jeffz Posted January 9, 2021 Share #61 Posted January 9, 2021 Advertisement (gone after registration) I am late to the thread. My kit is all the f2.5 Summarits and a Zeiss 28mm. I have found them to be wonderfully sharp, compact and a true value. 3 Link to post Share on other sites More sharing options...
Advertisement Posted January 9, 2021 Posted January 9, 2021 Hi jeffz, Take a look here Summarits - A case study. I'm sure you'll find what you were looking for!
stephengv Posted January 13, 2021 Share #62 Posted January 13, 2021 Do you think the recently discontinued summarit lenses, specifically the 75 2.4 will increased in value? Link to post Share on other sites More sharing options...
a.noctilux Posted January 17, 2021 Share #63 Posted January 17, 2021 On 1/13/2021 at 5:00 PM, stephengv said: Do you think the recently discontinued summarit lenses, specifically the 75 2.4 will increased in value? Hello Stephen, if you can buy one in your price range, just buy it as user. Loss/gain value may be of small amount, as these Summarit-M would never enter the expensive collector's market. If the lens lost it's value, you would have a good lens for the price of lost-value if you sell. In either case lost/gain value, I'd not be ansty. 1 Link to post Share on other sites More sharing options...
stephengv Posted January 19, 2021 Share #64 Posted January 19, 2021 On 1/7/2021 at 12:22 AM, Herr Barnack said: What's going on is the rubber is experiencing oxidation as it ages. 303 Protectant should remove the oxidation and restore the rubber to near new condition. A drop or two on the tip of a Q-Tip should be sufficient - just make sure the Q-Tip is damp, not soaking wet so you don't have 303 trickling into the mechanical works of your lens. https://www.amazon.com/303-30313-CSR-Protectant-Plastic-Fiberglass/dp/B0045E7PC8?ref_=ast_sto_dp&th=1 Can I use Armorall? Link to post Share on other sites More sharing options...
stephengv Posted January 19, 2021 Share #65 Posted January 19, 2021 On 1/7/2021 at 12:22 AM, Herr Barnack said: What's going on is the rubber is experiencing oxidation as it ages. 303 Protectant should remove the oxidation and restore the rubber to near new condition. A drop or two on the tip of a Q-Tip should be sufficient - just make sure the Q-Tip is damp, not soaking wet so you don't have 303 trickling into the mechanical works of your lens. https://www.amazon.com/303-30313-CSR-Protectant-Plastic-Fiberglass/dp/B0045E7PC8?ref_=ast_sto_dp&th=1 Do you applies this when the lens is new or only when it shows oxidation? Link to post Share on other sites More sharing options...
Herr Barnack Posted January 19, 2021 Share #66 Posted January 19, 2021 My understanding is that applying 303 about once a month will keep the rubber from oxidizing. Link to post Share on other sites More sharing options...
Herr Barnack Posted January 19, 2021 Share #67 Posted January 19, 2021 Advertisement (gone after registration) 2 hours ago, stephengv said: Can I use Armorall? I wouldn't - Armorall has a petroleum component. That is why 303 was developed - people were using Armorall on their canoes and kayaks. When they put them into a lake, the Armorall would leave a multicolored oil ring around the boat. I would not use anything with a petrol component on my cameras or lenses. Link to post Share on other sites More sharing options...
stephengv Posted January 19, 2021 Share #68 Posted January 19, 2021 3 minutes ago, Herr Barnack said: My understanding is that applying 303 about once a month will keep the rubber from oxidizing. So even if its new, I should apply 303? Link to post Share on other sites More sharing options...
Herr Barnack Posted January 19, 2021 Share #69 Posted January 19, 2021 (edited) 11 minutes ago, stephengv said: So even if its new, I should apply 303? It can't hurt - it will help keep the rubber from drying out and oxidizing. As I stated in my post 57 above - Quote ...A drop or two on the tip of a Q-Tip should be sufficient - just make sure the Q-Tip is damp, not soaking wet so you don't have 303 trickling into the mechanical works of your lens... Edited January 19, 2021 by Herr Barnack Link to post Share on other sites More sharing options...
stephengv Posted January 19, 2021 Share #70 Posted January 19, 2021 19 minutes ago, Herr Barnack said: It can't hurt - it will help keep the rubber from drying out and oxidizing. As I stated in my post 57 above - Thanks, just ordered one Link to post Share on other sites More sharing options...
a.noctilux Posted July 29, 2022 Share #71 Posted July 29, 2022 (edited) With Jeff's link, I "unearth" this thread, nice ideas as how lenses were made and trick to get rid of "whitening" rubber ring. Many thanks to the authors 👍. We have also Edited July 29, 2022 by a.noctilux Link to post Share on other sites More sharing options...
rpsawin Posted July 29, 2022 Share #72 Posted July 29, 2022 (edited) 55 minutes ago, a.noctilux said: With Jeff's link, I "unearth" this thread, nice ideas as how lenses were made and trick to get rid of "whitening" rubber ring. Many thanks to the authors 👍. We have also I also have added a 50/2.4 Summarit as well. Edited July 29, 2022 by rpsawin Link to post Share on other sites More sharing options...
