
I have included the 7artisans 35mm f/1.4 M and the Voigtlander VM 40mm f/1.2, the only lenses in the 35mm zone I own.
Disclaimers:
1. none of the lens makers / converters have been involved in these tests and I have personally purchased all 3 lenses, none of them have been provided.
2. the FUNLEADER link above contains an affiliate link with a code that will get you a 5% discount (used to be 15%, I hope they bring that back). If you purchase using the link above FUNLEADER says I will receive 10%.
3. all opinions expressed here are my own and, just like with anything in life (especially photography equipment!), you may have a different one.
A few bullet points about the tests:
- done on my Leica M-P typ 240
- done on a tripod with a 2 second timer to hopefully dampen most vibrations
- no filters or hoods were used and lenses were extremely clean
- captured at M-P's base ISO: 200 (with the exception of a few frames captured at 1.2 and 1.4 because 1/4000 was too slow to keep equal exposures so I set the ISO to PULL 100)
- exposure was manual and the exposure time was adjusted accordingly with every aperture change (generally 2/3 stop) in order to hopefully maintain an even exposure between the samples
- white balance was on AUTO
- all focus was EXTREMELY CAREFULLY done using LIVE VIEW at f/2 for each lens, using both the focus peaking and my own eyes to make sure I get the best possible focus
- focus was redone with every lens change
- the 40mm was repositioned so that the main subject filled roughly the same size in the photos (as much as possible, the infinity tests obviously show the difference in focal length)
- most tests were taken all all apertures but since this ended up requiring so much work I only included up to f/8, to be honest I don't think anything past that is relevant
- all samples processed in Capture 1 PRO with the default output sharpening for screen (any image processor will apply some sort of sharpening from DNG to JPG)
- I am sharing a Google Drive folder with all DNGs, JPGs, comparisons and misc images, all full size. Please check them out and use them for free, a credit would be nice if you end up posting them.
PART 1 / 5
A morsel of history: if you're reading this you most likely know what this lens is, otherwise this info can be easily found online.
The G35/2 is supposed to be the "lesser performer" of the Contax G suite, the internet is funny like that, some person deemed it once as not being as stellar as the G45/2 (which is whispered to be one of the best lenses in 35mm photography history) and the internet has taken that and transformed it into "not a good lens" kind of rumour. I am here to prove otherwise.
Here's a G35 / G45 specs comparison:
This 35 together with the Hologon 16mm are the only ones I do not own in G mount. I have shot all the other ones (21/2.8, 28/2.8, 45/2, 90/2.8) on my Contax G2 and adapted on my Sony A7R3 with a cheap Ulata adapter. They are sharp, very sharp wide open. And so light.
Build quality: without further ado, I think FUNLEADER and Mr. Ding have done an amazing job here: the conversion is incredible, so tiny and lovely, with a great weight and feel. The focus action is nice and smooth and the little focus tab suits the lens. The black paint version is really beautiful, I have always been a black paint / lacquer fan, hence my M-P. This version will get patina with use (unless you're Lenny Kravitz and give it a good rub to look well used). The "gold" version has lovely sharp black engravings and a black focus tab. The focus tabs are really nice, placed at the perfect position where, when pointed straight downwards, the lenses focus at 4 feet / 1.2 meters. I also purchased a "gold" helicoid as I am planning to do a conversion myself. The "gold" helicoid feels like brass and it's a bit of a fingerprint magnet.
The helicoid has "MR. DING" engraved on the mount. Pretty cool. I did a bit of digging and "Mr. Ding" is their master craftsman, maybe having been part of MGR Production. They are also behind the Bresson Viewfinder magnifier, which I happen to have on my M-P and love.
I would love to find out more about Mr. Ding, if anyone has info please do share.
The weight of the helicoid is 206g / 7.26oz and the whole lens is 266g / 9.38g
The lens did have a plastic ring glued on the front, on top of the original Carl Zeiss from markings, but I removed it easily and left no marks. Sorry Mr. Ding, I prefer the original Carl Zeiss engravings.
The original lens hood of the G35 / G45 fits nicely, but I have the champagne version and I personally don't think it works with either the black or the gold version. I might spray paint it with a glossy enamel.
Honestly, it looks amazing on the M-P. It is a gem of a little lens and a great performer.
Customer service: excellent, very responsive, I had quite a few questions for them and they replied very quickly.
Packing: excellent, pragmatic, not fancy.
Shipping: wowsers, the lens was in my hand in Vancouver BC Canada in 6 days, dayum!
PART 2 / 5: colour, focal length, sharpness close and mid distance
Two notes about colour and focal length:
- colour - the G35/2 renders the most accurate and neutral colours, next is the VM 40/1.2, while the 7artisans 35/1.4 M renders quite warm
- focal length - the G35/2 is a little wider than the 7artisans 35/1.4 M, I wonder what their real focal lengths are. Please do share if you happen to know.
Sharpness: the G35/2 is very sharp wide open, it nearly matches the VM 40/1.2 at f2, actually honestly we are splitting hairs between the G35/2 and VM 40/1.2. Keep in mind that the VM starts at 1.2, so from a lens design pov it has a lot of room to be sharp at f2. It's quite a feat how consistent the G35/2 is all the way up to the widest apertures. The G35/2 is sharper than the 7artisans 35/1.4 M at every aperture. I was surprised as well. In all honestly, I really love the 7artisans lens, it has a really nice 3d pop and the built is absolutely amazing.
Check out these 100%s of this starling at f2! I used live view, there's no way to nail that in the viewfinder patch, I also took a bunch of shots and these were the best 4, maybe out of 12 or so.
100%
full images for context
I have done a few test sessions but not included all here (so much to process and compare), so here are a few. Before every comparison chart you will see a half size G35/2 image at f2, for no reason really other than to show you what the whole scene looked like.
Session 1 close:
Session 1 mid distance:
Session 4 close:
Session 4 mid distance:
Session 5 close:
Session 6 close:
PART 3 / 5: sharpness at infinity
Session 3 infinity (center and corner):
Session 7 infinity (center and corner):
PART 4 / 5: bokeh and conclusion
Session 2 mid distance:
Session 6 close:
Vignetting: yea a bit, but nothing out of the ordinary at large apertures. See for yourself.
Focus shift: I did not test for it, but from my walks it seems to be fine.
CONCLUSION:
The Carl Zeiss Contax G Planar 35mm f/2 is a gem. Coming from great heritage, it is now encased in an amazing conversion from FUNLEADER for our Leicas. The G35/2 is an honest lens, you won't find clinical sharpness here, but since you're reading this you're probably not looking for that, but for the resurrection of a highly underrated Carl Zeiss optic. The G35/2 renders the world gently with neutral colour rendition, pleasant bokeh and a sprinkle of pop. The tiny form has a great weight and feel and it simply looks incredible on a Leica. The black paint version is shiny and will brass while the "gold" version has lovely sharp black engravings (bit of a fingerprint magnet though). I honestly look at my camera sitting on my desk now and hear the whispers: "take me out and make photographs". Well done FUNLEADER and Mr. Ding, hat's off to you.
Just like the original little piece of history it now protects and focuses, the FUNLEADER conversion will also be remembered as a gem amongst the connoisseurs.
I hope you enjoy the test results, please let me know if you have any thoughts, suggestions and questions.
Here is the Google Drive folder:
https://drive.google.com/drive/folders/1-mgIUEIScjebkdNY-GAouTlJE3FTCrDy
I am leaving you with a bunch of samples, enjoy.
PART 5 / 5 samples
All the following samples are just snaps from my walks and I barely spent a minute on some of them in C1 :)
f2
f5.6
f8
f2
f2
f2
f5.6
f5.6
f2
f2
f2
f2
f2
f2
f2
f2
f2
f2
f2
f4 (i think)
f2
f2
Cheers! :)
  • Thanks 6
This is awesome thank you; i actually feel that the g45/2 is the most beautiful lens for 35mm film photography, it gives me amazing results and I’d love to be able to use it on a digital body too (contax come back!!!). This 35mm seems to work great too. Is the conversion only for this specific lens or are there similar ones of the g45?
The G45 is amazing, I love the portraits I get with it. This conversion is their first one, sort of just came out. I have high hopes for a G45 conversion from them very soon.
  • 5 months later...
I got this LCA mod / Funleader G35M around 1 years, there are also Black lens Studio ver...
Black Paint CONTAX G G35 35mm f2 Leica M mount Mod by LAC
It can be said that the G35M is a very playful lens. With different aperture values, different distances can also produce different imaging effects … Color / B&W shooting is also very suitable … but the G35M is definitely not an all-around lens. I do not expect it to be, as long as I can adequately put its “defective beauty” to play correctly has been significantly enough
G35M+ M10D + C1 Pro20 + TCP K64 Film Preset
G35M+Sony A7R3 thin mod + C1Pro20 + TCP E100vs film Preset
For further reading, u can see :
Edited by samlee.hk
  • 4 months later...
The G45 is ready for pre-order:
https://myfunleader.com/products/contax-g45-f2-to-leica-m-conversion?ref=Funleader&variant=40931390849185
I love the lens for my G2, but this conversion weighs 332g because it's made of brass.
@pptmstr I'm afraid 332g is too heavy? It's even heavier than the 50mm Lux ASPH.
How easily could you remove the ring glued on the front?
On 11/24/2021 at 11:15 AM, raphael said:
Thanks!
 How did you do it? Is there a tool for removing it?
you can unscrew the front original plastic ring fairly easily then the sticker can be removed with any simple tool that can get a bit underneath it, then continue with your fingers. needless to say maybe: be careful with the front element when you unscrew the front plastic ring and use a plastic tool to get under the sticker (so you don't scratch the original plastic ring), maybe even your nail if you don't want to keep it.
you don't really have to unscrew the front plastic ring. it's just a tough sticker, really, but it's very high quality and does not leave any trace when removed. (sorry again Mr. Ding)
you might be overthinking it a bit :)
I received the black G45 I ordered. Lovely lens. I like it so much.
I also like to remove the front Mr. Ding plastic ring, but not very clear show to do it from the instruction you provided above. Would you mind explain it in more detail?
Thanks a lot.
38 minutes ago, Al Brown said:
I have read everything but am slightly disappointed that no clinical sharpnes could be found.
Seriously though, great test and review.
Don't forget that the G35/2 was considered "the worst" of the Contax G lenses (I like it, but that's a different story, we are talking sharpness here).
The G45/2, on the other hand, was considered "the best", so should be plenty sharp, possibly more than the contemporary Summicron 50/2.
Thanks a lot.
sure, no problem. here, i unscrewed the front plastic ring again to show you. i used that white silicone tool i got when i bought the G35 helicoid, it has great grip, but you can use anything else that has grip. you can see the sticker as well, just need to get underneath it
and here it is on my M10-R black paint (7artisans 28/1.4 52mm hood on top of cinebloom 20% filter with stepup from 46-52mm):
  • Thanks 2
5 hours ago, Al Brown said:
I have read everything but am slightly disappointed that no clinical sharpnes could be found 😁
thanks for the nice words, glad you enjoyed it, i want to do more, time is so limited though ..
I want to do a mega test with multiple lenses i have, who knows when i'll get the time:
Funleader G53/2 and G45/2, Zeiss ZM Distagon 35/1.4 (this lens is insane on the M10-R!!!), Zeiss ZM C-Sonnar 50/1.5,  Voiglander VM 50/2 APO, Voigtlander VM 40/1.2, TTartisan 50/0.95 M
I might borrow a Cron and maybe even a Lux from friends and add them.
Oh the time I wish I had ....
Thank you and look forward to reading your review. How long did it take for you to order and receive the G45/2 from Funleading, if I may ask?
