Schittra Posted March 15, 2020 Share #1 Posted March 15, 2020 Advertisement (gone after registration) I use nitecore charger ULM10 pro without QC2.0. So it won’t give me reach 1200 mA, right? When it shows as FULL, it is around 85% when I put to the camera. Do I understand correctly? Hmmm... I think I will get the QC2.0 adapter then. Thank you for the input. Link to post Share on other sites More sharing options...
Advertisement Posted March 15, 2020 Posted March 15, 2020 Hi Schittra, Take a look here Nitecore ULM10 charger. I'm sure you'll find what you were looking for!
jakontil Posted March 15, 2020 Share #2 Posted March 15, 2020 Even without the QC, it would still give you a real 1200mah capacity but slower and if you charge 2 batteries at the same time, it does simultaneously instead get the proper quick charger for nitecore 1 Link to post Share on other sites More sharing options...
Schittra Posted March 15, 2020 Author Share #3 Posted March 15, 2020 26 minutes ago, jakontil said: Even without the QC, it would still give you a real 1200mah capacity but slower and if you charge 2 batteries at the same time, it does simultaneously instead get the proper quick charger for nitecore Thanks. When it reaches to 800mAh, it shows FULL. Link to post Share on other sites More sharing options...
jakontil Posted March 15, 2020 Share #4 Posted March 15, 2020 3 hours ago, Schittra said: Thanks. When it reaches to 800mAh, it shows FULL. Hi, what charger are you using? may b try to get the proper one hopes it helps 1 Link to post Share on other sites More sharing options...
Soden Posted March 15, 2020 Share #5 Posted March 15, 2020 I find with My ULM10 that if I take the battery out soon after it says full I get 1200Ah. However if I just let it sit for a while the battery drains to about 800Ah. It does not matter if I use my iPhone converter or my QC3 1 Link to post Share on other sites More sharing options...
LeicaS2 Posted April 11, 2020 Share #6 Posted April 11, 2020 Even if I leave the battery at the charger, I back it off the connection once I remove the power, otherwise I worried the battery would back drain into the charger. 1 Link to post Share on other sites More sharing options...
